Dear Ros,
I can't open my compiler screen either.
When I open compiler, this message is displayed from yesterday.
Fatal Application Error: Resource object failed to load.
?request=/eNqLT423LSlKTQUADYMDEQ==&tree_id=nav_tree&tree_node_id=%2F&tree_node_path=1
<br />
<b>Fatal error</b>: Maximum execution time of 30 seconds exceeded in <b>/var/lib/mbed/compiler/releases/current/theitf/system/modules/error_handler.inc.php</b> on line <b>5</b><br />
Please contact support and describe how you get this message.
I used mbed compiler - 1.6.1(beta).
Would you give me some advice?
I can't access the compiler screen anymore. I don't know if it has anything to do with the library I just published. Here's the error message:
<br /> <b>Fatal error</b>: Maximum execution time of 30 seconds exceeded in <b>/var/lib/mbed/compiler/releases/current/theitf/system/modules/functions.inc.php</b> on line <b>554</b><br />
I've cleared my cache, restarted my computer, and even used a different computer which didn't work. Does anyone know how to fix this? I need to use the compiler urgently
