[SDP-K1] Change Serial Baud rate on fly
21 Aug 2019
Hi all,
I'm using Mbed on SDP-K1 in order to send DMX512 frames through UART1.
During the process, I change the baud rate of the UART with the Serial::baud() function, between two data transmission. Unfortunately, it's looks like the baud rate change doesn't take effect.
Here's a section of the code I used to test baud rate change :
Code
    while(true) {
        DMX_serial.baud(80000);
        DMXWriteFrame(0);
        DMX_serial.baud(250000);
        DMXWriteFrame(START_FRAME);
        DMXWriteFrame(_data_dmx[0]);
        DMXWriteFrame(_data_dmx[1]);
        led2 = !led2;
        //DMXWriteFrame(a++);
        wait_ms(SLEEP_TIME);
When I look the frames with a scope, all data are transferred with the 250000 baud rate.
Do you have any suggestion ?
Valentin
02 Sep 2019
Hello Valentin,
Add some delay (wait_ms(xxx);) after baudrate change and it will work.
Regards, Pekka
