Serial object and DI/O object on same pins
05 Oct 2012
For reasons I won't get in to, I need to have a DI/O and serial object share some of the same pins (the tx pin on the serial port). I know I could probably make this work by destroying the old object and creating a new one each time control needs to switch, but because of data stored in the class I have that inherits Serial that is not a practical solution.
I assume the settings for the crossbar/pin multiplex registers are written in the constructors for the DI/O and Serial objects. So would it work to go in myself and write the proper bits to those registers when I wanted to switch control? I would obviously make sure that the "dormant" object would not try to access its pins until it is "active" again.
Has anyone done/had to deal with something like this? Any easy solutions?
Thanks a ton for any help.
