I am working around with the LCD TFT from MikroElektronika. I want to fire up an interupt when the user is touching the screen. I am not sure if it is possible because the pins are analog?
Another solution would be to use threat and an RTOS I suppose. However, I am using the LPC11u24 and it looks like it does not work.
So, basically, I have 2 questions:
Quote:
1- Can I use interrupt on analog pins?
Quote:
2- is the RTOS supposed to work with the LPC11u24?
The touchscreen works fine.
thanks.
