Hi all,
I'm using Mbed on SDP-K1 in order to send DMX512 frames through UART1.
During the process, I change the baud rate of the UART with the Serial::baud() function, between two data transmission.
Unfortunately, it's looks like the baud rate change doesn't take effect.
Here's a section of the code I used to test baud rate change :
Code
while(true) {
DMX_serial.baud(80000);
DMXWriteFrame(0);
DMX_serial.baud(250000);
DMXWriteFrame(START_FRAME);
DMXWriteFrame(_data_dmx[0]);
DMXWriteFrame(_data_dmx[1]);
led2 = !led2;
//DMXWriteFrame(a++);
wait_ms(SLEEP_TIME);
When I look the frames with a scope, all data are transferred with the 250000 baud rate.
Do you have any suggestion ?
Valentin
Hi all,
During the process, I change the baud rate of the UART with the Serial::baud() function, between two data transmission. Unfortunately, it's looks like the baud rate change doesn't take effect.
Code
while(true) { DMX_serial.baud(80000); DMXWriteFrame(0); DMX_serial.baud(250000); DMXWriteFrame(START_FRAME); DMXWriteFrame(_data_dmx[0]); DMXWriteFrame(_data_dmx[1]); led2 = !led2; //DMXWriteFrame(a++); wait_ms(SLEEP_TIME); }When I look the frames with a scope, all data are transferred with the 250000 baud rate.
Valentin
