Hi, I've looked at the AnalogIn class documentation and header file, but it is not clear to me when the analog read is actually done. In the example code it looks like simply checking the value reads it (i.e. if(temperature > 0.5)...), but what is the read() function for then?
Is the code for the library available or just the header files?
Moses, can you provide a link to the sample code you're talking about?
When you declare an AnalogIn object, you can use the object itself in an expression without referring to any of the member functions. In this context that use is equivalent to calling the read() function.
AnalogIn temperature(p20);
if(temperature > 0.5) {
printf("Too hot! (%f)", temperature.read());
And I'll give it a try. Using temperature by itself is the same as using
temperature.read() So, it seems to me like it's actually reading the analog
value twice. In general bad code. It could read at the 'if' statement and get
an answer of .51 (causing the printf to execute. Then during the printf it reads
again and gets .49, thereby displaying "Too hot! .49"
That's the sample code I was refering to, and I agree that it is bad code. That was part of what was confusing me. Looks like you're right - I see now the "operator float()" in the header file. I had missed that before.
Thanks!
Important Information for this Arm website
This site uses cookies to store information on your computer.
By continuing to use our site, you consent to our cookies.
If you are not happy with the use of these cookies, please review our
Cookie Policy
to learn how they can be disabled.
By disabling cookies, some features of the site will not work.
Access Warning
You do not have the correct permissions to perform this operation.
Thanks,
Moses
