SOVLED: - Problem is the Create Mechanism is incorrect.
Thank you for any help you can give in advance.
The problem is my code crashes the MBed on the "Crashes here" line.
I am attempting to dynamically allocate the ports on the chip. I am having trouble on the dynamic allocation and assigning it to a on class pointer.
The use of LED_Two works correctly with the pointer defined and then allocated a port and it allows it work correctly. However allocating it to LED_One it then causes the MBed to hang even though they are defined the same.
Is it something to do with how I am declaring the pointer?
File: main.c
#include "LED_Light.h"
DigitalOut myled(LED1);
LED_Light *LED = 0;
myled = 1;
wait(0.2);
myled = 0;
wait(0.2);
LED = LED -> Create();
LED -> Initalise(LED3);
wait(10);
File: LED_Light.h
#ifndef LED_LIGHT
#define LED_LIGHT
class LED_Light {
private:
//-- Definition of the private LED Lights
DigitalOut *LED_One;
//-- Constructor
LED_Light();
//-- Destructor
~LED_Light();
public:
LED_Light *Create();
void Initalise(PinName LED_One_Pin);
#endif
File: LED_Light.cpp
Serial pc(USBTX, USBRX);
PinName Port[4] = {P1_18, P1_20, P1_21, P1_23};
//-- Name: Create
//-- Function: Standard Create Mechanism
LED_Light *LED_Light::Create(){
LED_Light *The_LED = 0;
if (this == 0){
The_LED = new LED_Light();
return The_LED;
void LED_Light::Initalise(PinName LED_One_Pin){
DigitalOut *LED_Two;
pc.printf("\n\r");
pc.printf("Creating LED Two\n\r");
LED_Two = new DigitalOut (Port[2]);
pc.printf("Setting LED Two On\n\r");
LED_Two -> write(1);
pc.printf("End\n\r");
pc.printf("Creating LED One\n\r");
LED_One = new DigitalOut (Port[1]); //-- Crashes Here
pc.printf("Setting LED One On\n\r");
LED_One -> write(1);
LED_Light::LED_Light(){ };
File: main.c
#include "mbed.h" #include "LED_Light.h" DigitalOut myled(LED1); int main() { LED_Light *LED = 0; while(1) { myled = 1; wait(0.2); myled = 0; wait(0.2); LED = LED -> Create(); LED -> Initalise(LED3); wait(10); } }File: LED_Light.h
#include "mbed.h" #ifndef LED_LIGHT #define LED_LIGHT class LED_Light { private: //-- Definition of the private LED Lights DigitalOut *LED_One; //-- Constructor LED_Light(); //-- Destructor ~LED_Light(); public: LED_Light *Create(); void Initalise(PinName LED_One_Pin); }; #endifFile: LED_Light.cpp
#include "LED_Light.h" Serial pc(USBTX, USBRX); PinName Port[4] = {P1_18, P1_20, P1_21, P1_23}; //--------------------------------------------------------- //-- Name: Create //-- //-- Function: Standard Create Mechanism //-- //--------------------------------------------------------- LED_Light *LED_Light::Create(){ LED_Light *The_LED = 0; if (this == 0){ The_LED = new LED_Light(); } return The_LED; } void LED_Light::Initalise(PinName LED_One_Pin){ DigitalOut *LED_Two; pc.printf("\n\r"); pc.printf("Creating LED Two\n\r"); LED_Two = new DigitalOut (Port[2]); pc.printf("Setting LED Two On\n\r"); LED_Two -> write(1); pc.printf("End\n\r"); pc.printf("Creating LED One\n\r"); LED_One = new DigitalOut (Port[1]); //-- Crashes Here pc.printf("Setting LED One On\n\r"); LED_One -> write(1); pc.printf("End\n\r"); } LED_Light::LED_Light(){ };
