Hardware: K64F, onboard compass/accel, venus GPS (115200, 10Hz)
Currently I am trying to access the serial port and compass using the mbed RTOS with mixed results. The program will run, but it will freeze at unknown times. I have seen this problem solved with the MODSERIAL and buffered serial libraries but, at this point I have not been able to implement them on the K64F. Without the compass code the program will run indefinately, but the shared resources have become a problem.
Is there a way to safely access the serial port with RTOS and onboard senors?
FYI, my background is mechanical engineering and I am stretching my capabilities with the code...
#include "rtos.h"
#include "nmea.h"
#include "ff.h"
#include "FXOS8700Q.h"
#include "eCompass_Lib.h"
//DigitalOut blue(LED3); // BLUE LED on K64F Freedom board
//______________________________ DEFINE COMPASS_____________________
FXOS8700Q_acc acc( PTE25, PTE24, FXOS8700CQ_SLAVE_ADDR1);
FXOS8700Q_mag mag( PTE25, PTE24, FXOS8700CQ_SLAVE_ADDR1);
eCompass compass;
extern axis6_t axis6;
extern uint32_t seconds;
extern uint32_t compass_type; // optional, NED compass is default
extern int32_t tcount;
extern uint8_t cdebug;
int l = 0;
volatile int sflag = 0;
MotionSensorDataCounts mag_raw;
MotionSensorDataCounts acc_raw;
Thread *(calibrate);
// This HAL map is for the FXOS8700Q on the K64F Freedom board.
void hal_map( MotionSensorDataCounts * acc_raw, MotionSensorDataCounts * mag_raw)
int16_t t;
// swap and negate accelerometer X & Y axis
t = acc_raw->x;
acc_raw->x = acc_raw->y * -1;
acc_raw->y = t * -1;
// swap magnetometer X & Y axis
t = mag_raw->x;
mag_raw->x = mag_raw->y;
mag_raw->y = t;
// negate magnetometer Z axis
mag_raw->z *= -1;
void calibrate_thread(void const *argument)
while(true) {
Thread::signal_wait(0x2);
compass.calibrate();
void compass_thread(void const *argument)
// get raw data from the sensors
acc.getAxis( acc_raw);
mag.getAxis( mag_raw);
if(tcount) compass.run( acc_raw, mag_raw); // calculate the eCompass
if(l++ >= 49) { // take car of business once a second
seconds++;
calibrate->signal_set(0x2);
l = 0;
sflag = 1;
tcount++;
//______________________________ END DEFINE COMPASS_____________________
RawSerial pc(USBTX, USBRX);
RawSerial gps(PTC17, PTC16);
Thread *RX_THREAD_POINTER;
int get_filename(char *fn);
NMEA nmea;
Semaphore sd_sem(0);
typedef struct {
char line[80];
} sensor_line;
MemoryPool<sensor_line, 16> mpool_sensor_line;
Queue<sensor_line, 16> queue_sensor_line;
// Rx Interupt routine
void Rx_interrupt(void)
gps.attach(NULL, gps.RxIrq); // Disable Rx interrupt
(*RX_THREAD_POINTER).signal_set(0x1);
void gps_thread(void const *args)
gps.baud(115200);
Thread::signal_wait(0x1);
while(gps.readable()) {
volatile char c = gps.getc();
nmea.fusedata(c);
gps.attach(&Rx_interrupt, gps.RxIrq);
void log_thread(const void *args)
DigitalOut log_led(LED3);
FATFS fs;
FIL fp_sensor;
f_mount(0, &fs);
f_open(&fp_sensor, "0:sensors.csv", FA_OPEN_EXISTING | FA_WRITE);
f_lseek(&fp_sensor, f_size(&fp_sensor));
sd_sem.release(); // sd card initialized... start sensor thread
Timer t;
t.start();
osEvent evt = queue_sensor_line.get(1);
if(evt.status == osEventMessage) {
log_led = !log_led;
sensor_line *message = (sensor_line*)evt.value.p;
f_puts(message->line, &fp_sensor);
f_sync(&fp_sensor);
pc.puts(message->line);
mpool_sensor_line.free(message);
void sensor_thread(const void* args)
DigitalOut sensor_led(LED2);
while( sd_sem.wait(50) <= 0) {} // wait for the sd card to initialize and open files
while(!nmea.isdataready()) {
Thread::wait(50); // wait for lock
sensor_line *message = mpool_sensor_line.alloc();
sprintf(message->line, "Lattitude");
queue_sensor_line.put(message);
while(true) {
//get sensor line memory
sensor_led = !sensor_led;
sprintf(message->line, "Lat: %f Heading: %i \n\r", nmea.getLatitude(), axis6.yaw);
Thread::wait(200);
pc.baud(115200);
//eCOMPASS START
acc.enable();
mag.enable();
RtosTimer compass_timer(compass_thread, osTimerPeriodic);
//eCOMPASS END
Thread t2(calibrate_thread);
calibrate = &t2;
Thread t_rx(gps_thread);
RX_THREAD_POINTER = &t_rx;
t_rx.set_priority(osPriorityHigh);
Thread thread2(log_thread, NULL, osPriorityNormal);
Thread thread3(sensor_thread, NULL, osPriorityNormal);
calibrate->set_priority(osPriorityBelowNormal);
compass_timer.start(20);
while(true) {
Thread::wait(osWaitForever);
