Besides this communication we are doing motion control. However, the performance of this motion control loop is ruined when communication over USB comes in. My hypothesis is that this has to do with printf statements (note: From past experience I am familiar with the troubles printf statements can cause and therefore I want to get rid of them as much as possible.) which by default can be found in the USBHID library. To be more exact in the file USBDevice.cpp. Each time as USB communication comes in some of these printf statements provide output.
It should be easy to just disable/remove these printf statements. The file is even prepared to do so by commenting line 10.
However when I disable the printf statements this ruins the HID communication. I tried in different ways to get rid of these printfs in this file but all ways introduce the same trouble. So it only works with the printf statements in place. I am breaking my head about this as the printf statements shouldn't influence functionality of the USB HID library but they do?
Does anybody see what I miss here of have ideas about this? Or suggestions how to get rid of the printf statements after all.
Thanks. Your help is appreciated!
USBDevice.cpp
/* Copyright (c) 2010-2011 mbed.org, MIT License */
#include "stdint.h"
#include "USBEndpoints.h"
#include "USBDevice.h"
#include "USBDescriptor.h"
#define DEBUG //print debug messages
/* Device status */
#define DEVICE_STATUS_SELF_POWERED (1U<<0)
#define DEVICE_STATUS_REMOTE_WAKEUP (1U<<1)
/* Endpoint status */
#define ENDPOINT_STATUS_HALT (1U<<0)
/* Standard feature selectors */
#define DEVICE_REMOTE_WAKEUP (1)
#define ENDPOINT_HALT (0)
/* Macro to convert wIndex endpoint number to physical endpoint number */
#define WINDEX_TO_PHYSICAL(endpoint) (((endpoint & 0x0f) << 1) + \
((endpoint & 0x80) ? 1 : 0))
bool USBDevice::requestGetDescriptor(void)
bool success = false;
#ifdef DEBUG
printf("get descr: type: %d\r\n", DESCRIPTOR_TYPE(transfer.setup.wValue));
#endif
switch (DESCRIPTOR_TYPE(transfer.setup.wValue)) {
case DEVICE_DESCRIPTOR:
if (deviceDesc() != NULL) {
if ((deviceDesc()[0] == DEVICE_DESCRIPTOR_LENGTH) \
&& (deviceDesc()[1] == DEVICE_DESCRIPTOR)) {
#ifdef DEBUG
printf("device descr\r\n");
#endif
transfer.remaining = DEVICE_DESCRIPTOR_LENGTH;
transfer.ptr = deviceDesc();
transfer.direction = DEVICE_TO_HOST;
success = true;
break;
case CONFIGURATION_DESCRIPTOR:
if (configurationDesc() != NULL) {
if ((configurationDesc()[0] == CONFIGURATION_DESCRIPTOR_LENGTH) \
&& (configurationDesc()[1] == CONFIGURATION_DESCRIPTOR)) {
#ifdef DEBUG
printf("conf descr request\r\n");
#endif
/* Get wTotalLength */
transfer.remaining = configurationDesc()[2] \
| (configurationDesc()[3] << 8);
transfer.ptr = configurationDesc();
success = true;
break;
case STRING_DESCRIPTOR:
#ifdef DEBUG
printf("str descriptor\r\n");
#endif
switch (DESCRIPTOR_INDEX(transfer.setup.wValue)) {
case STRING_OFFSET_LANGID:
#ifdef DEBUG
printf("1\r\n");
#endif
transfer.remaining = stringLangidDesc()[0];
transfer.ptr = stringLangidDesc();
success = true;
break;
case STRING_OFFSET_IMANUFACTURER:
#ifdef DEBUG
printf("2\r\n");
#endif
transfer.remaining = stringImanufacturerDesc()[0];
transfer.ptr = stringImanufacturerDesc();
success = true;
break;
case STRING_OFFSET_IPRODUCT:
#ifdef DEBUG
printf("3\r\n");
#endif
transfer.remaining = stringIproductDesc()[0];
transfer.ptr = stringIproductDesc();
success = true;
break;
case STRING_OFFSET_ISERIAL:
#ifdef DEBUG
printf("4\r\n");
#endif
transfer.remaining = stringIserialDesc()[0];
transfer.ptr = stringIserialDesc();
success = true;
break;
case STRING_OFFSET_ICONFIGURATION:
#ifdef DEBUG
printf("5\r\n");
#endif
transfer.remaining = stringIConfigurationDesc()[0];
transfer.ptr = stringIConfigurationDesc();
success = true;
break;
case STRING_OFFSET_IINTERFACE:
#ifdef DEBUG
printf("6\r\n");
#endif
transfer.remaining = stringIinterfaceDesc()[0];
transfer.ptr = stringIinterfaceDesc();
success = true;
break;
break;
case INTERFACE_DESCRIPTOR:
#ifdef DEBUG
printf("interface descr\r\n");
#endif
case ENDPOINT_DESCRIPTOR:
#ifdef DEBUG
printf("endpoint descr\r\n");
#endif
/* TODO: Support is optional, not implemented here */
break;
default:
#ifdef DEBUG
printf("ERROR\r\n");
#endif
break;
return success;
void USBDevice::decodeSetupPacket(uint8_t *data, SETUP_PACKET *packet)
/* Fill in the elements of a SETUP_PACKET structure from raw data */
packet->bmRequestType.dataTransferDirection = (data[0] & 0x80) >> 7;
packet->bmRequestType.Type = (data[0] & 0x60) >> 5;
packet->bmRequestType.Recipient = data[0] & 0x1f;
packet->bRequest = data[1];
packet->wValue = (data[2] | (uint16_t)data[3] << 8);
packet->wIndex = (data[4] | (uint16_t)data[5] << 8);
packet->wLength = (data[6] | (uint16_t)data[7] << 8);
bool USBDevice::controlOut2(void)
#ifdef DEBUG
printf("ControlOut2\r\n");
#endif
/* Control transfer data OUT stage */
uint8_t buffer[MAX_PACKET_SIZE_EP0];
uint32_t packetSize;
/* Read from endpoint */
packetSize = EP0getReadResult(buffer);
/* Update transfer */
transfer.ptr += packetSize;
transfer.remaining -= packetSize;
/* Check if transfer has completed */
/* Transfer completed */
// if(transfer.setup.bmRequestType.dataTransferDirection == 0 && transfer.setup.bmRequestType.Type == 1 && transfer.setup.bmRequestType.Recipient == 1 && transfer.setup.bRequest == 9 && transfer.setup.wValue == 512) {
USBCallback_dataReceived(buffer,packetSize);
return true;
bool USBDevice::controlOut(void)
/* Check we should be transferring data OUT */
if (transfer.direction != HOST_TO_DEVICE) {
return false;
/* Check if transfer size is valid */
if (packetSize > transfer.remaining) {
/* Too big */
return false;
if (transfer.remaining == 0) {
if (transfer.notify) {
/* Notify class layer. */
USBCallback_requestCompleted(buffer, packetSize);
transfer.notify = false;
/* Status stage */
EP0write(NULL, 0);
} else {
EP0read();
return true;
bool USBDevice::controlIn(void)
/* Control transfer data IN stage */
/* Check if transfer has completed (status stage transactions */
/* also have transfer.remaining == 0) */
if (transfer.zlp) {
/* Send zero length packet */
EP0write(NULL, 0);
transfer.zlp = false;
USBCallback_requestCompleted(NULL, 0);
EP0read();
EP0readStage();
/* Completed */
return true;
/* Check we should be transferring data IN */
if (transfer.direction != DEVICE_TO_HOST) {
return false;
packetSize = transfer.remaining;
if (packetSize > MAX_PACKET_SIZE_EP0) {
packetSize = MAX_PACKET_SIZE_EP0;
/* Write to endpoint */
EP0write(transfer.ptr, packetSize);
return true;
bool USBDevice::requestSetAddress(void)
/* Set the device address */
setAddress(transfer.setup.wValue);
if (transfer.setup.wValue == 0) {
device.state = DEFAULT;
} else {
device.state = ADDRESS;
return true;
bool USBDevice::requestSetConfiguration(void)
device.configuration = transfer.setup.wValue;
/* Set the device configuration */
if (device.configuration == 0) {
/* Not configured */
unconfigureDevice();
} else {
if (USBCallback_setConfiguration(device.configuration)) {
/* Valid configuration */
configureDevice();
device.state = CONFIGURED;
} else {
return false;
return true;
bool USBDevice::requestGetConfiguration(void)
/* Send the device configuration */
transfer.ptr = &device.configuration;
transfer.remaining = sizeof(device.configuration);
return true;
bool USBDevice::requestGetInterface(void)
/* Return the selected alternate setting for an interface */
if (device.state != CONFIGURED) {
return false;
/* Send the alternate setting */
transfer.setup.wIndex = currentInterface;
transfer.ptr = ¤tAlternate;
transfer.remaining = sizeof(currentAlternate);
return true;
bool USBDevice::requestSetInterface(void)
if(USBCallback_setInterface(transfer.setup.wIndex, transfer.setup.wValue)) {
success = true;
currentInterface = transfer.setup.wIndex;
currentAlternate = transfer.setup.wValue;
return success;
bool USBDevice::requestSetFeature()
/* Endpoint or interface must be zero */
if (transfer.setup.wIndex != 0) {
return false;
switch (transfer.setup.bmRequestType.Recipient) {
case DEVICE_RECIPIENT:
/* TODO: Remote wakeup feature not supported */
break;
case ENDPOINT_RECIPIENT:
if (transfer.setup.wValue == ENDPOINT_HALT) {
/* TODO: We should check that the endpoint number is valid */
stallEndpoint(
WINDEX_TO_PHYSICAL(transfer.setup.wIndex));
success = true;
break;
default:
break;
return success;
bool USBDevice::requestClearFeature()
return false;
break;
unstallEndpoint( WINDEX_TO_PHYSICAL(transfer.setup.wIndex));
success = true;
break;
default:
break;
return success;
bool USBDevice::requestGetStatus(void)
static uint16_t status;
return false;
/* TODO: Currently only supports self powered devices */
status = DEVICE_STATUS_SELF_POWERED;
success = true;
break;
case INTERFACE_RECIPIENT:
status = 0;
success = true;
break;
if (getEndpointStallState(
WINDEX_TO_PHYSICAL(transfer.setup.wIndex))) {
status = ENDPOINT_STATUS_HALT;
} else {
status = 0;
success = true;
break;
default:
break;
if (success) {
/* Send the status */
transfer.ptr = (uint8_t *)&status; /* Assumes little endian */
transfer.remaining = sizeof(status);
return success;
bool USBDevice::requestSetup(void)
/* Process standard requests */
if ((transfer.setup.bmRequestType.Type == STANDARD_TYPE)) {
switch (transfer.setup.bRequest) {
case GET_STATUS:
success = requestGetStatus();
break;
case CLEAR_FEATURE:
success = requestClearFeature();
break;
case SET_FEATURE:
success = requestSetFeature();
break;
case SET_ADDRESS:
success = requestSetAddress();
break;
case GET_DESCRIPTOR:
success = requestGetDescriptor();
break;
case SET_DESCRIPTOR:
success = false;
break;
case GET_CONFIGURATION:
success = requestGetConfiguration();
break;
case SET_CONFIGURATION:
success = requestSetConfiguration();
break;
case GET_INTERFACE:
success = requestGetInterface();
break;
case SET_INTERFACE:
success = requestSetInterface();
break;
default:
break;
return success;
bool USBDevice::controlSetup(void)
/* Control transfer setup stage */
EP0setup(buffer);
/* Initialise control transfer state */
decodeSetupPacket(buffer, &transfer.setup);
transfer.ptr = NULL;
transfer.remaining = 0;
transfer.direction = 0;
#ifdef DEBUG
printf("dataTransferDirection: %d\r\nType: %d\r\nRecipient: %d\r\nbRequest: %d\r\nwValue: %d\r\nwIndex: %d\r\nwLength: %d\r\n",transfer.setup.bmRequestType.dataTransferDirection,
transfer.setup.bmRequestType.Type,
transfer.setup.bmRequestType.Recipient,
transfer.setup.bRequest,
transfer.setup.wValue,
transfer.setup.wLength);
#endif
controlOut2();
/* Class / vendor specific */
success = USBCallback_request();
if (!success) {
/* Standard requests */
if (!requestSetup()) {
#ifdef DEBUG
printf("fail!!!!\r\n");
#endif
return false;
/* Check transfer size and direction */
if (transfer.setup.wLength>0) {
if (transfer.setup.bmRequestType.dataTransferDirection \
== DEVICE_TO_HOST) {
/* IN data stage is required */
return false;
/* Transfer must be less than or equal to the size */
/* requested by the host */
if (transfer.remaining > transfer.setup.wLength) {
transfer.remaining = transfer.setup.wLength;
} else {
/* OUT data stage is required */
return false;
/* Transfer must be equal to the size requested by the host */
if (transfer.remaining != transfer.setup.wLength) {
return false;
} else {
/* No data stage; transfer size must be zero */
if (transfer.remaining != 0) {
return false;
/* Data or status stage if applicable */
/* Check if we'll need to send a zero length packet at */
/* the end of this transfer */
if (transfer.setup.wLength > transfer.remaining) {
/* Device wishes to transfer less than host requested */
if ((transfer.remaining % MAX_PACKET_SIZE_EP0) == 0) {
/* Transfer is a multiple of EP0 max packet size */
transfer.zlp = true;
#ifdef DEBUG
printf("CONTROLIN!!!!\r\n");
#endif
/* IN stage */
controlIn();
} else {
#ifdef DEBUG
printf("EPOREAD!!!\r\n");
#endif
/* OUT stage */
EP0read();
} else {
#ifdef DEBUG
printf("EP0WRITE!!!!\r\n");
#endif
/* Status stage */
EP0write(NULL, 0);
return true;
void USBDevice::busReset(void)
device.configuration = 0;
device.suspended = false;
/* Call class / vendor specific busReset function */
USBCallback_busReset();
void USBDevice::EP0setupCallback(void)
/* Endpoint 0 setup event */
if (!controlSetup()) {
/* Protocol stall */
EP0stall();
/* Return true if an OUT data stage is expected */
void USBDevice::EP0out(void)
/* Endpoint 0 OUT data event */
if (!controlOut()) {
/* Protocol stall; this will stall both endpoints */
EP0stall();
void USBDevice::EP0in(void)
#ifdef DEBUG
printf("EP0IN\r\n");
#endif
/* Endpoint 0 IN data event */
if (!controlIn()) {
EP0stall();
bool USBDevice::configured(void)
/* Returns true if device is in the CONFIGURED state */
return (device.state == CONFIGURED);
void USBDevice::connect(void)
/* Connect device */
USBHAL::connect();
/* Block if not configured */
while (!configured());
void USBDevice::disconnect(void)
/* Disconnect device */
USBHAL::disconnect();
CONTROL_TRANSFER * USBDevice::getTransferPtr(void)
return &transfer;
bool USBDevice::addEndpoint(uint8_t endpoint, uint32_t maxPacket)
return realiseEndpoint(endpoint, maxPacket, 0);
bool USBDevice::addRateFeedbackEndpoint(uint8_t endpoint, uint32_t maxPacket)
/* For interrupt endpoints only */
return realiseEndpoint(endpoint, maxPacket, RATE_FEEDBACK_MODE);
uint8_t * USBDevice::findDescriptor(uint8_t descriptorType)
/* Find a descriptor within the list of descriptors */
/* following a configuration descriptor. */
uint16_t wTotalLength;
uint8_t *ptr;
if (configurationDesc() == NULL) {
return NULL;
/* Check this is a configuration descriptor */
if ((configurationDesc()[0] != CONFIGURATION_DESCRIPTOR_LENGTH) \
|| (configurationDesc()[1] != CONFIGURATION_DESCRIPTOR)) {
return NULL;
wTotalLength = configurationDesc()[2] | (configurationDesc()[3] << 8);
/* Check there are some more descriptors to follow */
if (wTotalLength <= (CONFIGURATION_DESCRIPTOR_LENGTH+2))
/* +2 is for bLength and bDescriptorType of next descriptor */
return false;
/* Start at first descriptor after the configuration descriptor */
ptr = &(configurationDesc()[CONFIGURATION_DESCRIPTOR_LENGTH]);
do {
if (ptr[1] /* bDescriptorType */ == descriptorType) {
/* Found */
return ptr;
/* Skip to next descriptor */
ptr += ptr[0]; /* bLength */
} while (ptr < (configurationDesc() + wTotalLength));
/* Reached end of the descriptors - not found */
return NULL;
void USBDevice::connectStateChanged(unsigned int connected)
void USBDevice::suspendStateChanged(unsigned int suspended)
USBDevice::USBDevice(uint16_t vendor_id, uint16_t product_id, uint16_t product_release)
VENDOR_ID = vendor_id;
PRODUCT_ID = product_id;
PRODUCT_RELEASE = product_release;
/* Set initial device state */
device.state = POWERED;
bool USBDevice::readStart(uint8_t endpoint, uint32_t maxSize)
return endpointRead(endpoint, maxSize) == EP_PENDING;
bool USBDevice::write(uint8_t endpoint, uint8_t * buffer, uint32_t size, uint32_t maxSize)
EP_STATUS result;
if (size > maxSize) {
return false;
if(!configured()) {
return false;
/* Send report */
result = endpointWrite(endpoint, buffer, size);
if (result != EP_PENDING) {
return false;
/* Wait for completion */
do {
result = endpointWriteResult(endpoint);
} while ((result == EP_PENDING) && configured());
return (result == EP_COMPLETED);
bool USBDevice::writeNB(uint8_t endpoint, uint8_t * buffer, uint32_t size, uint32_t maxSize)
EP_STATUS result;
return false;
if(!configured()) {
return false;
/* Send report */
return false;
bool USBDevice::readEP(uint8_t endpoint, uint8_t * buffer, uint32_t * size, uint32_t maxSize)
EP_STATUS result;
if(!configured()) {
return false;
do {
result = endpointReadResult(endpoint, buffer, size);
bool USBDevice::readEP_NB(uint8_t endpoint, uint8_t * buffer, uint32_t * size, uint32_t maxSize)
EP_STATUS result;
if(!configured()) {
return false;
uint8_t * USBDevice::deviceDesc()
static uint8_t deviceDescriptor[] = {
DEVICE_DESCRIPTOR_LENGTH, /* bLength */
DEVICE_DESCRIPTOR, /* bDescriptorType */
LSB(USB_VERSION_2_0), /* bcdUSB (LSB) */
MSB(USB_VERSION_2_0), /* bcdUSB (MSB) */
0x00, /* bDeviceClass */
0x00, /* bDeviceSubClass */
0x00, /* bDeviceprotocol */
MAX_PACKET_SIZE_EP0, /* bMaxPacketSize0 */
LSB(VENDOR_ID), /* idVendor (LSB) */
MSB(VENDOR_ID), /* idVendor (MSB) */
LSB(PRODUCT_ID), /* idProduct (LSB) */
MSB(PRODUCT_ID), /* idProduct (MSB) */
LSB(PRODUCT_RELEASE), /* bcdDevice (LSB) */
MSB(PRODUCT_RELEASE), /* bcdDevice (MSB) */
STRING_OFFSET_IMANUFACTURER, /* iManufacturer */
STRING_OFFSET_IPRODUCT, /* iProduct */
STRING_OFFSET_ISERIAL, /* iSerialNumber */
0x01 /* bNumConfigurations */
return deviceDescriptor;
uint8_t * USBDevice::stringLangidDesc()
static uint8_t stringLangidDescriptor[] = {
0x04, /*bLength*/
STRING_DESCRIPTOR, /*bDescriptorType 0x03*/
0x09,0x00, /*bString Lang ID - 0x009 - English*/
return stringLangidDescriptor;
uint8_t * USBDevice::stringImanufacturerDesc()
static uint8_t stringImanufacturerDescriptor[] = {
0x12, /*bLength*/
'm',0,'b',0,'e',0,'d',0,'.',0,'o',0,'r',0,'g',0, /*bString iManufacturer - mbed.org*/
return stringImanufacturerDescriptor;
uint8_t * USBDevice::stringIserialDesc()
static uint8_t stringIserialDescriptor[] = {
0x16, /*bLength*/
'0',0,'1',0,'2',0,'3',0,'4',0,'5',0,'6',0,'7',0,'8',0,'9',0, /*bString iSerial - 0123456789*/
return stringIserialDescriptor;
uint8_t * USBDevice::stringIConfigurationDesc()
static uint8_t stringIconfigurationDescriptor[] = {
0x06, /*bLength*/
'0',0,'1',0, /*bString iConfiguration - 01*/
return stringIconfigurationDescriptor;
uint8_t * USBDevice::stringIinterfaceDesc()
static uint8_t stringIinterfaceDescriptor[] = {
0x08, /*bLength*/
'U',0,'S',0,'B',0, /*bString iInterface - USB*/
return stringIinterfaceDescriptor;
uint8_t * USBDevice::stringIproductDesc()
static uint8_t stringIproductDescriptor[] = {
0x16, /*bLength*/
'U',0,'S',0,'B',0,' ',0,'D',0,'E',0,'V',0,'I',0,'C',0,'E',0 /*bString iProduct - USB DEVICE*/
return stringIproductDescriptor;
Dear all,
In our project we are currently using the USBHID library as can be found here https://mbed.org/handbook/USBHID, to communicate with an Android device.
It should be easy to just disable/remove these printf statements. The file is even prepared to do so by commenting line 10. However when I disable the printf statements this ruins the HID communication. I tried in different ways to get rid of these printfs in this file but all ways introduce the same trouble. So it only works with the printf statements in place. I am breaking my head about this as the printf statements shouldn't influence functionality of the USB HID library but they do?
Here is the file:
USBDevice.cpp
/* Copyright (c) 2010-2011 mbed.org, MIT License */ #include "stdint.h" #include "USBEndpoints.h" #include "USBDevice.h" #include "USBDescriptor.h" #define DEBUG //print debug messages /* Device status */ #define DEVICE_STATUS_SELF_POWERED (1U<<0) #define DEVICE_STATUS_REMOTE_WAKEUP (1U<<1) /* Endpoint status */ #define ENDPOINT_STATUS_HALT (1U<<0) /* Standard feature selectors */ #define DEVICE_REMOTE_WAKEUP (1) #define ENDPOINT_HALT (0) /* Macro to convert wIndex endpoint number to physical endpoint number */ #define WINDEX_TO_PHYSICAL(endpoint) (((endpoint & 0x0f) << 1) + \ ((endpoint & 0x80) ? 1 : 0)) bool USBDevice::requestGetDescriptor(void) { bool success = false; #ifdef DEBUG printf("get descr: type: %d\r\n", DESCRIPTOR_TYPE(transfer.setup.wValue)); #endif switch (DESCRIPTOR_TYPE(transfer.setup.wValue)) { case DEVICE_DESCRIPTOR: if (deviceDesc() != NULL) { if ((deviceDesc()[0] == DEVICE_DESCRIPTOR_LENGTH) \ && (deviceDesc()[1] == DEVICE_DESCRIPTOR)) { #ifdef DEBUG printf("device descr\r\n"); #endif transfer.remaining = DEVICE_DESCRIPTOR_LENGTH; transfer.ptr = deviceDesc(); transfer.direction = DEVICE_TO_HOST; success = true; } } break; case CONFIGURATION_DESCRIPTOR: if (configurationDesc() != NULL) { if ((configurationDesc()[0] == CONFIGURATION_DESCRIPTOR_LENGTH) \ && (configurationDesc()[1] == CONFIGURATION_DESCRIPTOR)) { #ifdef DEBUG printf("conf descr request\r\n"); #endif /* Get wTotalLength */ transfer.remaining = configurationDesc()[2] \ | (configurationDesc()[3] << 8); transfer.ptr = configurationDesc(); transfer.direction = DEVICE_TO_HOST; success = true; } } break; case STRING_DESCRIPTOR: #ifdef DEBUG printf("str descriptor\r\n"); #endif switch (DESCRIPTOR_INDEX(transfer.setup.wValue)) { case STRING_OFFSET_LANGID: #ifdef DEBUG printf("1\r\n"); #endif transfer.remaining = stringLangidDesc()[0]; transfer.ptr = stringLangidDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; case STRING_OFFSET_IMANUFACTURER: #ifdef DEBUG printf("2\r\n"); #endif transfer.remaining = stringImanufacturerDesc()[0]; transfer.ptr = stringImanufacturerDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; case STRING_OFFSET_IPRODUCT: #ifdef DEBUG printf("3\r\n"); #endif transfer.remaining = stringIproductDesc()[0]; transfer.ptr = stringIproductDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; case STRING_OFFSET_ISERIAL: #ifdef DEBUG printf("4\r\n"); #endif transfer.remaining = stringIserialDesc()[0]; transfer.ptr = stringIserialDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; case STRING_OFFSET_ICONFIGURATION: #ifdef DEBUG printf("5\r\n"); #endif transfer.remaining = stringIConfigurationDesc()[0]; transfer.ptr = stringIConfigurationDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; case STRING_OFFSET_IINTERFACE: #ifdef DEBUG printf("6\r\n"); #endif transfer.remaining = stringIinterfaceDesc()[0]; transfer.ptr = stringIinterfaceDesc(); transfer.direction = DEVICE_TO_HOST; success = true; break; } break; case INTERFACE_DESCRIPTOR: #ifdef DEBUG printf("interface descr\r\n"); #endif case ENDPOINT_DESCRIPTOR: #ifdef DEBUG printf("endpoint descr\r\n"); #endif /* TODO: Support is optional, not implemented here */ break; default: #ifdef DEBUG printf("ERROR\r\n"); #endif break; } return success; } void USBDevice::decodeSetupPacket(uint8_t *data, SETUP_PACKET *packet) { /* Fill in the elements of a SETUP_PACKET structure from raw data */ packet->bmRequestType.dataTransferDirection = (data[0] & 0x80) >> 7; packet->bmRequestType.Type = (data[0] & 0x60) >> 5; packet->bmRequestType.Recipient = data[0] & 0x1f; packet->bRequest = data[1]; packet->wValue = (data[2] | (uint16_t)data[3] << 8); packet->wIndex = (data[4] | (uint16_t)data[5] << 8); packet->wLength = (data[6] | (uint16_t)data[7] << 8); } bool USBDevice::controlOut2(void) { #ifdef DEBUG printf("ControlOut2\r\n"); #endif /* Control transfer data OUT stage */ uint8_t buffer[MAX_PACKET_SIZE_EP0]; uint32_t packetSize; /* Read from endpoint */ packetSize = EP0getReadResult(buffer); /* Update transfer */ transfer.ptr += packetSize; transfer.remaining -= packetSize; /* Check if transfer has completed */ /* Transfer completed */ // if(transfer.setup.bmRequestType.dataTransferDirection == 0 && transfer.setup.bmRequestType.Type == 1 && transfer.setup.bmRequestType.Recipient == 1 && transfer.setup.bRequest == 9 && transfer.setup.wValue == 512) { USBCallback_dataReceived(buffer,packetSize); // } return true; } bool USBDevice::controlOut(void) { /* Control transfer data OUT stage */ uint8_t buffer[MAX_PACKET_SIZE_EP0]; uint32_t packetSize; /* Check we should be transferring data OUT */ if (transfer.direction != HOST_TO_DEVICE) { return false; } /* Read from endpoint */ packetSize = EP0getReadResult(buffer); /* Check if transfer size is valid */ if (packetSize > transfer.remaining) { /* Too big */ return false; } /* Update transfer */ transfer.ptr += packetSize; transfer.remaining -= packetSize; /* Check if transfer has completed */ if (transfer.remaining == 0) { /* Transfer completed */ if (transfer.notify) { /* Notify class layer. */ USBCallback_requestCompleted(buffer, packetSize); transfer.notify = false; } /* Status stage */ EP0write(NULL, 0); } else { EP0read(); } return true; } bool USBDevice::controlIn(void) { /* Control transfer data IN stage */ uint32_t packetSize; /* Check if transfer has completed (status stage transactions */ /* also have transfer.remaining == 0) */ if (transfer.remaining == 0) { if (transfer.zlp) { /* Send zero length packet */ EP0write(NULL, 0); transfer.zlp = false; } /* Transfer completed */ if (transfer.notify) { /* Notify class layer. */ USBCallback_requestCompleted(NULL, 0); transfer.notify = false; } EP0read(); EP0readStage(); /* Completed */ return true; } /* Check we should be transferring data IN */ if (transfer.direction != DEVICE_TO_HOST) { return false; } packetSize = transfer.remaining; if (packetSize > MAX_PACKET_SIZE_EP0) { packetSize = MAX_PACKET_SIZE_EP0; } /* Write to endpoint */ EP0write(transfer.ptr, packetSize); /* Update transfer */ transfer.ptr += packetSize; transfer.remaining -= packetSize; return true; } bool USBDevice::requestSetAddress(void) { /* Set the device address */ setAddress(transfer.setup.wValue); if (transfer.setup.wValue == 0) { device.state = DEFAULT; } else { device.state = ADDRESS; } return true; } bool USBDevice::requestSetConfiguration(void) { device.configuration = transfer.setup.wValue; /* Set the device configuration */ if (device.configuration == 0) { /* Not configured */ unconfigureDevice(); device.state = ADDRESS; } else { if (USBCallback_setConfiguration(device.configuration)) { /* Valid configuration */ configureDevice(); device.state = CONFIGURED; } else { return false; } } return true; } bool USBDevice::requestGetConfiguration(void) { /* Send the device configuration */ transfer.ptr = &device.configuration; transfer.remaining = sizeof(device.configuration); transfer.direction = DEVICE_TO_HOST; return true; } bool USBDevice::requestGetInterface(void) { /* Return the selected alternate setting for an interface */ if (device.state != CONFIGURED) { return false; } /* Send the alternate setting */ transfer.setup.wIndex = currentInterface; transfer.ptr = ¤tAlternate; transfer.remaining = sizeof(currentAlternate); transfer.direction = DEVICE_TO_HOST; return true; } bool USBDevice::requestSetInterface(void) { bool success = false; if(USBCallback_setInterface(transfer.setup.wIndex, transfer.setup.wValue)) { success = true; currentInterface = transfer.setup.wIndex; currentAlternate = transfer.setup.wValue; } return success; } bool USBDevice::requestSetFeature() { bool success = false; if (device.state != CONFIGURED) { /* Endpoint or interface must be zero */ if (transfer.setup.wIndex != 0) { return false; } } switch (transfer.setup.bmRequestType.Recipient) { case DEVICE_RECIPIENT: /* TODO: Remote wakeup feature not supported */ break; case ENDPOINT_RECIPIENT: if (transfer.setup.wValue == ENDPOINT_HALT) { /* TODO: We should check that the endpoint number is valid */ stallEndpoint( WINDEX_TO_PHYSICAL(transfer.setup.wIndex)); success = true; } break; default: break; } return success; } bool USBDevice::requestClearFeature() { bool success = false; if (device.state != CONFIGURED) { /* Endpoint or interface must be zero */ if (transfer.setup.wIndex != 0) { return false; } } switch (transfer.setup.bmRequestType.Recipient) { case DEVICE_RECIPIENT: /* TODO: Remote wakeup feature not supported */ break; case ENDPOINT_RECIPIENT: /* TODO: We should check that the endpoint number is valid */ if (transfer.setup.wValue == ENDPOINT_HALT) { unstallEndpoint( WINDEX_TO_PHYSICAL(transfer.setup.wIndex)); success = true; } break; default: break; } return success; } bool USBDevice::requestGetStatus(void) { static uint16_t status; bool success = false; if (device.state != CONFIGURED) { /* Endpoint or interface must be zero */ if (transfer.setup.wIndex != 0) { return false; } } switch (transfer.setup.bmRequestType.Recipient) { case DEVICE_RECIPIENT: /* TODO: Currently only supports self powered devices */ status = DEVICE_STATUS_SELF_POWERED; success = true; break; case INTERFACE_RECIPIENT: status = 0; success = true; break; case ENDPOINT_RECIPIENT: /* TODO: We should check that the endpoint number is valid */ if (getEndpointStallState( WINDEX_TO_PHYSICAL(transfer.setup.wIndex))) { status = ENDPOINT_STATUS_HALT; } else { status = 0; } success = true; break; default: break; } if (success) { /* Send the status */ transfer.ptr = (uint8_t *)&status; /* Assumes little endian */ transfer.remaining = sizeof(status); transfer.direction = DEVICE_TO_HOST; } return success; } bool USBDevice::requestSetup(void) { bool success = false; /* Process standard requests */ if ((transfer.setup.bmRequestType.Type == STANDARD_TYPE)) { switch (transfer.setup.bRequest) { case GET_STATUS: success = requestGetStatus(); break; case CLEAR_FEATURE: success = requestClearFeature(); break; case SET_FEATURE: success = requestSetFeature(); break; case SET_ADDRESS: success = requestSetAddress(); break; case GET_DESCRIPTOR: success = requestGetDescriptor(); break; case SET_DESCRIPTOR: /* TODO: Support is optional, not implemented here */ success = false; break; case GET_CONFIGURATION: success = requestGetConfiguration(); break; case SET_CONFIGURATION: success = requestSetConfiguration(); break; case GET_INTERFACE: success = requestGetInterface(); break; case SET_INTERFACE: success = requestSetInterface(); break; default: break; } } return success; } bool USBDevice::controlSetup(void) { bool success = false; /* Control transfer setup stage */ uint8_t buffer[MAX_PACKET_SIZE_EP0]; EP0setup(buffer); /* Initialise control transfer state */ decodeSetupPacket(buffer, &transfer.setup); transfer.ptr = NULL; transfer.remaining = 0; transfer.direction = 0; transfer.zlp = false; transfer.notify = false; #ifdef DEBUG printf("dataTransferDirection: %d\r\nType: %d\r\nRecipient: %d\r\nbRequest: %d\r\nwValue: %d\r\nwIndex: %d\r\nwLength: %d\r\n",transfer.setup.bmRequestType.dataTransferDirection, transfer.setup.bmRequestType.Type, transfer.setup.bmRequestType.Recipient, transfer.setup.bRequest, transfer.setup.wValue, transfer.setup.wIndex, transfer.setup.wLength); #endif if(transfer.setup.bmRequestType.dataTransferDirection == 0 && transfer.setup.bmRequestType.Type == 1 && transfer.setup.bmRequestType.Recipient == 1 && transfer.setup.bRequest == 9 && transfer.setup.wValue == 512) { controlOut2(); } /* Class / vendor specific */ success = USBCallback_request(); if (!success) { /* Standard requests */ if (!requestSetup()) { #ifdef DEBUG printf("fail!!!!\r\n"); #endif return false; } } /* Check transfer size and direction */ if (transfer.setup.wLength>0) { if (transfer.setup.bmRequestType.dataTransferDirection \ == DEVICE_TO_HOST) { /* IN data stage is required */ if (transfer.direction != DEVICE_TO_HOST) { return false; } /* Transfer must be less than or equal to the size */ /* requested by the host */ if (transfer.remaining > transfer.setup.wLength) { transfer.remaining = transfer.setup.wLength; } } else { /* OUT data stage is required */ if (transfer.direction != HOST_TO_DEVICE) { return false; } /* Transfer must be equal to the size requested by the host */ if (transfer.remaining != transfer.setup.wLength) { return false; } } } else { /* No data stage; transfer size must be zero */ if (transfer.remaining != 0) { return false; } } /* Data or status stage if applicable */ if (transfer.setup.wLength>0) { if (transfer.setup.bmRequestType.dataTransferDirection \ == DEVICE_TO_HOST) { /* Check if we'll need to send a zero length packet at */ /* the end of this transfer */ if (transfer.setup.wLength > transfer.remaining) { /* Device wishes to transfer less than host requested */ if ((transfer.remaining % MAX_PACKET_SIZE_EP0) == 0) { /* Transfer is a multiple of EP0 max packet size */ transfer.zlp = true; } } #ifdef DEBUG printf("CONTROLIN!!!!\r\n"); #endif /* IN stage */ controlIn(); } else { #ifdef DEBUG printf("EPOREAD!!!\r\n"); #endif /* OUT stage */ EP0read(); } } else { #ifdef DEBUG printf("EP0WRITE!!!!\r\n"); #endif /* Status stage */ EP0write(NULL, 0); } return true; } void USBDevice::busReset(void) { device.state = DEFAULT; device.configuration = 0; device.suspended = false; /* Call class / vendor specific busReset function */ USBCallback_busReset(); } void USBDevice::EP0setupCallback(void) { /* Endpoint 0 setup event */ if (!controlSetup()) { /* Protocol stall */ EP0stall(); } /* Return true if an OUT data stage is expected */ } void USBDevice::EP0out(void) { /* Endpoint 0 OUT data event */ if (!controlOut()) { /* Protocol stall; this will stall both endpoints */ EP0stall(); } } void USBDevice::EP0in(void) { #ifdef DEBUG printf("EP0IN\r\n"); #endif /* Endpoint 0 IN data event */ if (!controlIn()) { /* Protocol stall; this will stall both endpoints */ EP0stall(); } } bool USBDevice::configured(void) { /* Returns true if device is in the CONFIGURED state */ return (device.state == CONFIGURED); } void USBDevice::connect(void) { /* Connect device */ USBHAL::connect(); /* Block if not configured */ while (!configured()); } void USBDevice::disconnect(void) { /* Disconnect device */ USBHAL::disconnect(); } CONTROL_TRANSFER * USBDevice::getTransferPtr(void) { return &transfer; } bool USBDevice::addEndpoint(uint8_t endpoint, uint32_t maxPacket) { return realiseEndpoint(endpoint, maxPacket, 0); } bool USBDevice::addRateFeedbackEndpoint(uint8_t endpoint, uint32_t maxPacket) { /* For interrupt endpoints only */ return realiseEndpoint(endpoint, maxPacket, RATE_FEEDBACK_MODE); } uint8_t * USBDevice::findDescriptor(uint8_t descriptorType) { /* Find a descriptor within the list of descriptors */ /* following a configuration descriptor. */ uint16_t wTotalLength; uint8_t *ptr; if (configurationDesc() == NULL) { return NULL; } /* Check this is a configuration descriptor */ if ((configurationDesc()[0] != CONFIGURATION_DESCRIPTOR_LENGTH) \ || (configurationDesc()[1] != CONFIGURATION_DESCRIPTOR)) { return NULL; } wTotalLength = configurationDesc()[2] | (configurationDesc()[3] << 8); /* Check there are some more descriptors to follow */ if (wTotalLength <= (CONFIGURATION_DESCRIPTOR_LENGTH+2)) /* +2 is for bLength and bDescriptorType of next descriptor */ { return false; } /* Start at first descriptor after the configuration descriptor */ ptr = &(configurationDesc()[CONFIGURATION_DESCRIPTOR_LENGTH]); do { if (ptr[1] /* bDescriptorType */ == descriptorType) { /* Found */ return ptr; } /* Skip to next descriptor */ ptr += ptr[0]; /* bLength */ } while (ptr < (configurationDesc() + wTotalLength)); /* Reached end of the descriptors - not found */ return NULL; } void USBDevice::connectStateChanged(unsigned int connected) { } void USBDevice::suspendStateChanged(unsigned int suspended) { } USBDevice::USBDevice(uint16_t vendor_id, uint16_t product_id, uint16_t product_release) { VENDOR_ID = vendor_id; PRODUCT_ID = product_id; PRODUCT_RELEASE = product_release; /* Set initial device state */ device.state = POWERED; device.configuration = 0; device.suspended = false; }; bool USBDevice::readStart(uint8_t endpoint, uint32_t maxSize) { return endpointRead(endpoint, maxSize) == EP_PENDING; } bool USBDevice::write(uint8_t endpoint, uint8_t * buffer, uint32_t size, uint32_t maxSize) { EP_STATUS result; if (size > maxSize) { return false; } if(!configured()) { return false; } /* Send report */ result = endpointWrite(endpoint, buffer, size); if (result != EP_PENDING) { return false; } /* Wait for completion */ do { result = endpointWriteResult(endpoint); } while ((result == EP_PENDING) && configured()); return (result == EP_COMPLETED); } bool USBDevice::writeNB(uint8_t endpoint, uint8_t * buffer, uint32_t size, uint32_t maxSize) { EP_STATUS result; if (size > maxSize) { return false; } if(!configured()) { return false; } /* Send report */ result = endpointWrite(endpoint, buffer, size); if (result != EP_PENDING) { return false; } result = endpointWriteResult(endpoint); return (result == EP_COMPLETED); } bool USBDevice::readEP(uint8_t endpoint, uint8_t * buffer, uint32_t * size, uint32_t maxSize) { EP_STATUS result; if(!configured()) { return false; } /* Wait for completion */ do { result = endpointReadResult(endpoint, buffer, size); } while ((result == EP_PENDING) && configured()); return (result == EP_COMPLETED); } bool USBDevice::readEP_NB(uint8_t endpoint, uint8_t * buffer, uint32_t * size, uint32_t maxSize) { EP_STATUS result; if(!configured()) { return false; } result = endpointReadResult(endpoint, buffer, size); return (result == EP_COMPLETED); } uint8_t * USBDevice::deviceDesc() { static uint8_t deviceDescriptor[] = { DEVICE_DESCRIPTOR_LENGTH, /* bLength */ DEVICE_DESCRIPTOR, /* bDescriptorType */ LSB(USB_VERSION_2_0), /* bcdUSB (LSB) */ MSB(USB_VERSION_2_0), /* bcdUSB (MSB) */ 0x00, /* bDeviceClass */ 0x00, /* bDeviceSubClass */ 0x00, /* bDeviceprotocol */ MAX_PACKET_SIZE_EP0, /* bMaxPacketSize0 */ LSB(VENDOR_ID), /* idVendor (LSB) */ MSB(VENDOR_ID), /* idVendor (MSB) */ LSB(PRODUCT_ID), /* idProduct (LSB) */ MSB(PRODUCT_ID), /* idProduct (MSB) */ LSB(PRODUCT_RELEASE), /* bcdDevice (LSB) */ MSB(PRODUCT_RELEASE), /* bcdDevice (MSB) */ STRING_OFFSET_IMANUFACTURER, /* iManufacturer */ STRING_OFFSET_IPRODUCT, /* iProduct */ STRING_OFFSET_ISERIAL, /* iSerialNumber */ 0x01 /* bNumConfigurations */ }; return deviceDescriptor; } uint8_t * USBDevice::stringLangidDesc() { static uint8_t stringLangidDescriptor[] = { 0x04, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ 0x09,0x00, /*bString Lang ID - 0x009 - English*/ }; return stringLangidDescriptor; } uint8_t * USBDevice::stringImanufacturerDesc() { static uint8_t stringImanufacturerDescriptor[] = { 0x12, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ 'm',0,'b',0,'e',0,'d',0,'.',0,'o',0,'r',0,'g',0, /*bString iManufacturer - mbed.org*/ }; return stringImanufacturerDescriptor; } uint8_t * USBDevice::stringIserialDesc() { static uint8_t stringIserialDescriptor[] = { 0x16, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ '0',0,'1',0,'2',0,'3',0,'4',0,'5',0,'6',0,'7',0,'8',0,'9',0, /*bString iSerial - 0123456789*/ }; return stringIserialDescriptor; } uint8_t * USBDevice::stringIConfigurationDesc() { static uint8_t stringIconfigurationDescriptor[] = { 0x06, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ '0',0,'1',0, /*bString iConfiguration - 01*/ }; return stringIconfigurationDescriptor; } uint8_t * USBDevice::stringIinterfaceDesc() { static uint8_t stringIinterfaceDescriptor[] = { 0x08, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ 'U',0,'S',0,'B',0, /*bString iInterface - USB*/ }; return stringIinterfaceDescriptor; } uint8_t * USBDevice::stringIproductDesc() { static uint8_t stringIproductDescriptor[] = { 0x16, /*bLength*/ STRING_DESCRIPTOR, /*bDescriptorType 0x03*/ 'U',0,'S',0,'B',0,' ',0,'D',0,'E',0,'V',0,'I',0,'C',0,'E',0 /*bString iProduct - USB DEVICE*/ }; return stringIproductDescriptor; }
