I have a distance of 6cm between mbed and the energy measurement chip. It's soldered in a PCB. I'm making right now a new design to test with a distance of only 1cm.
The accepted values for the SPI communication at ADE7758 need to be between 5MHZ and 15MHZ, as you can see at page 5 of the ADE7758 datasheet available at http://www.analog.com/static/imported-files/data_sheets/ADE7758.pdf .
I'm testing in this PCB the code below and I only start to get the right values after 50 reads. If I updated the mbed file to read a new register, it gives the right value but if I turn the mbed off and 15 minutes start the mbed again, it gives me 0xFF. After 50 reads or more it gives again the right value.
- include "mbed.h"
SPI spi(p5, p6, p7);  mosi, miso, sclk
DigitalOut cs(p8);
uint8_t packet[9];
Serial pc(USBTX, USBRX);
/* Configuração MBED*/
DigitalOut led1(LED1);
DigitalOut led2(LED2);
DigitalOut led3(LED3);
DigitalOut led4(LED4);
     register name address length
read only register
- define REACTIVE_A 0x01 16 Watt-Hour Accumulation Register for Phase A
 - define REACTIVE_B 0x02 16 Watt-Hour Accumulation Register for Phase B
 - define REACTIVE_C 0x03 16 Watt-Hour Accumulation Register for Phase C
- define AVARHR 0x04 16 Var-Hour accumulation register for phase A
 - define BVARHR 0x05 16 Var-Hour accumulation register for phase b
 - define CVARHR 0x06 16 Var-Hour accumulation register for phase c
Timer timeout;
bool timed_out;
    uint8_t status_byte = 0x00;
    timeout.start(); start the timeout timer
    while (1) {
        try the 4 available modes to see if it will work
   for(int mode = 0; mode < 3; mode++) {
            spi.format(8, mode);
            spi.frequency(10000000);  10MHz on sck
            cs = 0;
            led1 = 1;
            printf("Testing Command in SPI Mode %d\r\n", mode);
                spi.write(0x17); send command byte
                wait(0.01);
            timeout.reset(); reset the timeout to wait for reply for 2 seconds
            timed_out = false;
            wait for the status byte
            while (status_byte == 0x00) {
                status_byte = spi.write(0x00);
                wait(0.01);
                waited too long timeout
                if (timeout.read_ms() > 1000) {
                    timed_out = true;
                    break;
            if (!timed_out) {
                packet[0] = status_byte;
                have the status (should check it really)
                get the rest of the packet
                for (int i=1; i<5; i++) {
                    packet[i] = spi.write(0x00);
                output the packet
                for (int i=0; i<5; i++) {
                    printf("%02X ", packet[i]); output the bytes in hex format on one line
                printf("\r\n");
            } else {
                printf("Command timeout..\r\n");
            cs = 1;  must raise cs between commands but after the reply
            led1 = 0;
            wait(0.5);
Regards
Currently I have my mbed connected to an energy measurement chip ADE7758 that uses SPI to communicate the energy data, but the problem is that this chip uses a clock oscillator of 10MHz and mbed is using only 4MHz. I tried to change the spi.frequency on the mbed to 10MHz but the energy chip doesn't receive the full data as I could verify on the oscilloscope.
How I can change the mbed internal oscillator do start using 10MHz on the SPI communication?
Here is the code that I'm using:
#include "mbed.h" SPI spi(p5, p6, p7); // mosi, miso, sclk DigitalOut cs(p8); uint8_t packet[9]; Serial pc(USBTX, USBRX); /* Configuração MBED*/ DigitalOut led1(LED1); DigitalOut led2(LED2); DigitalOut led3(LED3); DigitalOut led4(LED4); // ************************************** // register name address length // ************************************** //read only register #define REACTIVE_A 0x01 //16 Watt-Hour Accumulation Register for Phase A #define REACTIVE_B 0x02 //16 Watt-Hour Accumulation Register for Phase B #define REACTIVE_C 0x03 //16 Watt-Hour Accumulation Register for Phase C #define AVARHR 0x04 //16 Var-Hour accumulation register for phase A #define BVARHR 0x05 //16 Var-Hour accumulation register for phase b #define CVARHR 0x06 //16 Var-Hour accumulation register for phase c Timer timeout; bool timed_out; int main() { uint8_t status_byte = 0x00; timeout.start(); //start the timeout timer while (1) { //try the 4 available modes to see if it will work for(int mode = 0; mode < 3; mode++) { spi.format(8, mode); spi.frequency(10000000); // 10MHz on sck cs = 0; led1 = 1; printf("Testing Command in SPI Mode %d\r\n", mode); spi.write(0x17); //send command byte wait(0.01); timeout.reset(); //reset the timeout to wait for reply for 2 seconds timed_out = false; //wait for the status byte while (status_byte == 0x00) { status_byte = spi.write(0x00); wait(0.01); //waited too long timeout if (timeout.read_ms() > 1000) { timed_out = true; break; } } if (!timed_out) { packet[0] = status_byte; //have the status (should check it really) //get the rest of the packet for (int i=1; i<5; i++) { packet[i] = spi.write(0x00); } //output the packet for (int i=0; i<5; i++) { printf("%02X ", packet[i]); //output the bytes in hex format on one line } printf("\r\n"); } else { printf("Command timeout..\r\n"); } cs = 1; // must raise cs between commands but after the reply led1 = 0; wait(0.5); } } }
