I had the common problem with mbed serial driver but now have:
I am using platform NUCLEO_F746ZG on Windows 10. Note the Driver: NODE_F746ZG which is under Portable Devices and which accepts bin files from the MBED online compiler. Note the ÜSB Serial Device (COM3) under Ports (COM & LTP). The NODE_F746ZG driver has MBED as the manufacturers name. The ÜSB Serial Device (COM3) driver, although it has the same date as the official MBED driver, is named Microsoft and has version 10.0.10586.306. There is no MBED name on the ÜSB Serial Device but works with Tera Term:
I did delete a ST virtual COM port prior to Microsoft auto install.
Does the official mbed serial driver work for you on Windows 10?
