Hi all,
It is my understanding that macros are done by the pre-processor, so if you declare a macro in the main() it should be useable in other header files. I have a program which exhibits some strange behaviour that seems to contradict this. I've stripped it down to the bare basics. The program is below:
In main.c:
//#define USE_RTC
#include "DataLog.h"
DataLog d;
d.StartLogging();
__wfi();
In DataLog.h:
#ifndef DATA_LOG_H
#define DATA_LOG_H
class DataLog
public:
void StartLogging(void);
protected:
void Log(void);
char FileName[256];
#ifndef USE_RTC
Ticker SampleTimer;
#endif
void CheckIfDefined(void)
#ifndef USE_RTC
fprintf(stderr, "USE_RTC not defined in h\n");
#else
fprintf(stderr, "USE_RTC is defined in h\n");
#endif
#endif
In DataLog.cpp
void DataLog::StartLogging(void)
#ifndef USE_RTC
SampleTimer.attach(this, &DataLog::Log, 1);
fprintf(stderr, "USE_RTC not defined in cpp\n");
#else
fprintf(stderr, "USE_RTC is defined in cpp\n");
#endif
CheckIfDefined();
void DataLog::Log(void)
fprintf(stderr, "Logging\n");
When USE_RTC isn't defined in the main, the program writes the following to the terminal:
and then starts calling DataLog::Log() every second. This is what I would expect to see. If however, USE_RTC is defined in main (comments removed), the program writes the same message to the terminal, i.e.:
but doesn't start logging. So it is doing the fprintfs like USE_RTC is not defined, but behaving like USE_RTC is defined.
This is adding highly unpredictable behaviour to the code. For example, if you comment out the definition of FileName and run the code with USE_RTC defined, nothing gets written to the terminal; the program just hangs.
Please could someone explain what is going on?
Thanks
Tim
Hi all,
In main.c:
#include "mbed.h" //#define USE_RTC #include "DataLog.h" DataLog d; int main() { d.StartLogging(); while(1) { __wfi(); } }In DataLog.h:
#include "mbed.h" #ifndef DATA_LOG_H #define DATA_LOG_H class DataLog { public: void StartLogging(void); protected: void Log(void); char FileName[256]; #ifndef USE_RTC Ticker SampleTimer; #endif void CheckIfDefined(void) { #ifndef USE_RTC fprintf(stderr, "USE_RTC not defined in h\n"); #else fprintf(stderr, "USE_RTC is defined in h\n"); #endif } }; #endifIn DataLog.cpp
#include "mbed.h" #include "DataLog.h" void DataLog::StartLogging(void) { #ifndef USE_RTC SampleTimer.attach(this, &DataLog::Log, 1); fprintf(stderr, "USE_RTC not defined in cpp\n"); #else fprintf(stderr, "USE_RTC is defined in cpp\n"); #endif CheckIfDefined(); }; void DataLog::Log(void) { fprintf(stderr, "Logging\n"); };When USE_RTC isn't defined in the main, the program writes the following to the terminal:
Thanks Tim
