Using mbed api in own class
14 Aug 2011
I want to use the serial API in my own class, but I can't get this to work. What am I doing wrong?
status.cpp:
#include "status.h"
Status::Status(Roer * r, Zeil * z){
    roer = r;
    zeil = z;
    zender.baud(9600);
    zender.attach(&Status::newData);
void Status::newData(void) {
    //buffer variables
    char lezen;
    //if data is ready in the buffer
    while (zender.readable()) {
        //read 1 character
        lezen = zender.getc();
        //if character is $ than it is the start of a sentence
        if (lezen == '$') {
            //so the pointer should be set to the first position
            plaats = 0;
        //write buffer character to big buffer string
        buffer_recv[plaats] = lezen;
        //if the character is # than the end of the sentence is reached and some stuff has to be done
        if (lezen == '#') {
            zender.putc('A');
status.h:
#ifndef STATUS_H
#define STATUS_H
#include "roer.h"
#include "zeil.h"
class Status{
    Serial zender(p13,p14);
    Roer * roer;
    Zeil * zeil;
    char buffer_recv[128];
    int plaats;
    void newData(void);
    public:
        Status(Roer *, Zeil *);
#endif
The error is:
"constant "p13" is not a type name" in file "status.h/<a href="#" onClick="window.open('/cookbook/Compiler-Error-757');">757</a>"
"constant "p14" is not a type name" in file "status.h/<a href="#" onClick="window.open('/cookbook/Compiler-Error-757');">757</a>"
"nonstandard form for taking the address of a member function" in file "status.cpp/<a href="#" onClick="window.open('/cookbook/Compiler-Error-504-D');">504-D</a>"
"expression must have class type" in file "status.cpp/<a href="#" onClick="window.open('/cookbook/Compiler-Error-153');">153</a>"
etc.
14 Aug 2011
Never mind, problem solved. The working code:
#include "status.h"
Status::Status(Roer * r, Zeil * z) : zender(p13,p14){
    roer = r;
    zeil = z;
    zender.baud(9600);
    zender.attach(this, &Status::newData);
    //buffer variables
    char lezen;
        //read 1 character
        if (lezen == '$') {
            plaats = 0;
        if (lezen == '#') {
            zender.putc('A');
