Beware that the docs for the Serial::writeable method claims that when there is space in the buffer, it will return a 1.
So, accordingly I wrote:
writeable doesn't work this way
if (Base_serial.writeable() == 1)
but I found that the condition never got hit. I printed the return value and discovered a surprising 32 result. I'm guessing that it is returning the current number of bytes available for write buffering. When I changed the code to:
writeable seems to work this way
if (Base_serial.writeable() > 0)
then it worked as I expected and data now flows. If you use ancient C coding techniques, it is common to treat an integer return as a boolean expression, and then this approach would make more sense. However, the more contemporary practice is to avoid these unexpected/sneaky conversions which hide information and sometimes cause problems.
MBED folks, please update the docs to reflect both what is actually happening and your intended usage of the interface. I think a better approach would be to deprecate the writeable method, and replace it with 2 new methods along these lines:
alternate suggestion
bool is_writeable(void);
int buffer_bytes_available(void);
Question: Does Serial::readable() do the same thing?
-Dan
-Dan
