Hi. I'm using a SRAM memory that runs 23k256 SPI communication and I have some communication problems at the time of writing and reading data. I made a test program that first order type multiple characters and then reads them and sends them via USB to PC, I visualize the characters with TERA TERM program and see that several characters do not match those that mainly have written. That's a problem because the application memory I can not have many failures of writing and reading. Food memory with the power supply of 3.3 V of mbed, and one SCK-SCK, MOSI-MOSI, MISO WITH MISO. I leave the program code in a txt document. have if someone sees a flaw in the program I use or otherwise is not the fault code and can come from elsewhere. Greetings.
/media/uploads/ddobano/sram23k256.txt
