I have written a program to measure time for a time of flight experiment using an mBed LPC1768. To achieve the required precision I need timer0 to run at full clock speed (96 MHz) and the max speed I am getting is 12 MHz. I wrote a short routine on an 8-bit processor running at 16 MHz to trip the gates as a means of debugging without running the whole system. The clock speed of the 8-bit processor was verified using an oscilloscope. Using TIMER0_SETPRESCALE(1); to set the prescaler I thought would have timer0 running at full speed, I commented it out thinking that if I did set the prescaler it would default to max speed, both of these gave me a clock speed of 12 MHz. I used a variety of prescaler values and did not get the expected results.
The size of the source code is too large to include so I only included the pertinent routines and definitions below. The value of variable elapsedTicks assigned in gateOneTicks() is 1/8 of what it should be that is why I am saying the max speed is 12 MHz.
Does anyone see a reason why timer0 is giving such slow speed results, hopefully I have done something stupid and simple to fix, trust me it would not be the first time.
Thanks for looking at this post,
wade
Timer setup and interrupts
#include <mbed.h>
#include <time.h>
#include <timers.h>
volatile unsigned long elapsedTicks;
InterruptIn gateOne(GATEONEPIN);
InterruptIn gateTwo(GATETWOPIN);
//Function Prototypes
void gateOneTime(void);
void gateTwoTime(void);
void systemSetup(void);
void clockSetup(void);
void systemSetup(void){
// Set up interrupts
gateOne.rise(&gateOneTime);
gateTwo.rise(&gateTwoTime);
void clockSetup(void){
// Set up clock to run at full speed (96 Mhz) so the timing resolution is at a max
TIMER0_INIT();
TIMER0_START();
// TIMER0_SETPRESCALE(1); // Here the clock prescale is being set
// There are different interrupt routines for gate one and two they could be combined
// as long as the state variable is managed properly. Combining them would be a little
// elegant but using one for each gate does not cost much space.
void gateOneTime(void){
__disable_irq();// Turn off Interrupts
// timer.reset();
TIMER0_INIT();
TIMER0_START();
state = 2;
__enable_irq();// Turn on Interrupts
void gateTwoTime(void){
elapsedTicks = TIMER0_VALUE();
if(state != 2){
state = 5; // second gate was triggered before first gate
state = 3;
wade
#include <mbed.h> #include <time.h> #include <timers.h> volatile unsigned long elapsedTicks; InterruptIn gateOne(GATEONEPIN); InterruptIn gateTwo(GATETWOPIN); //Function Prototypes void gateOneTime(void); void gateTwoTime(void); void systemSetup(void); void clockSetup(void); void systemSetup(void){ // Set up interrupts gateOne.rise(&gateOneTime); gateTwo.rise(&gateTwoTime); } void clockSetup(void){ // Set up clock to run at full speed (96 Mhz) so the timing resolution is at a max TIMER0_INIT(); TIMER0_START(); // TIMER0_SETPRESCALE(1); // Here the clock prescale is being set } // There are different interrupt routines for gate one and two they could be combined // as long as the state variable is managed properly. Combining them would be a little // elegant but using one for each gate does not cost much space. void gateOneTime(void){ __disable_irq();// Turn off Interrupts // timer.reset(); TIMER0_INIT(); TIMER0_START(); state = 2; __enable_irq();// Turn on Interrupts } void gateTwoTime(void){ __disable_irq();// Turn off Interrupts elapsedTicks = TIMER0_VALUE(); if(state != 2){ state = 5; // second gate was triggered before first gate } state = 3; __enable_irq();// Turn on Interrupts }
