Weird!
Using
, which is
(p18,p17,p16,p15,p11,p12,p14,p13)
, I read the portIn value.
I am extremely confused about the bit order of the received byte.
Using this code to print every bit:
pc.printf(..., s,s&0x80,s&0x40,s&0x20,s&0x10,s&0x8,s&0x4,s&0x2,s&0x1)
, I see that, when pin input is HIGH, the value of the bits is:
(8,4,2,1,256,512,1024,2048)
What is the correct order to read one byte from PortIn?
PS I' ve found a function to read a byte from PortIn, but seems not to work and is even more confusing:
int top = s >> 19; // Isolate the top nibble
int middle = s >> 2; // Isolate bits 2 & 3
s = s & 0x00000003; // Isolate bits 0 & 1
s += middle;
s += top;
So what the hell is going on here? THANKS everybody!!
Weird! Using
, which is
, I read the portIn value. I am extremely confused about the bit order of the received byte. Using this code to print every bit:
int top = s >> 19; // Isolate the top nibble int middle = s >> 2; // Isolate bits 2 & 3 s = s & 0x00000003; // Isolate bits 0 & 1 s += middle; s += top;So what the hell is going on here? THANKS everybody!!
