http://www.sparkfun.com/commerce/product_info.php?products_id=8161
Has anyone bought this pressure sensor? I have problems with the SPI communication.
Forgive me for my lack of Knowledge. (both English and electronics)
I have found a code which is known to have worked in the arduino:
My idea is to translate this code to mbed
Arduino code:
//--------------1-------------------------
// define spi bus pins
#define SLAVESELECT 10 //nuestro pin 8
#define SPICLOCK 13 // nuestro pin 7
#define DATAOUT 11 //MOSI nuestro pin 5
#define DATAIN 12 //MISO nuestro pin 6
#define UBLB(a,b) ( ( (a) << 8) | (b) )
#define UBLB19(a,b) ( ( (a) << 16 ) | (b) )
//---------------2----------------------
//Addresses
#define REVID 0x00 //ASIC Revision Number
#define OPSTATUS 0x04 //Operation Status
#define STATUS 0x07 //ASIC Status
#define START 0x0A //Constant Readings
#define PRESSURE 0x1F //Pressure 3 MSB
#define PRESSURE_LSB 0x20 //Pressure 16 LSB
#define TEMP 0x21 //16 bit temp
//---------------3-----------------------
char rev_in_byte;
int temp_in;
unsigned long pressure_lsb;
unsigned long pressure_msb;
unsigned long temp_pressure;
unsigned long pressure;
//---------------4-----------------------
void setup()
byte clr; // arduino command
pinMode(DATAOUT, OUTPUT); //nuestro pin 5
pinMode(DATAIN, INPUT); // nuestro pin 6
pinMode(SPICLOCK,OUTPUT); // nuestro pin 7
pinMode(SLAVESELECT,OUTPUT); // nuestro pin 8
digitalWrite(SLAVESELECT,HIGH); //disable device hacemos lo mismo con cs = 1;
SPCR = B01010011; //MPIE=0, SPE=1 (on), DORD=0 (MSB first), MSTR=1 (master), CPOL=0 (clock idle when low), CPHA=0 (samples MOSI on rising edge), SPR1=0 & SPR0=0 (500kHz)
clr=SPSR;
clr=SPDR;//para limpiar el buffer
delay(10);
Serial.begin(9600);
delay(500);
Serial.println("Initialize High Speed Constant Reading Mode");
write_register(0x03,0x09);
void loop()
rev_in_byte = read_register(REVID);
pressure_msb = read_register(PRESSURE);
pressure_msb &= B00000111;
pressure_lsb = read_register16(PRESSURE_LSB);
pressure = UBLB19(pressure_msb, pressure_lsb);
pressure /= 4;
Serial.print("PRESSURE [");
Serial.print(pressure, DEC);
Serial.println("]");
temp_in = read_register16(TEMP);
temp_in = temp_in / 20;
temp_in = ((1.8) *temp_in) + 32;
Serial.print("TEMP F [");
Serial.print(temp_in , DEC);
delay(1500);
//-----------------------5------------------------
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<<= 2;
register_name &= B11111100; //Read command
digitalWrite(SLAVESELECT,LOW); //Select SPI Device
spi_transfer(register_name); //Write byte to device
in_byte = spi_transfer(0x00); //Send nothing, but we should get back the register value
delay(10);
return(in_byte);
//---------------------7---------------------------
float read_register16(char register_name)
byte in_byte1;
byte in_byte2;
float in_word;
register_name <<= 2;
in_byte1 = spi_transfer(0x00);
in_byte2 = spi_transfer(0x00);
in_word = UBLB(in_byte1,in_byte2);
return(in_word);
//-----------------------8----------------------------
void write_register(char register_name, char register_value)
register_name |= B00000010; //Write command
digitalWrite(SLAVESELECT,LOW); //Select SPI device
spi_transfer(register_name); //Send register location
spi_transfer(register_value); //Send value to record into register
And this is my try to translate de code:
//---------------1-------------------------
SPI spi(p5, p6, p7); // mosi, miso, sclk
DigitalOut cs(p8);
//-----------------2------------------------
//Addresses
char rev_in_byte;
int temp_in;
//-----------------4------------------------
cs=1;
pc.baud(921600);
spi.frequency(500000); // the fastest of the sensor
spi.format(8, 0); // duda son dos palabras de 8 bits?
wait(0.5);
pc.printf("Initialize High Speed Constant Reading Mode");
// pressure_msb &= B00000111; -----arduino read command
pressure /= 4;
pc.printf("PRESSURE [");
pc.printf(pressure, DEC);
pc.printf("]");
pc.printf("TEMP F [");
pc.printf(temp_in , DEC);
pc.printf("]");
wait(1500);
//------------------------5---------------------
spi.write(data);
//------------------------6----------------------
char read_register(char register_name)
char in_byte;
// register_name &= B11111100; -----arduino read command
cs=0; //Select SPI Device
cs=1;
wait(10);
return in_byte;
//------------------------7------------------------
byte in_byte1;
byte in_byte2;
float in_word;
cs=1;
return in_word;
// register_name |= B00000010; -----arduino write command
cs=0; //Select SPI device
cs=1;
I have no idea of what "register_name |= B00000010;" does and how can I
do the same thing with mbed.
However, I now I am a bit ambitious for my knowledge. So I tryed a simplier
program.
I want to call for the temperature, recieve the hex number (16 bits) and print
it in the computer screen.
I give some pictures of the user guide that I think they have the most relevat
information.
My program:
DigitalOut cs(p8);
//Addresses
// Setup the spi for 8 bit data, high steady state clock,
// second edge capture, with a 500kHz clock rate
cs=1;
spi.format(8,0);
wait(1);
// Select the device by seting chip select low
cs = 0;
// Send 0x21
spi.write(TEMP);
// Send a dummy byte to receive the contents of the 0x21 register (16 bits)
int in_byte1 = spi.write(0x00);
int in_byte2 = spi.write(0x00);
cs=1;
pc.printf("ox%X",in_byte1);//------------------------------
pc.printf("ox%X",in_byte2);//---------------------------
and this is what I get:
ox7F (in_byte1)
oxFF (in_byte2)
0111-1111-1111-1111
If I do as the example in the guide:
xx11-1111-1111-1111
s=1 (bit pattern of a negative temperature data)
TEMPOUT inverted data = 00-0000-0000
So I don't receive any temperature!!!
Please!! I need help!!
Arduino code:
program.
information.
My program:
ox7F (in_byte1)
oxFF (in_byte2)
0111-1111-1111-1111
xx11-1111-1111-1111
