I'm using the MBED as part of the m3pi setup. It communicates with the 3pi robot base, a WiFly wireless UART bridge, and an Arduino acting as a sensor coprocessor. Since the USB UART isn't broken out, that means I need to use all three of the other available UARTS. UART3 is hardwired into the 3pi.
My communications implementation is based on a state machine that operates asynchronously inside uart Rx interrupts. This works perfectly fine on UART1. However, on UART2, the RxIRQ is never fired. Code excerpts:
//UART device to communicate on (m3pi uses 9 and 10 aka UART3)
MODSERIAL _wifly(p28, p27); //UART2
void wifly_input_handler(MODSERIAL_IRQ_INFO *q) {
char c;
led2=~led2;
//While we can get a character and we're still getting a command...
while (!cur_command.complete) {
while(!_wifly.readable()){}
c=_wifly.getc();
switch (cur_command.type) { //Command recognizer state machine
case command_t::COM_CLEAR: //Only case where state may be switched in this function
switch (c) { //Command state transition block
case 'M':
cur_command.type=command_t::COM_MOTOR_LR;
cur_command.counter=0;
break;
case 'm':
cur_command.type=command_t::COM_MOTOR_VW;
break;
case 'V':
cur_command.type=command_t::COM_VERSION;
cur_command.complete=1; //Only need 1 char to recognize
break;
case 'K':
cur_command.type=command_t::COM_ECHO_SEN;
break;
case 'Q':
cur_command.type=command_t::COM_CONN_OPEN;
break;
case 'R':
cur_command.type=command_t::COM_CONN_CLOSE;
break;
default: //Character is not in protocol
cur_command.type=command_t::COM_CLEAR; //Reset state
cur_command.complete=0;
break;
break; //End of CLEAR case
case command_t::COM_MOTOR_LR: //Recieving motor command specifiers
cur_command.content.lrd[cur_command.counter]=(signed char)c;
cur_command.counter++;
if (cur_command.counter==3) { //If we've recieved all 3 chars...
cur_command.complete=1; //We're done
break;
case command_t::COM_MOTOR_VW:
cur_command.content.vwd[cur_command.counter]=(signed char)c;
break;
default: //Something has gone wrong
cur_command.complete=0; //Reset recognizer state
break;
void wifly_output_handler( MODSERIAL_IRQ_INFO *q) {
__disable_irq();
static int _sbuff_out=0;
if (connection_ok) { //Only if there is an open connection
//_sbuff_out = cinc(_sbuff_out, BUFFER_SIZE-1);
int sbuff_in_local_copy = _sbuff_in;
static char c[3];
m3pi.locate(0, 1);
c[1] = sbuff_in_local_copy % 10 + '0';
c[0] = (sbuff_in_local_copy / 10 ) % 10 + '0';
m3pi.print(c, 2);
m3pi.locate(3, 1);
c[1] = _sbuff_out % 10 + '0';
c[0] = (_sbuff_out / 10 ) % 10 + '0';
m3pi.print(c, 2);
if(_sbuff_out != sbuff_in_local_copy){
while (_sbuff_out != sbuff_in_local_copy) {
_wifly.putc(g_output_buff[_sbuff_out]);
g_output_buff[_sbuff_out] = 0;
_sbuff_out=cinc(_sbuff_out, BUFFER_SIZE-1);
} else {
_wifly.putc(0); //Well don't know how else to do it
__enable_irq();
//Utility to set motor speeds to 0. Ends current command after its duration expires.
void m3pi_nullmotors(void) {
m3pi.stop();
void main(void){
_wifly.attach(&wifly_input_handler, MODSERIAL::RxIrq);
_wifly.attach(&wifly_output_handler, MODSERIAL::TxIrq);
while(1){
led1=connection_ok;
I'm using MODSERIAL here because the standard serial class wasn't working; MODSERIAL also doesn't work and shows the same results.
Is there anything that's particularly different about UART2 that makes its ISRs not work?
Thanks!
Thanks!
