I'm having troubles with mbed-os 5. With the previous version of mbed (v163) it worked perfectly. With the following piece of assembler code, the micro (stm32F401) enters DFU mode. But with the newest version of mbed-os 5 doesn't work.
void enterDFU(){
__asm ("LDR R0, =0x40023844");// RCC_APB2ENR
__asm ("LDR R1, =0x00004000");// ENABLE SYSCFG CLOCK
__asm ("STR R1, [R0, #0]");
__asm ("LDR R0, =0x40013800");// remap ROM at zero
__asm ("LDR R1, =0x00000001");// SYSCFG_MEMRMP
__asm ("LDR R0, =0x1FFF0000");// ROM BASE
__asm ("LDR SP,[R0, #0]"); // SP @ +0
__asm ("LDR R0,[R0, #4]"); // PC @ +4
__asm ("BX R0"); // Jump to Bootloader
I've been doing some tests and I think that the problem is in the last line (ln:15), when it should jump to the Bootloader. If I try to connect the device on the PC it says "descriptor request error".
Any ideas what may be happening,
Thank you.
void enterDFU(){ __asm ("LDR R0, =0x40023844");// RCC_APB2ENR __asm ("LDR R1, =0x00004000");// ENABLE SYSCFG CLOCK __asm ("STR R1, [R0, #0]"); __asm ("LDR R0, =0x40013800");// remap ROM at zero __asm ("LDR R1, =0x00000001");// SYSCFG_MEMRMP __asm ("STR R1, [R0, #0]"); __asm ("LDR R0, =0x1FFF0000");// ROM BASE __asm ("LDR SP,[R0, #0]"); // SP @ +0 __asm ("LDR R0,[R0, #4]"); // PC @ +4 __asm ("BX R0"); // Jump to Bootloader }I've been doing some tests and I think that the problem is in the last line (ln:15), when it should jump to the Bootloader. If I try to connect the device on the PC it says "descriptor request error".
Any ideas what may be happening, Thank you.
