I'd like to declare a library function (EthernetNetIf) in one of two ways, according to whether a "dhcpenable" flag is set or not.
If the flag is set, the library should be declared simply as
Whereas, if the flag is not set, then I need to declare it in the following way:
EthernetNetIf eth(
IpAddr(192,168,1,158), //IP Address
IpAddr(255,255,255,0), //Network Mask
IpAddr(192,168,1,254), //Gateway
IpAddr(192,168,1,2) //DNS
The required form is not known until run time, which means that these declarations have to live inside an executable routine. I can't put them in a static header, as is normally done.
While the compiler is OK with a library declaration inside an executable routine, it gets very unhappy when a library declaration is prefaced by a conditional test.
If a condition precedes the library declaration, the library declaration seems to be ignored by the compiler. The first reference to one of its members gives a compiler error. The following, for example, does not work:
#include "EthernetNetIf.h"
int dhcpenable = 1;
if(dhcpenable) EthernetNetIf eth();
else {
EthernetNetIf eth(
EthernetErr ethErr = eth.setup();
if(!ethErr) printf("Setup OK\r\n");
The resulting compiler error says that "Identifier 'eth' is undefined (E20)".
I was able to distill this compiler behavior into the following simple test programs:
// This compiles cleanly
DigitalOut myled(LED1);
myled = !myled;
//This generates a compiler error
if(1) DigitalOut myled(LED1);
myled = !myled;
The top case compiles cleanly; the bottom case generates an "undefined identifier" error for myled.
Any suggestions on how to work around this?
EthernetNetIf eth( IpAddr(192,168,1,158), //IP Address IpAddr(255,255,255,0), //Network Mask IpAddr(192,168,1,254), //Gateway IpAddr(192,168,1,2) //DNS );The required form is not known until run time, which means that these declarations have to live inside an executable routine. I can't put them in a static header, as is normally done.
#include "mbed.h" #include "EthernetNetIf.h" int main() { int dhcpenable = 1; if(dhcpenable) EthernetNetIf eth(); else { EthernetNetIf eth( IpAddr(192,168,1,158), //IP Address IpAddr(255,255,255,0), //Network Mask IpAddr(192,168,1,254), //Gateway IpAddr(192,168,1,2) //DNS ); } EthernetErr ethErr = eth.setup(); if(!ethErr) printf("Setup OK\r\n"); }The resulting compiler error says that "Identifier 'eth' is undefined (E20)".
// This compiles cleanly #include "mbed.h" int main() { DigitalOut myled(LED1); myled = !myled; }//This generates a compiler error #include "mbed.h" int main() { if(1) DigitalOut myled(LED1); myled = !myled; }The top case compiles cleanly; the bottom case generates an "undefined identifier" error for myled.
