main,.cpp
#include "MDM.h"
#define SIMPIN      "0000"
#define APN         "gprs.swisscom.ch"
#define USERNAME    NULL
#define PASSWORD    NULL
const char* SERVER_ADDRESS = "httpbin.org";
const int SERVER_PORT = 443;
#include "mbedtls/ssl.h"
#include "mbedtls/entropy.h"
#include "mbedtls/ctr_drbg.h"
#include "mbedtls/debug.h"
#define GET_REQUEST "POST /post HTTP/1.0\r\nContent-Type: text/plain\r\nContent-Length: 11\r\n\r\nHello World\r\n"
struct MDMSocketConnection {
    MDMSerial* mdm;
    int socket;
int sendWrapper(void* mdmSockConPtr, const unsigned char* buf, size_t length) {
    MDMSocketConnection* mdmSockCon = (MDMSocketConnection *) mdmSockConPtr;
    return mdmSockCon->mdm->socketSend(mdmSockCon->socket, (const char *)buf, (int) length);
int recvWrapper(void* mdmSockConPtr, unsigned char* buf, size_t length) {
    return mdmSockCon->mdm->socketRecv(mdmSockCon->socket, (char *)buf, (int) length);
static void my_debug( void *ctx, int level,
                      const char *filename, int line, const char *msg )
    printf("%s:%04d: %s", filename, line, msg );
    mbedtls_entropy_context entropy;
    mbedtls_ctr_drbg_context ctr_drbg;
    mbedtls_ssl_context ssl;
    mbedtls_ssl_config conf;
    mbedtls_x509_crt caCert;
    int ret;
    // Initialize the modem
    MDMSocketConnection mdmSockCon;
    MDMSerial mdm;
    mdmSockCon.mdm = &mdm;
    MDMParser::DevStatus devStatus = {};
    MDMParser::NetStatus netStatus = {};
    bool mdmOk = mdm.init(SIMPIN, &devStatus);
    mdm.dumpDevStatus(&devStatus);
    mdmOk = mdm.registerNet(&netStatus);
    mdm.dumpNetStatus(&netStatus);
    MDMParser::IP ip = mdm.join(APN,USERNAME,PASSWORD);
    int socket = mdm.socketSocket(MDMParser::IPPROTO_TCP);
    mdmSockCon.socket = socket;
    mdm.dumpIp(ip);
    // Connect to Server
    while (mdm.socketConnect(socket, SERVER_ADDRESS, SERVER_PORT) == false) {
        printf("Unable to connect to %s:%d\n", SERVER_ADDRESS, SERVER_PORT);
        wait(1);
    printf("Connected to Server at %s:%d\n",SERVER_ADDRESS, SERVER_PORT);
    // Configure SSL/TLS
    mbedtls_ssl_init( &ssl );
    mbedtls_ssl_config_init( &conf );
    mbedtls_x509_crt_init( &caCert );
    mbedtls_ctr_drbg_init( &ctr_drbg );
    mbedtls_entropy_init( &entropy );
    if ( ( ret = mbedtls_entropy_self_test(1)) != 0) {
            printf("Error: mbedtls_entropy_self_test failed!\n");
            return 0;
    if( ( ret = mbedtls_ctr_drbg_seed( &ctr_drbg, mbedtls_entropy_func, &entropy,
                               NULL,
                               0 ) ) != 0 )
        printf( "Error: mbedtls_ctr_drbg_seed returned %d\n", ret );
        return 0;
    if( ( ret = mbedtls_ssl_config_defaults( &conf,
                MBEDTLS_SSL_IS_CLIENT,
                MBEDTLS_SSL_TRANSPORT_STREAM,
                MBEDTLS_SSL_PRESET_DEFAULT ) ) != 0 )
        printf( "Error: mbedtls_ssl_config_defaults returned %d\n", ret );
        return 0;
    mbedtls_ssl_conf_authmode(&conf, MBEDTLS_SSL_VERIFY_NONE); // TODO: add certificate checking
    mbedtls_ssl_conf_rng( &conf, mbedtls_ctr_drbg_random, &ctr_drbg );
    mbedtls_ssl_conf_dbg( &conf, my_debug, stdout );
    if( ( ret = mbedtls_ssl_set_hostname( &ssl, "mbed TLS Server 1" ) ) != 0 )
        printf( "Error: mbedtls_ssl_set_hostname returned %d\n", ret );
        return 0;
    mbedtls_ssl_set_bio( &ssl, &mdmSockCon, sendWrapper, recvWrapper, NULL );
    if ((ret = mbedtls_ssl_handshake(&ssl)) != 0) {
        printf( "Error: mbedtls_ssl_handshake returned %d\n", ret );
        return 0;
    // Send message to server
    const unsigned char hello[] = "POST /post HTTP/1.0\r\nContent-Type: text/plain\r\nContent-Length: 11\r\n\r\nHello World\r\n";
    printf("Sending  message to Server : '%s' (%d bytes)...",hello, sizeof(hello)-1);
    ret = mbedtls_ssl_write(&ssl, hello, sizeof(hello)-1);
    printf("done. Sent %d bytes.\r\n", ret);
    // Receive message from server
    int bufLen = 1024;
    unsigned char buf[bufLen];
    printf("Receiving message from server (up to %d bytes)...\r\n", bufLen);
    ret = mbedtls_ssl_read(&ssl, buf, bufLen);
    buf[ret] = '\0';
    printf("Received message from server: '%s' (%d bytes read)\r\n", buf, ret);
    // Clean up
    mbedtls_ssl_close_notify(&ssl);
    mdm.socketClose(socket);
    mbedtls_ssl_free( &ssl );
    mbedtls_ssl_config_free( &conf );
    mbedtls_ctr_drbg_free( &ctr_drbg );
    mbedtls_entropy_free( &entropy );
    mdm.socketFree(socket);
    mdm.disconnect();
ARM recently announced mbed TLS 2.1.0 which is available at https://tls.mbed.org/
Since I'm new to mbed I cannot figure out on how to use this library to send data to a HTTPS server (using PUT). Can anyone please explain to me how to use the library from within the mbed online compiler? I'm using a u-blox C027 platform.
Thanks for any help, Christoph
