I've recently been writing bare metal assembly language software for the FRDM KL25Z board and using the online MBED ARM assembler. I've managed to get a number of different examples working ok, so have passed the initial hurdle of getting things running.
I'm using assembly language (rather than C++) as I'm developing some teaching material for an undergrad architecture course.
One problem I've come across is with using the value of labels in assembler directives and as operands to instructions. The value of the label appearing in the binary appears to be the actual value plus 0x8000.
The following code is a minimal example of this:
AREA asm_func, CODE, READONLY
THUMB
DCD 0x20000000 // Top of Stack
DCD main // Reset Handler
main
LDR R0,=main
B main
This assembles to the following series of bytes:
00 00 00 20 09 80 00 00 00 48 FD E7 09 80 00 00
which if disassembled, gives the following:
0000 20000000
0004 00008009
0008 4800 LDR R0,=0x000C
000A E7FD B 0008
000C 00008009
The reset vector at address 0004 should be 0x9 (8 + 1 for thumb) - whereas we have 0x8009.
Again we see the same problem with the LDR instruction. The assembler is dropping the value of the operand at the end of code, as expected, at address 000C and accessing this as an offset on PC. Again however the value in the binary is 0x8009 rather than 9.
I can get around these problems by plugging in constants, but it would be nice to refer to labels in many cases. [The particular example where I would like to reference the value of a label is so that I can pass the address of an interrupt handler to a piece of code which updates a copy of the interrupt vector table which has been relocated to RAM.]
Has anyone come across this, or know what the problem is?
cheers
Gerald
AREA asm_func, CODE, READONLY THUMB DCD 0x20000000 // Top of Stack DCD main // Reset Handler main LDR R0,=main B mainThis assembles to the following series of bytes:
cheers Gerald
