DS1620 CLK problem
05 Jun 2009
the project is DS1620(Digital Thermometer and Thermostat),the problem is how can control the CLK?use PWM?
anybody has any idea?
Thanks a lot!
SHF
05 Jun 2009 . Edited: 05 Jun 2009
This might not be that helpful, especially if you already have the DS1620 part, but I've already done something pretty similar with the MAX6662:
http://mbed.co.uk/projects/cookbook/wiki/SPIThermometer
Having said this, it looks pretty similar to the MAX6662. Instead of driving CS low, you drive RST high, and then use SPI as you would for MAX6662
http://datasheets.maxim-ic.com/en/ds/DS1620.pdf
http://datasheet.digchip.com/280/280-20345-0-MAX6662.pdf
HTH,
Chris
16 Jun 2009
Based on my experience of DS1620 many years ago, I didn't think there was any minimum limit on clock frequency, so I'd just drive CLK using GPIO as per the rest of the 3-wire interface.
hth
s.
19 Jun 2009
The LM75 will give a thermometer and threshold function but uses I2C....
