Dear all,
I am trying to use MODSERIAL (https://mbed.org/cookbook/MODSERIAL) in my program. This program used to compile, but when I import the MODSERIAL library and make the required adjustments I get the following error and therefore it won't compile properly:
Compiler Output Error:
Quote:
cannot open source input file "serial_api.h": No such file or directory
I also tried it with the very simple example provided:
#include "MODSERIAL.h"
MODSERIAL pc(USBTX, USBRX); // tx, rx
pc.printf("Hello World!");
pc.putc(pc.getc() + 1);
but this gives me exactly the same result.
The error explanation states that this could mean that the default mbed library is accidentaly removed. But this isn't the case.
Furthermore I have looked for an additional library called 'serial_api' that I might needed to import but I couldn't find anything.
What did I miss to import and use the MODSERIAL library properly?
Much thanks in advance
p.s. I also posted this under the section 'question'. I am not sure where it is placed best.
Dear all,
#include "mbed.h" #include "MODSERIAL.h" MODSERIAL pc(USBTX, USBRX); // tx, rx int main() { pc.printf("Hello World!"); while(1) { pc.putc(pc.getc() + 1); } }but this gives me exactly the same result.
