The Standard baud rates Comes from the sixties.
The baudrates are multiply from 75 baud
75*1 = 75 baud
75*2 = 150 baud
75*4 = 300 baud
The 110 baud comes from the old acoustic coupler modem
But there are not common baudrates like MIDI with a baud rate of 31250.
The max baud rate of the most serial ports and usb to serial ports is 115200.
230400, 460800 and 921600 is not availlable at the most usb to serial ports.
Older serial ports goes up to 57600 baud
But for long cables the max baud rates is lower.
Then it depends on the voltage level. Valid signals detected > +3V and < -3V.
The common voltage is +15V and -15V but some serial ports are only driven by +-8V or some driven at +-5V
So you must check the cable length, cable quality and the voltage level to define the max baud rate.
I had a look around the site and did not find an answer...
What is the maximum baud rate for serial communications? I need to send a lot of data at a high speed over USB. I'm going to use the built in USB or FTDI serial to USB converter chips. I did some experimenting and it seems like the maximum baud rate that the mBed supports is 115200 (v24 of library).
I want to send at USB speeds of at least 1.5Mbps. Is this even possible with the mBed over serial? What is the maximum baud rate?Thanks.
