I have a question about the code below:
FILE *fp = fopen("/local/filename.txt", "w"); while (on) { wait(1); fprintf(fp, "hi\n"); } fclose(fp);This code works like it should. But suppose there is a power outage while the while-loop was still running. This means the file isn't properly closed. If I check the file afterwards, it's empty.
What's the right way to overcome the loss of data if there is a power outage while the file was still open? I already tried carriage return and fflush, but without succes.
