It looks like a line of code got dropped from sendRC5code(). The "togglebit" part of the preamble isn't being sent. Shouldn't the code be:
void sendRC5code(int togglebit, unsigned int adres, unsigned int commando) {
int copyadres;
int copycommando;
RC5sendbit(1); //startbit 1
RC5sendbit(1); //extra commandbit, leave it 1
RC5sendbit(togglebit); // toggle bit finishes preamble
//5 data bits from the adres:
adres = adres & 0x1F; //1F = b00011111
etc...
An alternative approach, by the way, would be to use a PWM output set to 36KHz. You could then just set the duty cycle
to zero to turn off the IR signal, and set it to 50% (or, better yet, 33% per the spec) to turn the IR signal on.
It seems like that would have less overhead than attaching and detaching a ticker function. Just a thought.
Hi everybody
I am trying to send RC5 codes using my mBed. Bits are transmitted using a 36kHz carrier. To get this carrier, I used a ticker and set it to a time of 14uS. I attach or detach this carrier to send bits. I use the following code, but it doesn't work...
Does anyone have a clue what I'm doing wrong?
#include "mbed.h" DigitalOut RC5led(p22); Ticker RC5carrier; //TV Address: 0 //Code 0-9: buttons 0-9 void toggleRC5led() { //function that toggles the led for the 36KHz carrier RC5led=!RC5led; } void RC5sendbit(int rc5bit) { //Function to transmit a bit //36kHz: ((1 / 36 000) * (10^6)) / 2 = 13.8888889µS if (rc5bit == 0) { //Logic 0: 36kHz Carrier 889µS on, 889µS off RC5carrier.attach_us(&toggleRC5led, 14); wait_us(889); //Wait 889µS RC5carrier.detach(); wait_us(889); RC5led = 0; } else { //Logic 1: Carrier 889µS off, 889uS on wait_us(889); RC5carrier.attach_us(&toggleRC5led, 14); wait_us(889); RC5led = 0; } } void sendRC5code(int togglebit, unsigned int adres, unsigned int commando) { int copyadres; int copycommando; RC5sendbit(1); //startbit 1 RC5sendbit(1); //extra commandbit, leave it 1 //5 data bits from the adres: adres = adres & 0x1F; //1F = b00011111 copyadres = (adres & 0x10) >>4; RC5sendbit(copyadres); copyadres = (adres & 0x08) >>3; RC5sendbit(copyadres); copyadres = (adres & 0x04) >>2; RC5sendbit(copyadres); copyadres = (adres & 0x02) >>1; RC5sendbit(copyadres); copyadres = adres & 0x01; RC5sendbit(copyadres); //6 data bits from the command: commando = commando & 0x3F; //3F = b00111111 copycommando = (commando & 0x20) >>5; RC5sendbit(copycommando); copycommando = (commando & 0x10) >>4; RC5sendbit(copycommando); copycommando = (commando & 0x08) >>3; RC5sendbit(copycommando); copycommando = (commando & 0x04) >>2; RC5sendbit(copycommando); copycommando = (commando & 0x02) >>1; RC5sendbit(copycommando); copycommando = commando & 0x01; RC5sendbit(copycommando); } int main() { int togglebit; while(1) { togglebit = 1; sendRC5code(togglebit, 0, 5); //Send command 5 to address 0 wait(0.5); togglebit = 0; sendRC5code(togglebit, 0, 6); //Send command 6 to address 0 wait(0.5); } }Thanks in advance!
