One of the features of my project is a serial pass-through connecting the USB serial input port (connected to the PC) to the serial output port on p9 (connects to another device).
Initially, I was using the "Dev::HandleUSBSerial()" ISR in the code snippet below to handle passing through the data, and all was well. But then I wanted to add some logging to the pass through (the "fSnoop.Listen( ch );" line) and it stopped working reliably - it looks like characters are getting dropped after just a few dozen bytes.
The serial ports are operating at just 9600 baud, so I'd think the ARM chip can easily handle stashing the data. Any ideas? As an alternative, I could buffer all of the data before I transmit it; but figuring out when the input stream has stopped is a bit tricky. Is there much overhead to resetting timers?
Thanks,
jp
const int kBufferMax = 600;
class Snoop {
public:
void Listen( const uint8_t ch );
private:
uint8_t fBuffer[kBufferMax];
int fBufferIndex, fLastBufferIndex;
void Snoop::Listen( uint8_t ch )
if (fBufferIndex >= kBufferMax)
fBufferIndex = 0;
fBuffer[fBufferIndex++] = ch;
class Dev {
public:
void AttachUSBSerial();
private:
Snoop fSnoop;
void HandleUSBToLights();
Serial fPort;
Serial fUSBPort;
void Dev::AttachUSBSerial()
fUSBPort.attach( this, &Dev::HandleUSBSerial );
void Dev::HandleUSBSerial()
while (fUSBPort.readable())
uint8_t ch = fUSBPort.getc();
fPort.putc( ch );
// Adding this line causes serial com to fail?!?
Thanks, jp
#include "mbed.h" const int kBufferMax = 600; class Snoop { public: ... void Listen( const uint8_t ch ); private: ... uint8_t fBuffer[kBufferMax]; int fBufferIndex, fLastBufferIndex; }; void Snoop::Listen( uint8_t ch ) { if (fBufferIndex >= kBufferMax) fBufferIndex = 0; fBuffer[fBufferIndex++] = ch; } class Dev { public: ... void AttachUSBSerial(); private: ... Snoop fSnoop; void HandleUSBToLights(); Serial fPort; Serial fUSBPort; }; void Dev::AttachUSBSerial() { fUSBPort.attach( this, &Dev::HandleUSBSerial ); } void Dev::HandleUSBSerial() { while (fUSBPort.readable()) { uint8_t ch = fUSBPort.getc(); fPort.putc( ch ); // Adding this line causes serial com to fail?!? fSnoop.Listen( ch ); } }
