AX12 set float angle
05 Nov 2012
I would like to set a float angle on servo AX12. I'm using the this lib:
http://mbed.org/users/chris/code/AX12/docs/tip/classAX12.html.
Someone know if this is possible? If yes, how I can do that?
05 Nov 2012
The library expects an int for the target position
int SetGoal (int degrees, int flags=0)
So you would have to hack the library or cast the float to an int
Martin
