Parallax COLORPAL
16 Mar 2011
The following code works with the Parallax color sensor COLORPAL (#28380) I didn't reset the device.
SerialHalfDuplex RGB_master(p9, p10); // this is the color sensor
In the code
 // RGB comm rate
     RGB_master.baud(2400);
     RGB_master.format(8,Serial::None,2);
 // To Read and format as 24 bit RGB in 32 bits
     RGB_master.putc('=');
     RGB_master.putc('m');
     RGB_master.putc('!');
     c1=RGB_master.getc(); // R
     if((c1-'A') >= 0) color = c1-'A'; else color = c1-'0';
     color = color << 4;
     if((c1-'A') >= 0) color += c1-'A'; else color += c1-'0';
     color = color << 4;
     c1=RGB_master.getc();  // discard since we have 8 bits of color
     c1=RGB_master.getc(); // G
     color = color << 4;
     color = color << 4;
     c1=RGB_master.getc(); // B
     color = color << 4;
     color = color << 4;
As time permits, I will wrap and put in a library
13 Aug 2011
Hello. I was wondering, how did you find the color accuracy of this sensor?
