While playing a bit with the VGA generator code posted somewhere in this site, found this pwm problem.
Please, can someone tell me why I don´t get pwm interrupts 4 and 6 using this code?
I´m using mbed, lpcxpresso compiler (a tuned gcc) and fastlib.
fl_power_pwm1(FL_ON);
fl_select_clock_pwm1(FL_CLOCK_DIV1);
fl_pinsel(2, 1, FL_FUNC_ALT1, FL_FLOATING, FL_FLOATING); // PWM1.2, no pullup/down
fl_pwm_set_prescale(4); // 100/25 = 4
fl_pwm_config_match(0, FL_ON, FL_ON, FL_OFF); // interrupt, reset, !stop
fl_pwm_set_match(0, 800); // 800 dot clocks
fl_pwm_set_match(2, 704); // go low at 704/high again at 800
fl_pwm_config_match(2, FL_OFF, FL_OFF, FL_OFF); // interrupt, reset, !stop
fl_pwm_set_match(4, 48); // start visible line
fl_pwm_config_match(4, FL_ON, FL_OFF, FL_OFF); // interrupt, reset, !stop
fl_pwm_set_match(6, 688); // end visible line 688-48=640
fl_pwm_config_match(6, FL_ON, FL_OFF, FL_OFF); // interrupt, reset, !stop
fl_pwm_config_edges(2, FL_SINGLE_EDGE);
fl_pwm_config_edges(4, FL_SINGLE_EDGE);
fl_pwm_config_edges(6, FL_SINGLE_EDGE);
fl_pwm_output_enable(2, FL_ENABLE); //
fl_pwm_latch_match_all();
fl_nvic_interrupt_set_enable(FL_NVIC_INT_PWM); // enable PWM interrupts
fl_pwm_timer_counter_enable(FL_ENABLE);
fl_pwm_enable(FL_ENABLE);
//Interrupt handler
void PWM1_IRQHandler(void) {
uint32_t regval=*FL_PWM1IR;
if (regval & (1 << 0)) { //
printf("got this one");
*FL_PWM1IR=(regval & (1 << 0));
else if (regval & (1 << 8)) { //start visible line
printf("but no this");
*FL_PWM1IR=(regval & (1 << 8));
else if (regval & (1 << 10)) { //end visible line
*FL_PWM1IR=(regval & (1 << 10));
Hi all!
While playing a bit with the VGA generator code posted somewhere in this site, found this pwm problem. Please, can someone tell me why I don´t get pwm interrupts 4 and 6 using this code? I´m using mbed, lpcxpresso compiler (a tuned gcc) and fastlib.
Thanks in advance!
pwm setting code:
