Problems with electronic drive control unit
02 Feb 2011
I'm building a model car. The function of the servo is not a problem and this works well. However, I have problems with motor control. To this end I have an electronic drive control unit. This is connected to the battery and the motor. A three-core cable is still on for the voltage supply of 5.0V and white core for the control signal. With this I run the mbed and the servo to steer the vehicle. I have only the value of the frequency (1 kHz)of the electronic drive control unit. I have now occupied the pin 21 if it were a servo, I get a good PWM signal, which I measured with the oscilloscope. The power required on first use back to neutral. But how can I do that? The variable of the servo is 0 does not put up enough. Furthermore, the drive electronic control unit does not work, the engine has no function. Or do I have here to switch to PPM? If so, how?
The manual of the is attached /media/uploads/BastlWastl/206963-an-01-ml-elektronischer_fahrtregler_de_en_fr_nl.pdf .
http://www.conrad.de/ce/de/product/206963/CARBON-SERIES-FAHRTREGLER-15-TURNS/SHOP_AREA_32305&promotionareaSearchDetail=005
Thanks for all help!
03 Feb 2011
Hello Sebastian, the regulator try to detect the neutral signal when switched on. You have to set the servo on pin 21 to 50% before turn on the regulator.
Turn on you transmitter (check the status of the battery or the rechargeable battery!) Place the trim regulator in the centre position; place the throttle lever in the neutral position. • The switch drive control unit switch must be set to the "OFF" position.
Peter
