Hi, I love the mbed hardware, but closed-source online compilation seems totally weird and crazy to me. Maybe it's useful for beginners... So anyway, I'm trying to get something working with LPCXpresso. Here's what I've done so far:
1. Download & install LPCXpresso.
2. Import the CMSISv2p00LPC11Uxx library project, and the LPCXpresso11U14_systick example project (it's supposed to flash an LED).
3. Change LED_PORT and LED_BIT to:
#define LED_PORT 1 // Port for led
#define LED_BIT 18 // Bit on port for led
which as far as I can tell is LED0 (or LED1 or whatever) on the mbed.
4. Right click the example project->Properties->C/C++ Build->Settings->Build Steps-> (Lost yet?) ->Post-build steps->Command. Remove the '#' which prevents the .bin file from being built.
5. Build the project. You get a bin file, which is nice.
6. Copy the file to the mbed using 'cp' and reset. Sadly it doesn't flash the LED and now I am stuck. I also tried using lpc-flash from OpenPCD.org which is necessary for the LPC13xx on linux due to something about FAT (and it also calculates the checksum, although the compile output says that is already done). Still didn't work.
Here's the obj-copy output nayway:
make --no-print-directory post-build
Performing post-build steps
arm-none-eabi-size LPCXpresso11U14_systick.axf; arm-none-eabi-objcopy -O binary LPCXpresso11U14_systick.axf LPCXpresso11U14_systick.bin ; checksum -p LPC11U14_201 -d LPCXpresso11U14_systick.bin;
text data bss dec hex filename
3192 4 156 3352 d18 LPCXpresso11U14_systick.axf
Created checksum 0x9edffef in LPCXpresso11U14_systick.bin at offset 0x1c
Has anyone got this to work? I'd rather not use any closed source stuff on this...
