Important update: Arm Announces End of Life Timeline for Mbed. This site will be archived in July 2026. Read the full announcement.
Interrupts vs Thread conflict in mbed for STM32?
            Topic last updated  20 Jun 2018, by    Yehor Pererva.
                            0
                            replies
  Yehor Pererva.
                            0
                            replies
 Yehor Pererva.
                            0
                            replies
  Yehor Pererva.
                            0
                            replies
                    Hello everyone!
I'm studying mbed for STM32 and have some problem with using interrupts and threads in single program.
**What is going on in code:**\\
3 buttons are used to control states of 3 digital outputs,
Encoder has 2 interrupts : to control PWM (on one pin), second interrupt (encoder button) switches states of all 3 outputs (which are attached to buttons).
The same time I read temperature from 3 temperature sensors (on individual data pins).
PWM forming frequency data and read temperatures are transferred to display.
**Problem**\\
When temperature reading is inside of main() function - everything works amazingly.
But when I'm trying to move all temperature reading to thread outside of the main() function the program compiles, but microcontroller stops (freezes) at the moment when tread starts.  After that microcontroller doesn't respond to anything (interrupts do not work).
Is there any conflict if using interrupts and thread in a single program?
Please, help with that.
**Libraries and references**\\
Thread using instructions taken from here: https://docs.mbed.com/docs/mbed-os-api-reference/en/latest/APIs/tasks/rtos/
* Enhanced TextLCD by Wim Huiskamp : https://os.mbed.com/users/wim/code/TextLCD/
* DS1820 by Zoltan Hudak : https://developer.mbed.org/users/hudakz/code/DS1820/wiki/Homepage
**Used Hardware**\\
* HD44780 20x4 LCD in 4-bit mode
* 3 x DS18B20 temperature sensors
* BluePill STM32F103C8T6
**Code**\\
<<code title="Code without threads">>
#include "stm32f103c8t6.h"
#include "TextLCD.h"
#include "DS1820.h"
class Motor{
    public:
        void on()  { _out = 1; };
        void off() { _out = 0; };
        void flip(){ _out = !_out;};
        bool state() { return _out;};
        Motor (PinName button_pin, PinName output_pin) :
            // since _out and _interrupt instances are "private" - they have to be initialized with an initializer list!
            _out(output_pin), _interrupt(button_pin) {
                // now extra actions that has to be done during initializing
                off();
                _interrupt.fall(callback(this, &Motor::flip));
    private:
        DigitalOut _out;
        InterruptIn _interrupt;
DigitalOut led(PC_13);
InterruptIn encoder_A(PA_10);   // contact A of encoder
InterruptIn encoder_S(PA_12);   // contact Switch of encoder
DigitalIn   encoder_B(PA_11);   // contact B of encoder
Motor motor_1(PA_15, PB_11);     // control button input, output pin
Motor motor_2(PB_3, PB_10);
Motor motor_3(PB_4, PB_1);
PwmOut step(PA_1);
DS1820 ds18b20[3] = {DS1820(PA_2), DS1820(PA_3), DS1820(PA_4)};
float temperatures[3];
// For TextLCD in 4-bit mode:
// TextLCD lcd( p11, p12, p30, p29, p28, p27, TextLCD::LCD20x4 ); // rs, e, d4...d7; RW - wire to GND!
// wire RW to ground!
// place the potentiometer between V0 / VSS / VDD to correct the contrast
// For VDD ~5.0 V: VSS can be wired via 2 x 4K7 resistors (in paralel) to GND
TextLCD lcd(PB_12, PB_13, PB_14, PB_15, PA_8, PA_9, TextLCD::LCD20x4 );
// Just input values ----------------------------------------------------------------------------------------------
float RPM = 10.0;               // default value, later shoud be sotred in flash mamory or EEPROM
int SPRmotor = 400;             // Steps Per Revolution of motor : defined by motor model
                                // NEMA 17 : 42BYGHM809 : 400 bipolar
                                // NEMA 23 : 57BYGH420-2 : 200 bipolar stepper; 2A per phase
int MSM = 16;                   // 1; 2; 4; 8; 16 : depends on driver
                                // Big Easy Driver : Allegro A4988 : <2 A per phase : 1, 2, 4, 8, 16
                                // Easy driver : A3967SLBT : <0.7 A per phase : 1, 2, 4, 8
int pulse_width = 75;           // 1...10 microsecond for making step : defined by driver
float period;
volatile bool changed = false;  // important to be volatile!!!!, Otherwise the problem with while loop
void update_period(){
    period = 60.0/(RPM * SPRmotor *  MSM);
void print_RPM(){
    lcd.locate(0,0);
    lcd.printf("%2.1f ", RPM);
    lcd.locate(6,0);
    lcd.printf("%8.3f ", period*1000000);
    lcd.locate(9,1);
    lcd.printf("%6.4f", step.read()*100.0);
// Functions, attached to interrupts ----------------------------------------------------------------------------------------------
void encoder() {
    float lastRPM = RPM;
    if (encoder_B == encoder_A) {
        RPM = RPM + (float) 0.1;
        } else {
            RPM = RPM - (float) 0.1;
    if (RPM < 0.1) {RPM = 0.1;}
    if (lastRPM != RPM) {
        changed = true;
void encoder_switch(){
    // if at least one motor is on, turn off all
    if (motor_1.state() |  motor_2.state() |  motor_3.state()){
        motor_1.off();
        motor_2.off();
        motor_3.off();
    } else {
        motor_1.on();
        motor_2.on();
        motor_3.on();
    led = 0;
    // needed for this library, otherwise - places the "_" symbol after last printed symbol
    lcd.setCursor(TextLCD::CurOff_BlkOff);
    lcd.locate(0,0);
    lcd.printf("Inititalizing...");
    for (int i = 0; i <3; i++){
        lcd.locate(0,i+1);
        lcd.printf("   Temp.Probe %d ", i+1);
        if (!ds18b20[i].begin()){
            lcd.printf("FAIL");
            } else {
            lcd.printf("PASS");
        wait(0.1);
    lcd.cls();
    encoder_A.fall(callback(encoder));
    encoder_S.fall(callback(encoder_switch));
    update_period();
    step.period(period);
    step.write(0.5);
    print_RPM();
    while (true){
        led = !led;
        for (int i = 0; i <3; i++) { ds18b20[i].startConversion();};
        led = !led;
        if (changed){
            changed = false;
            update_period();
            step.write(0.5);    // for some reason needs to be updates
            print_RPM();
        led = !led;
        for (int i = 0; i <3; i++) { temperatures[i] = ds18b20[i].read();};
        led = !led;
            lcd.locate(0+i*5,3);
            lcd.printf("%3.1f", temperatures[i]);
<</code>>
<<code title="Code with threads">>
#include "DS1820.h"
class Motor{
    public:
                off();
    private:
        DigitalOut _out;
PwmOut step(PA_1);
Thread temperature_thread;
float period;
volatile bool measured = false;  // important to be volatile!!!!, Otherwise the problem with while loop
void print_RPM(){
    lcd.locate(0,0);
    lcd.locate(6,0);
    lcd.locate(9,1);
void encoder() {
        } else {
        changed = true;
        motor_1.off();
        motor_2.off();
        motor_3.off();
    } else {
        motor_1.on();
        motor_2.on();
        motor_3.on();
void temperature_monitor(){
    led = !led;
    led = !led;
    wait(1);
    led = !led;
    led = !led;
    measured = true;
    led = 0;
    lcd.locate(0,0);
        lcd.locate(0,i+1);
            lcd.printf("FAIL");
            } else {
            lcd.printf("PASS");
        wait(0.1);
    lcd.cls();
    update_period();
    step.write(0.5);
    temperature_thread.start(temperature_monitor);
    print_RPM();
    while (true){
        if (changed){
            changed = false;
            update_period();
            print_RPM();
        if (measured){
            measured = false;
<</code>>
Hello everyone!
3 buttons are used to control states of 3 digital outputs, Encoder has 2 interrupts : to control PWM (on one pin), second interrupt (encoder button) switches states of all 3 outputs (which are attached to buttons). The same time I read temperature from 3 temperature sensors (on individual data pins). PWM forming frequency data and read temperatures are transferred to display.
Problem
When temperature reading is inside of main() function - everything works amazingly. But when I'm trying to move all temperature reading to thread outside of the main() function the program compiles, but microcontroller stops (freezes) at the moment when tread starts. After that microcontroller doesn't respond to anything (interrupts do not work).
Used Hardware
Code
#include "stm32f103c8t6.h" #include "mbed.h" #include "TextLCD.h" #include "DS1820.h" // ------------------------------------------------------------------------------------------------ class Motor{ public: void on() { _out = 1; }; void off() { _out = 0; }; void flip(){ _out = !_out;}; bool state() { return _out;}; Motor (PinName button_pin, PinName output_pin) : // since _out and _interrupt instances are "private" - they have to be initialized with an initializer list! _out(output_pin), _interrupt(button_pin) { // now extra actions that has to be done during initializing off(); _interrupt.fall(callback(this, &Motor::flip)); }; private: DigitalOut _out; InterruptIn _interrupt; }; // ------------------------------------------------------------------------------------------------ DigitalOut led(PC_13); InterruptIn encoder_A(PA_10); // contact A of encoder InterruptIn encoder_S(PA_12); // contact Switch of encoder DigitalIn encoder_B(PA_11); // contact B of encoder Motor motor_1(PA_15, PB_11); // control button input, output pin Motor motor_2(PB_3, PB_10); Motor motor_3(PB_4, PB_1); PwmOut step(PA_1); DS1820 ds18b20[3] = {DS1820(PA_2), DS1820(PA_3), DS1820(PA_4)}; float temperatures[3]; // For TextLCD in 4-bit mode: // TextLCD lcd( p11, p12, p30, p29, p28, p27, TextLCD::LCD20x4 ); // rs, e, d4...d7; RW - wire to GND! // wire RW to ground! // place the potentiometer between V0 / VSS / VDD to correct the contrast // For VDD ~5.0 V: VSS can be wired via 2 x 4K7 resistors (in paralel) to GND TextLCD lcd(PB_12, PB_13, PB_14, PB_15, PA_8, PA_9, TextLCD::LCD20x4 ); // Just input values ---------------------------------------------------------------------------------------------- float RPM = 10.0; // default value, later shoud be sotred in flash mamory or EEPROM int SPRmotor = 400; // Steps Per Revolution of motor : defined by motor model // NEMA 17 : 42BYGHM809 : 400 bipolar // NEMA 23 : 57BYGH420-2 : 200 bipolar stepper; 2A per phase int MSM = 16; // 1; 2; 4; 8; 16 : depends on driver // Big Easy Driver : Allegro A4988 : <2 A per phase : 1, 2, 4, 8, 16 // Easy driver : A3967SLBT : <0.7 A per phase : 1, 2, 4, 8 int pulse_width = 75; // 1...10 microsecond for making step : defined by driver float period; volatile bool changed = false; // important to be volatile!!!!, Otherwise the problem with while loop void update_period(){ period = 60.0/(RPM * SPRmotor * MSM); }; void print_RPM(){ lcd.locate(0,0); lcd.printf("%2.1f ", RPM); lcd.locate(6,0); lcd.printf("%8.3f ", period*1000000); lcd.locate(9,1); lcd.printf("%6.4f", step.read()*100.0); }; // Functions, attached to interrupts ---------------------------------------------------------------------------------------------- void encoder() { float lastRPM = RPM; if (encoder_B == encoder_A) { RPM = RPM + (float) 0.1; } else { RPM = RPM - (float) 0.1; }; if (RPM < 0.1) {RPM = 0.1;} if (lastRPM != RPM) { changed = true; }; }; void encoder_switch(){ // if at least one motor is on, turn off all if (motor_1.state() | motor_2.state() | motor_3.state()){ motor_1.off(); motor_2.off(); motor_3.off(); } else { motor_1.on(); motor_2.on(); motor_3.on(); }; }; // ---------------------------------------------------------------------------------------------- int main() { led = 0; // needed for this library, otherwise - places the "_" symbol after last printed symbol lcd.setCursor(TextLCD::CurOff_BlkOff); lcd.locate(0,0); lcd.printf("Inititalizing..."); for (int i = 0; i <3; i++){ lcd.locate(0,i+1); lcd.printf(" Temp.Probe %d ", i+1); if (!ds18b20[i].begin()){ lcd.printf("FAIL"); } else { lcd.printf("PASS"); }; wait(0.1); }; lcd.cls(); encoder_A.fall(callback(encoder)); encoder_S.fall(callback(encoder_switch)); update_period(); step.period(period); step.write(0.5); print_RPM(); while (true){ led = !led; for (int i = 0; i <3; i++) { ds18b20[i].startConversion();}; led = !led; if (changed){ changed = false; update_period(); step.period(period); step.write(0.5); // for some reason needs to be updates print_RPM(); }; led = !led; for (int i = 0; i <3; i++) { temperatures[i] = ds18b20[i].read();}; led = !led; for (int i = 0; i <3; i++) { lcd.locate(0+i*5,3); lcd.printf("%3.1f", temperatures[i]); }; }; };Code with threads
#include "stm32f103c8t6.h" #include "mbed.h" #include "TextLCD.h" #include "DS1820.h" // ------------------------------------------------------------------------------------------------ class Motor{ public: void on() { _out = 1; }; void off() { _out = 0; }; void flip(){ _out = !_out;}; bool state() { return _out;}; Motor (PinName button_pin, PinName output_pin) : // since _out and _interrupt instances are "private" - they have to be initialized with an initializer list! _out(output_pin), _interrupt(button_pin) { // now extra actions that has to be done during initializing off(); _interrupt.fall(callback(this, &Motor::flip)); }; private: DigitalOut _out; InterruptIn _interrupt; }; // ------------------------------------------------------------------------------------------------ DigitalOut led(PC_13); InterruptIn encoder_A(PA_10); // contact A of encoder InterruptIn encoder_S(PA_12); // contact Switch of encoder DigitalIn encoder_B(PA_11); // contact B of encoder Motor motor_1(PA_15, PB_11); // control button input, output pin Motor motor_2(PB_3, PB_10); Motor motor_3(PB_4, PB_1); PwmOut step(PA_1); DS1820 ds18b20[3] = {DS1820(PA_2), DS1820(PA_3), DS1820(PA_4)}; float temperatures[3]; Thread temperature_thread; // For TextLCD in 4-bit mode: // TextLCD lcd( p11, p12, p30, p29, p28, p27, TextLCD::LCD20x4 ); // rs, e, d4...d7; // wire RW to ground! // place the potentiometer between V0 / VSS / VDD to correct the contrast // For VDD ~5.0 V: VSS can be wired via 2 x 4K7 resistors (in paralel) to GND TextLCD lcd(PB_12, PB_13, PB_14, PB_15, PA_8, PA_9, TextLCD::LCD20x4 ); // Just input values ---------------------------------------------------------------------------------------------- float RPM = 10.0; // default value, later shoud be sotred in flash mamory or EEPROM int SPRmotor = 400; // Steps Per Revolution of motor : defined by motor model // NEMA 17 : 42BYGHM809 : 400 bipolar // NEMA 23 : 57BYGH420-2 : 200 bipolar stepper; 2A per phase int MSM = 16; // 1; 2; 4; 8; 16 : depends on driver // Big Easy Driver : Allegro A4988 : <2 A per phase : 1, 2, 4, 8, 16 // Easy driver : A3967SLBT : <0.7 A per phase : 1, 2, 4, 8 int pulse_width = 75; // 1...10 microsecond for making step : defined by driver float period; volatile bool changed = false; // important to be volatile!!!!, Otherwise the problem with while loop volatile bool measured = false; // important to be volatile!!!!, Otherwise the problem with while loop void update_period(){ period = 60.0/(RPM * SPRmotor * MSM); }; void print_RPM(){ lcd.locate(0,0); lcd.printf("%2.1f ", RPM); lcd.locate(6,0); lcd.printf("%8.3f ", period*1000000); lcd.locate(9,1); lcd.printf("%6.4f", step.read()*100.0); }; // Functions, attached to interrupts ---------------------------------------------------------------------------------------------- void encoder() { float lastRPM = RPM; if (encoder_B == encoder_A) { RPM = RPM + (float) 0.1; } else { RPM = RPM - (float) 0.1; }; if (RPM < 0.1) {RPM = 0.1;} if (lastRPM != RPM) { changed = true; }; }; void encoder_switch(){ // if at least one motor is on, turn off all if (motor_1.state() | motor_2.state() | motor_3.state()){ motor_1.off(); motor_2.off(); motor_3.off(); } else { motor_1.on(); motor_2.on(); motor_3.on(); }; }; void temperature_monitor(){ led = !led; for (int i = 0; i <3; i++) { ds18b20[i].startConversion();}; led = !led; wait(1); led = !led; for (int i = 0; i <3; i++) { temperatures[i] = ds18b20[i].read();}; led = !led; measured = true; }; // ---------------------------------------------------------------------------------------------- int main() { led = 0; // needed for this library, otherwise - places the "_" symbol after last printed symbol lcd.setCursor(TextLCD::CurOff_BlkOff); lcd.locate(0,0); lcd.printf("Inititalizing..."); for (int i = 0; i <3; i++){ lcd.locate(0,i+1); lcd.printf(" Temp.Probe %d ", i+1); if (!ds18b20[i].begin()){ lcd.printf("FAIL"); } else { lcd.printf("PASS"); }; wait(0.1); }; lcd.cls(); encoder_A.fall(callback(encoder)); encoder_S.fall(callback(encoder_switch)); update_period(); step.period(period); step.write(0.5); temperature_thread.start(temperature_monitor); print_RPM(); while (true){ if (changed){ changed = false; update_period(); step.period(period); step.write(0.5); // for some reason needs to be updates print_RPM(); }; if (measured){ measured = false; for (int i = 0; i <3; i++) { lcd.locate(0+i*5,3); lcd.printf("%3.1f", temperatures[i]); }; }; }; };
