Important update: Arm Announces End of Life Timeline for Mbed. This site will be archived in July 2026. Read the full announcement.
TCP Server responding very slowly
Topic last updated 01 Jul 2011, by
Fabio Garufi.
0
replies
Fabio Garufi.
0
replies
I slightly modified the TCPServer program to respond to calls from a client that calculates the round-trip time and the number of messages echoed per second. I only get something like 4 messages per second, independetly on the message length.
The times to complete the onLinkSocketEvent callback are around 7 us to send and 14 us to receive.
Here's the TCPServer
<<code>>
#include "EthernetNetIf.h"
#include "TCPSocket.h"
EthernetNetIf eth( // Brings up the device with static IP address and domain name.
IpAddr(192,168,1,177), // IPv4 address
IpAddr(255,255,255,0), // netmask
IpAddr(192,168,1,1), // default gateway
IpAddr(192,168,1,1)); // dns server
DigitalOut led1(LED1);
TCPSocket tcp; //The listening port where requests are queued
TCPSocket* link; //The port where accepted requests can communicate
Host local(IpAddr(), 10003); //mbed IP
Host client;
TCPSocketErr accErr;
Timer TimG;
Ticker To;
int Nf=0;
int readable=0;
int writeable=0;
int accepted=0;
int connected=0;
char ack = 0xe;
void onLinkSocketEvent(TCPSocketEvent e)
char buff[128];
Timer Tim;
Tim.reset();
Tim.start();
// printf("link Callback evt %d\n",e );
switch(e)
case TCPSOCKET_CONNECTED:
printf("TCP Socket Connected\r\n");
connected =1;
break;
case TCPSOCKET_WRITEABLE:
//Can now write some data...
//printf("TCP Socket Writable\r\n");
printf("w ");
writeable=1;
break;
case TCPSOCKET_READABLE:
readable=1;
//Can now read dome data...
//printf("TCP Socket Readable\r\n");
// Read in any available data into the buffer
while ( int len = link->recv(buff, 128) ) {
// And send straight back out again
link->send(&ack, 1);
readable=0;
break;
case TCPSOCKET_CONTIMEOUT:
//printf("TCP Socket Timeout\r\n");
break;
case TCPSOCKET_CONRST:
//printf("TCP Socket CONRST\r\n");
break;
case TCPSOCKET_CONABRT:
// printf("TCP Socket CONABRT\r\n");
break;
case TCPSOCKET_ERROR:
// printf("TCP Socket Error\r\n");
break;
case TCPSOCKET_DISCONNECTED:
//Close socket...
printf("TCP Socket Disconnected\r\n");
link->close();
connected =0;
break;
default:
printf("DEFAULT\r\n");
readable=0;
writeable=0;
Tim.stop();
TimG.stop();
printf("Time Step us %d Nf=%d\n", Tim.read_us(), Nf);
TimG.reset();
Tim.reset();
void onTCPSocketEvent(TCPSocketEvent e)
Timer Tim;
TimG.start();
Tim.start();
switch(e) {
printf("Connected\n");
break;
case TCPSOCKET_ACCEPT: {
accErr = tcp.accept(&client,&link);
switch(accErr) {
case TCPSOCKET_SETUP: printf("Err:Setup\n"); break; //TCPSocket not properly configured.
case TCPSOCKET_TIMEOUT: printf("Err:Timeout\n"); break; //Connection timed out.
case TCPSOCKET_IF: printf("Err:Interface\n"); break; //Interface has problems, does not exist or is not initialized.
case TCPSOCKET_MEM: printf("Err:Memory\n"); break; //Not enough mem.
case TCPSOCKET_INUSE: printf("Err:In use\n"); break; //Interface / Port is in use.
case TCPSOCKET_EMPTY: printf("Err:Empty\n"); break; //Connections queue is empty.
case TCPSOCKET_RST: printf("Err:Reset\n"); break; //Connection was reset by remote host.
case TCPSOCKET_OK: printf("Accepted: "); break; //Success.
link->setOnEvent(&onLinkSocketEvent);
IpAddr clientIp = client.getIp();
accepted=1;
printf("Incoming TCP connection from %d.%d.%d.%d\r\n",
clientIp[0], clientIp[1], clientIp[2], clientIp[3]);
break;
printf("Readable\n");
break;
writeable=1;
printf("Writeable\n");
break;
printf("Timeout\n");
break;
printf("Reset\n");
break;
printf("Aborted\n");
break;
printf("Error\n");
break;
printf("Disconnected\n");
tcp.close();
accepted =0;
break;
Tim.stop();
printf("Accept Callback Timer %d\n", Tim.read_us());
Tim.reset();
void DataFilt()
Nf++;
Timer Tim;
To.attach(&DataFilt, 0.01);
//********Basic setup********
printf("Welcome to wireFUSE\n");
printf("Setting up...\n");
EthernetErr ethErr = eth.setup();
if(ethErr)
printf("Error %d in setup.\n", ethErr);
return -1;
printf("Setup OK\n");
//****End of basic setup*****
tcp.setOnEvent(&onTCPSocketEvent); //Generate method to deal with requests
//Bind to local port
printf("Init bind..\n");
TCPSocketErr bindErr = tcp.bind(local);
switch(bindErr) {
case TCPSOCKET_OK: printf("Bound to port\n"); break; //Success.
//Listen to local port
printf("Init listen..\n");
TCPSocketErr listenErr = tcp.listen();
switch(listenErr) {
case TCPSOCKET_OK: printf("Listening\n"); break; //Success.
// Timer tmr;
//tmr.start();
if(accepted)
Net::poll();
while(!readable)
Net::poll();
<</code>>
#######################################3
This is the result of the Sender/receiver
./testTCPSender 192.168.1.177 10 10 10003
out 0
min 109878 max 250011
sum 2359730.000000 sum2 24743399424.000000
Avg. 235973.000000 Sigma nan
Delta T = 2359747 (usec)
4.237742 messages/sec
Here is the packet dump on the sender/receiver
tcpdump src 192.168.1.177 or dst 192.168.1.177
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1, link-type EN10MB (Ethernet), capture size 96 bytes
12:15:09.553268 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: S 262914439:262914439(0) win 5840 <mss 1460,sackOK,timestamp 1287352803 0,nop,wscale 7>
12:15:09.553345 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: S 11490:11490(0) ack 262914440 win 2144 <mss 536>
12:15:09.553359 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: . ack 1 win 5840
12:15:09.553576 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 1:11(10) ack 1 win 5840
12:15:09.663160 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 1:2(1) ack 11 win 2134
12:15:09.663340 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: . ack 2 win 5840
12:15:09.663456 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 11:21(10) ack 2 win 5840
12:15:09.913172 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 2:3(1) ack 21 win 2124
12:15:09.913265 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 21:31(10) ack 3 win 5840
12:15:10.163182 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 3:4(1) ack 31 win 2114
12:15:10.163274 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 31:41(10) ack 4 win 5840
12:15:10.413188 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 4:5(1) ack 41 win 2104
12:15:10.413276 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 41:51(10) ack 5 win 5840
12:15:10.663200 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 5:6(1) ack 51 win 2094
12:15:10.663287 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 51:61(10) ack 6 win 5840
12:15:10.913207 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 6:7(1) ack 61 win 2084
12:15:10.913300 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 61:71(10) ack 7 win 5840
12:15:11.163214 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 7:8(1) ack 71 win 2074
12:15:11.163307 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 71:81(10) ack 8 win 5840
12:15:11.413222 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 8:9(1) ack 81 win 2064
12:15:11.413314 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 81:91(10) ack 9 win 5840
12:15:11.663232 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 9:10(1) ack 91 win 2054
12:15:11.663324 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: P 91:101(10) ack 10 win 5840
12:15:11.913234 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: P 10:11(1) ack 101 win 2044
12:15:11.913737 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: F 101:101(0) ack 11 win 5840
12:15:11.913853 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: . ack 102 win 2043
12:15:11.966174 IP 192.168.1.177.10003 > lxvirgo5.na.infn.it.36194: F 11:11(0) ack 102 win 2043
12:15:11.966196 IP lxvirgo5.na.infn.it.36194 > 192.168.1.177.10003: . ack 12 win 5840
I slightly modified the TCPServer program to respond to calls from a client that calculates the round-trip time and the number of messages echoed per second. I only get something like 4 messages per second, independetly on the message length. The times to complete the onLinkSocketEvent callback are around 7 us to send and 14 us to receive.
################include "mbed.h" #include "EthernetNetIf.h" #include "TCPSocket.h" EthernetNetIf eth( // Brings up the device with static IP address and domain name. IpAddr(192,168,1,177), // IPv4 address IpAddr(255,255,255,0), // netmask IpAddr(192,168,1,1), // default gateway IpAddr(192,168,1,1)); // dns server DigitalOut led1(LED1); TCPSocket tcp; //The listening port where requests are queued TCPSocket* link; //The port where accepted requests can communicate Host local(IpAddr(), 10003); //mbed IP Host client; TCPSocketErr accErr; Timer TimG; Ticker To; int Nf=0; int readable=0; int writeable=0; int accepted=0; int connected=0; char ack = 0xe; void onLinkSocketEvent(TCPSocketEvent e) { char buff[128]; Timer Tim; Tim.reset(); Tim.start(); // printf("link Callback evt %d\n",e ); switch(e) { case TCPSOCKET_CONNECTED: printf("TCP Socket Connected\r\n"); connected =1; break; case TCPSOCKET_WRITEABLE: //Can now write some data... //printf("TCP Socket Writable\r\n"); printf("w "); writeable=1; break; case TCPSOCKET_READABLE: readable=1; //Can now read dome data... //printf("TCP Socket Readable\r\n"); // Read in any available data into the buffer while ( int len = link->recv(buff, 128) ) { // And send straight back out again link->send(&ack, 1); } readable=0; break; case TCPSOCKET_CONTIMEOUT: //printf("TCP Socket Timeout\r\n"); break; case TCPSOCKET_CONRST: //printf("TCP Socket CONRST\r\n"); break; case TCPSOCKET_CONABRT: // printf("TCP Socket CONABRT\r\n"); break; case TCPSOCKET_ERROR: // printf("TCP Socket Error\r\n"); break; case TCPSOCKET_DISCONNECTED: //Close socket... printf("TCP Socket Disconnected\r\n"); link->close(); connected =0; break; default: printf("DEFAULT\r\n"); } readable=0; writeable=0; Tim.stop(); TimG.stop(); printf("Time Step us %d Nf=%d\n", Tim.read_us(), Nf); TimG.reset(); Tim.reset(); } void onTCPSocketEvent(TCPSocketEvent e) { Timer Tim; TimG.start(); Tim.start(); switch(e) { case TCPSOCKET_CONNECTED: printf("Connected\n"); break; case TCPSOCKET_ACCEPT: { accErr = tcp.accept(&client,&link); switch(accErr) { case TCPSOCKET_SETUP: printf("Err:Setup\n"); break; //TCPSocket not properly configured. case TCPSOCKET_TIMEOUT: printf("Err:Timeout\n"); break; //Connection timed out. case TCPSOCKET_IF: printf("Err:Interface\n"); break; //Interface has problems, does not exist or is not initialized. case TCPSOCKET_MEM: printf("Err:Memory\n"); break; //Not enough mem. case TCPSOCKET_INUSE: printf("Err:In use\n"); break; //Interface / Port is in use. case TCPSOCKET_EMPTY: printf("Err:Empty\n"); break; //Connections queue is empty. case TCPSOCKET_RST: printf("Err:Reset\n"); break; //Connection was reset by remote host. case TCPSOCKET_OK: printf("Accepted: "); break; //Success. } link->setOnEvent(&onLinkSocketEvent); IpAddr clientIp = client.getIp(); accepted=1; printf("Incoming TCP connection from %d.%d.%d.%d\r\n", clientIp[0], clientIp[1], clientIp[2], clientIp[3]); } break; case TCPSOCKET_READABLE: printf("Readable\n"); break; case TCPSOCKET_WRITEABLE: writeable=1; printf("Writeable\n"); break; case TCPSOCKET_CONTIMEOUT: printf("Timeout\n"); break; case TCPSOCKET_CONRST: printf("Reset\n"); break; case TCPSOCKET_CONABRT: printf("Aborted\n"); break; case TCPSOCKET_ERROR: printf("Error\n"); break; case TCPSOCKET_DISCONNECTED: printf("Disconnected\n"); tcp.close(); accepted =0; break; } Tim.stop(); printf("Accept Callback Timer %d\n", Tim.read_us()); Tim.reset(); } void DataFilt() { Nf++; } int main() { Timer Tim; To.attach(&DataFilt, 0.01); //********Basic setup******** printf("Welcome to wireFUSE\n"); printf("Setting up...\n"); EthernetErr ethErr = eth.setup(); if(ethErr) { printf("Error %d in setup.\n", ethErr); return -1; } printf("Setup OK\n"); //****End of basic setup***** tcp.setOnEvent(&onTCPSocketEvent); //Generate method to deal with requests //Bind to local port printf("Init bind..\n"); TCPSocketErr bindErr = tcp.bind(local); switch(bindErr) { case TCPSOCKET_SETUP: printf("Err:Setup\n"); break; //TCPSocket not properly configured. case TCPSOCKET_TIMEOUT: printf("Err:Timeout\n"); break; //Connection timed out. case TCPSOCKET_IF: printf("Err:Interface\n"); break; //Interface has problems, does not exist or is not initialized. case TCPSOCKET_MEM: printf("Err:Memory\n"); break; //Not enough mem. case TCPSOCKET_INUSE: printf("Err:In use\n"); break; //Interface / Port is in use. case TCPSOCKET_EMPTY: printf("Err:Empty\n"); break; //Connections queue is empty. case TCPSOCKET_RST: printf("Err:Reset\n"); break; //Connection was reset by remote host. case TCPSOCKET_OK: printf("Bound to port\n"); break; //Success. } //Listen to local port printf("Init listen..\n"); TCPSocketErr listenErr = tcp.listen(); switch(listenErr) { case TCPSOCKET_SETUP: printf("Err:Setup\n"); break; //TCPSocket not properly configured. case TCPSOCKET_TIMEOUT: printf("Err:Timeout\n"); break; //Connection timed out. case TCPSOCKET_IF: printf("Err:Interface\n"); break; //Interface has problems, does not exist or is not initialized. case TCPSOCKET_MEM: printf("Err:Memory\n"); break; //Not enough mem. case TCPSOCKET_INUSE: printf("Err:In use\n"); break; //Interface / Port is in use. case TCPSOCKET_EMPTY: printf("Err:Empty\n"); break; //Connections queue is empty. case TCPSOCKET_RST: printf("Err:Reset\n"); break; //Connection was reset by remote host. case TCPSOCKET_OK: printf("Listening\n"); break; //Success. } // Timer tmr; //tmr.start(); if(accepted) { Net::poll(); } while(!readable) { Net::poll(); } }#########3 This is the result of the Sender/receiver#########Here is the packet dump on the sender/receiver####
