I have a Sparkfun 2x16 serial LCD, and I was trying to change the baud rate over the weekend, but I couldn't get it to work.
I wondered if anyone's done it?
I'll try and knock up an example of what I think I should be doing, that fails when I'm back with the mbed & LCD.
Serial lcd(p9, p10);
lcd.printf("test");
lcd.putc(0x7C); // command char
lcd.putc(0x0E); // ctrl-N = 14400 baud from the SerLCD_V2_5 pdf
lcd.baud(14400); //change baud
lcd.printf("test");
What often happens is that "testte" gets displayed, which is odd, and sometimes I was playing I'd just get garbage ascii chars up.
I tried it with a wait(1) before the lcd.baud call, but that didn't seem to make a difference.
(here's a link to the spec sheet from Sparkfun http://www.sparkfun.com/datasheets/LCD/SerLCD_V2_5.PDF )
Serial lcd(p9, p10); lcd.printf("test"); lcd.putc(0x7C); // command char lcd.putc(0x0E); // ctrl-N = 14400 baud from the SerLCD_V2_5 pdf lcd.baud(14400); //change baud lcd.printf("test");What often happens is that "testte" gets displayed, which is odd, and sometimes I was playing I'd just get garbage ascii chars up.
