im having trouble initializing uart1 on p13 and p14
here is my init code. triple checked and referenced the lpc1768 manual and followed every single line in the example configuration step.
void uart1_init(void) { LPC_SC->PCONP |= (1<<4); //power up uart1 LPC_SC->PCLKSEL0 |= (3<<8); //run uart1 clock at 12MHz (prescale 8) //baud generation (115200) LPC_UART1->LCR |= (1<<7); //DLAB enable LPC_UART1->DLL = (4<<0); //divl LPC_UART1->DLM = (0<<0); //divm LPC_UART1->FDR = (5<<0) | (8<<4); //fractional baud div LPC_UART1->FCR |= (3<<6) | (1<<2) | (1<<1) | (1<<0); //FIFO enable, TX and RX FIFO reset LPC_PINCON->PINSEL0 |= (0x40000000); //txd1 LPC_PINCON->PINSEL1 |= (1<<0); //rxd1 LPC_PINCON->PINMODE0 |= (0x80000000); LPC_PINCON->PINMODE1 |= (1<<1); LPC_UART1->LCR |= (0<<7); //DLAB disable LPC_UART1->IER |= (1<<2) | (1<<0); //receive and transmit interrupt only LPC_UART1->LCR |= (0<<7) | (0<<3) | (0<<2) | (3<<0); //8-n-1, DLAB=0 LPC_UART1->TER |= (1<<7); //enable transmitter LPC_UART1->LCR |= (0<<7); //DLAB=0 NVIC_EnableIRQ(UART1_IRQn); } //sending code LPC_UART1->THR = 'A'; while((LPC_UART1->LSR & (1<<5)) == 0);what possibly could be wrong with my init code
