Hi all,
I have recently asked about setting up a program to measure the length of a pulse signal and was pointed in the direction of some other peoples codes they had put together. After looking through them and attempting to get them working I am still struggling. The sensor I have ( http://www.maxbotix.com/documents/MB7060-MB7070_Datasheet.pdf ) gives out a pulse according to distance measured (58us per cm ). I have imported a program and tried to get it going. I have changed the trigger signal form 10us to 25us as the data sheet stated a minimum of 20us so I went for 25 to be safe. The data sheet also states that pin 4 is used for the trigger signal but I don't know what output from the microcontroller would do this. I am unsure about setting up the pins for the sensor to the microcontroller. The way its named in the code makes it a bit confusing for me (sorry i'm a bit of a novice when it comes to this). Also the existing program is set up for a different type of sensor but I was informed it should operate ok for mine as it is just measuring pulse duration. This is what I have:
#include "mbed.h" #include "Terminal.h" #include "HCSR04.h" HCSR04::HCSR04(PinName 9, PinName 10) : trig(t), echo(e) {} // Trigger Echo // _______ _____________,,,,,,,,, // ____| 25us |_________| 150us-25ms, or 38ms if no obstacle // //return echo duration in us (refer to digram above) long HCSR04::echo_duration() { timer.reset(); trig = 0; wait_us(2); trig = 1; wait_us(25); trig = 0; while(echo == 0); timer.start(); while(echo == 1); timer.stop(); return timer.read_us(); } //return distance to nearest obstacle or returns -1 //if no obstacle within range //set sys to cm or inch accordingly long HCSR04::distance(int sys){ duration = echo_duration(); if(duration > 30000) return -1; distacne_cm = duration /29 / 2 ; distance_inc = duration / 74 / 2; if (sys) return distacne_cm; else return distance_inc; } int main() { U while(1){ long distance = sensor.distance(CM); term.printf("Distance:%d\n"); wait(0.1); } }>>If anyone could give me some help it would be greatly appreciated as I am currently pulling my hair out!
Many Thanks
