Embedded artists have just launched a new breakout board for EUR69, which will be mbed compatible. Unfortunately it looks like it won't ship in time for Christmas.
http://www.embeddedartists.com/products/lpcxpresso/xpr_base.php
Common features
• Socket for LPCXpresso and mbed module
• 50 pin expansion dual row pin list connector (male, 100mil pitch) for simple connection external designs and to a logic analyzer
• 50 pin expansion dual row header connector (female, 100mil pitch) for simple connection to breadboard
• Battery powering (small coin battery)
• USB interface
• Reset pushbutton
Digital IO
• RGB-LED (can be PWM controlled)
• 5-key joystick switch
• 2 pushbuttons, one for activating bootloader
• Rotary switch with quadrature encoding (timer capture)
• Temperature sensor with PWM output (timer capture)
Analog IO
• Trimming potentiometer input (analog input)
• PWM to analog LP-filtering (PWM output and analog input)
• Speaker output (PWM output)
• Oscilloscope probe inout stage
Serial bus - SPI
• Shift register driving 7-segment LED
• SD/MMC memory card interface
• Dataflash SPI-NOR flash
Serial bus - I2C
• PCA9532 port expander connected to 16 LEDs
• 8kbit E2PROM
• MMA7455L accelerometer with I2C interface
• Light sensor
Serial bus - I2C/SPI shared
• SC16IS752 - I2C/SPI to 2xUART bridge; connected to RS232 full-modem interface and one expansion UART
• 128x64 pixel white OLED (alternative I2C/SPI interface)
Serial bus - UART
• USB-to-serial bridge, with automatic ISP activation
• RS422/485 interface, connected to DSUB
• Interface socket for XBee RF-module
Specific mbed module support
• CAN bus interface (can be simulated with LPC-Xpresso), connected to DSUB
• Ethernet RJ45 connector with integrated magnetic
Dimensions
150 x 180 mm
Power
Powered via USB (+5V)
Common features
• USB interface
• Reset pushbutton
Digital IO
Analog IO
Serial bus - SPI
Serial bus - I2C
• 8kbit E2PROM
• Light sensor
Serial bus - UART
Dimensions
150 x 180 mm
Power
