I was just asked if it is possible to use a pin as both an analog and a digital pin in different parts of the code.
The answer is yes, but it should be considered carefully if this is the best way to achieve the desired result.
Anyway, I wrote an example program that has two functions read_analog and read_digital, where each function has it's own local object (either analog or digital) which is created each time the function is called.
Not a particularly complex example, but it does enable you to measure the threshold voltage at which a DigitalIn starts reading the input as a '1'.
00001 #include "mbed.h"
00002
00003 int read_digital(void) {
00004 DigitalIn mydigital(p20);
00005 return(mydigital.read());
00006 }
00007
00008 float read_analog(void) {
00009 AnalogIn myanalog(p20);
00010 return(myanalog.read());
00011 }
00012
00013 int main() {
00014 while(1) {
00015
00016 printf("Digital reading : %d\n",read_digital());
00017 wait(1.0);
00018 printf("Analog reading : %.2f\n",read_analog());
00019 wait(1.0);
00020
00021 }
00022 }
Import programAnalogDigital - main.cpp
