Well, I spent a few hours fighting this function...
All I want to do is read the directory from an SD card and display a list of files with their sizes and time and date information.
I am using the opendir() function and then readdir("/sd") which gives, each time it is called, only a pointer to the current filename (or directoryname when present) and no attributes.
In FatDirHandle.cpp I see that the fileinfo is read in but only used to get access to the long filename. How do I get access to the other fileinfo from my program?
For testing I added a printf in FatDirHandle to show the available fileinfo:
struct dirent *FATDirHandle::readdir() {
FILINFO finfo;
#if _USE_LFN
finfo.lfname = cur_entry.d_name;
finfo.lfsize = sizeof(cur_entry.d_name);
#endif // _USE_LFN
FRESULT res = f_readdir(&dir, &finfo);
printf("File %s filesize: %d attribute %02x\n\r",finfo.fname,finfo.fsize,finfo.fattrib);
#if _USE_LFN
if (res != 0 || finfo.fname[0]==0) {
return NULL;
} else {
if (cur_entry.d_name[0]==0) {
// No long filename so use short filename.
memcpy(cur_entry.d_name, finfo.fname, sizeof(finfo.fname));
return &cur_entry;
#else
return NULL;
} else {
return &cur_entry;
#endif /* _USE_LFN */
Well, I spent a few hours fighting this function... All I want to do is read the directory from an SD card and display a list of files with their sizes and time and date information.
struct dirent *FATDirHandle::readdir() { FILINFO finfo; #if _USE_LFN finfo.lfname = cur_entry.d_name; finfo.lfsize = sizeof(cur_entry.d_name); #endif // _USE_LFN FRESULT res = f_readdir(&dir, &finfo); printf("File %s filesize: %d attribute %02x\n\r",finfo.fname,finfo.fsize,finfo.fattrib); #if _USE_LFN if (res != 0 || finfo.fname[0]==0) { return NULL; } else { if (cur_entry.d_name[0]==0) { // No long filename so use short filename. memcpy(cur_entry.d_name, finfo.fname, sizeof(finfo.fname)); } return &cur_entry; } #else if (res != 0 || finfo.fname[0]==0) { return NULL; } else { memcpy(cur_entry.d_name, finfo.fname, sizeof(finfo.fname)); return &cur_entry; } #endif /* _USE_LFN */ }
