OneWire CMSIS incompatibility
01 Jul 2013
CMSIS target isn't defined for the Kl25z, I dont understand what is the work out for this problem?
// DS18B20 converted to run on mbed
#define TEMP_PIN  PTC9
DigitalInOut temperature_pin(TEMP_PIN);
void OneWireReset() { // reset.  Should improve to act as a presence pulse
    temperature_pin.output();
    temperature_pin = 0;     // bring low for 500 us
    wait_us(500);
    temperature_pin.input();
    wait_us(500);
void OneWireOutByte(unsigned char d) { // output byte d (least sig bit first).
    for(int n=8; n!=0; n--) {
        if ((d & 0x01) == 1) { // test least sig bit
            wait_us(5);
            wait_us(60);
        } else {
            wait_us(60);
        d=d>>1; // now the next bit is in the least sig bit position.
unsigned char OneWireInByte() { // read byte, least sig byte first
    unsigned char d = 0, b;
    for (int n=0; n<8; n++) {
        wait_us(5);
        wait_us(5);
        b = temperature_pin;
        wait_us(50);
        d = (d >> 1) | (b << 7); // shift d to right and insert b in most sig bit position
    return d;
    int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
    pc.printf("mbed 1 wire interface simple test!\r\n");
    temperature_pin.input();  // sets the digital pin as input (logic 1) make sure external pullup resistor 4K7
    wait(1);
    pc.printf("temperature measurements:\r\n");
    while (1) {
        OneWireReset();
        OneWireOutByte( 0xcc);  //Skip ROM command
        OneWireOutByte( 0x44); // perform temperature conversion, strong pullup for one sec
        OneWireReset();
        OneWireOutByte( 0xbe);   //Read Scratchpad
        LowByte = OneWireInByte();
        HighByte = OneWireInByte();
        TReading = (HighByte << 8) + LowByte;
        SignBit = TReading & 0x8000;  // test most sig bit
        if (SignBit) { // negative
            TReading = (TReading ^ 0xffff) + 1; // 2's comp
        Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
        Whole = Tc_100 / 100;  // separate off the whole and fractional portions
        Fract = Tc_100 % 100;
        if (SignBit) { // If its negative
            pc.printf("-");
        pc.printf("%d", Whole);
        pc.printf(".");
        if (Fract < 10) {
            pc.printf("0");
        pc.printf("%d", Fract);
        pc.printf("\r\n");
        wait(5);         // 5 second delay.  Adjust as necessary
01 Jul 2013
I think there is nothing specialised done that would complicate stuff ,just some regular bit shifting in and out and for that also inbuilt functions are made and no external library is used!
