Hi all,
The code below activates LEDs and relays on two boards with xbee, how do I change the code to work on a web application running in a browser using RPC or other form of remote serial communication?
#include "mbed.h" Serial xbee1(p13,p14); DigitalOut rst1(p11); //Digital reset for the XBee, 200ns for reset DigitalOut myled(LED3);//Create variable for Led 3 on the mbed int main() { rst1 = 0; //Set reset pin to 0 myled = 0;//Set LED3 to 0 wait_ms(1);//Wait at least one millisecond rst1 = 1;//Set reset pin to 1 wait_ms(1);//Wait another millisecond while (1) {//Neverending Loop myled = 1; //Turn Led 3 Off //Frame XBEE 1 turn on relay xbee1.putc(0x7E); //start byte of API frame xbee1.putc(0x00); //high part of length.It always zero xbee1.putc(0x10); //low part of length.The number of bytes that follow,not including checksum xbee1.putc(0x17); // frame type.In this case 0x17 is a remote AT command xbee1.putc(0x05); //Frame ID.No acknowledgment is needed.The remote xbee will receive what we send xbee1.putc(0x00); xbee1.putc(0x13); //XBEE ANDRESS xbee1.putc(0xA2); //XBEE ANDRESS xbee1.putc(0x00);//XBEE ANDRESS xbee1.putc(0x40);//XBEE ANDRESS xbee1.putc(0xA1); ///XBEE ANDRESS xbee1.putc(0x3A); //XBEE ANDRESS xbee1.putc(0xB6); //XBEE ANDRESS xbee1.putc(0xFF); xbee1.putc(0xFE); xbee1.putc(0x02); xbee1.putc(0x44); // command name in ASCII characters "D" xbee1.putc(0x34); // command name in ASCII characters "4" xbee1.putc(0x05); // D 4 HIGH xbee1.putc(0xE1); //CHECKSUM wait(1); myled = 0; //Turn Led 3 on for succcessfull communication wait(1); //Frame XBEE 1 turn off relay xbee1.putc(0x7E); //start byte of API frame xbee1.putc(0x00); //high part of length.It always zero xbee1.putc(0x10); //low part of length.The number of bytes that follow,not including checksum xbee1.putc(0x17); // frame type.In this case 0x17 is a remote AT command xbee1.putc(0x05); //Frame ID.No acknowledgment is needed.The remote xbee will receive what we send xbee1.putc(0x00); xbee1.putc(0x13); //XBEE ANDRESS xbee1.putc(0xA2); //XBEE ANDRESS xbee1.putc(0x00);//XBEE ANDRESS xbee1.putc(0x40);//XBEE ANDRESS xbee1.putc(0xA1); //XBEE ANDRESS xbee1.putc(0x3A); //XBEE ANDRESS xbee1.putc(0xB6); //XBEE ANDRESS xbee1.putc(0xFF); xbee1.putc(0xFE); xbee1.putc(0x02); xbee1.putc(0x44); // command name in ASCII characters "D" xbee1.putc(0x34);// command name in ASCII characters "4" xbee1.putc(0x04);// D 4 LOW xbee1.putc(0xE2);//CHECKSUM wait(1); //Frame XBEE 2 turn on relay xbee1.putc(0x7E); //start byte of API frame xbee1.putc(0x00); //high part of length.It always zero xbee1.putc(0x10); //low part of length.The number of bytes that follow,not including checksum xbee1.putc(0x17); // frame type.In this case 0x17 is a remote AT command xbee1.putc(0x05); //Frame ID.No acknowledgment is needed.The remote xbee will receive what we send xbee1.putc(0x00); xbee1.putc(0x13); xbee1.putc(0xA2); xbee1.putc(0x00); xbee1.putc(0x40); xbee1.putc(0xA0); xbee1.putc(0x40); xbee1.putc(0x37); xbee1.putc(0xFF); xbee1.putc(0xFE); xbee1.putc(0x02); xbee1.putc(0x44); xbee1.putc(0x34); xbee1.putc(0x05); xbee1.putc(0x5B); wait(1); //Frame XBEE 2 turn off relay xbee1.putc(0x7E); //start byte of API frame xbee1.putc(0x00); //high part of length.It always zero xbee1.putc(0x10); //low part of length.The number of bytes that follow,not including checksum xbee1.putc(0x17); // frame type.In this case 0x17 is a remote AT command xbee1.putc(0x05); //Frame ID.No acknowledgment is needed.The remote xbee will receive what we send xbee1.putc(0x00); xbee1.putc(0x13); xbee1.putc(0xA2); xbee1.putc(0x00); xbee1.putc(0x40); xbee1.putc(0xA0); xbee1.putc(0x40); xbee1.putc(0x37); xbee1.putc(0xFF); xbee1.putc(0xFE); xbee1.putc(0x02); xbee1.putc(0x44); xbee1.putc(0x34); xbee1.putc(0x04); xbee1.putc(0x5C); wait(1); } }
