Dear All,
We use the AndroidAccessory Library [1] to setup a USB communication between MBED and an Android device In our case the Android device is an Android TV stick, to be precise a Tronsmart MK808b with Android Jellybean 4.1.1 installed [2].
However, setting up the USB communication with Androids ADK gives some problems. When I want to build it and run it at the Android stick I get the following error message in the Android Development Tool (ADT) using the Android Debugging Bridge (ADB):
"Package com.test.demo requires unavailable shared library com.android.future.usb.accessory; failing!"
I don't get this message when I have connected a normal Samsung Galaxy S2 smartphone (Jellybean 4.1.2) instead of this Android TV Stick.
So I have the following questions for setting up the USB communication between the Android TV Stick and the MBED side:
(A) For the smartphone tested App - MBED USB communication, with use of the ADK, the App uses the 'com.android.future.usb.accessory' library. However, these USB accessories APIs are a Google APIs add-on library to backport it to models before Android 3.1, using an external library, namely the 'com.android.future.usb.accessory' library [3].
Has somebody managed to setup an Android - MBED USB communication using the built-in library (after Android 3.1), so the 'android.hardware.usb' library in combination with the MBED AndriodAccessory Library [1]? Is there a MBED library available with examples of this?
(B) Does somebody know how to check if the library 'com.android.future.usb.accessory' is available on the Android OS side? So to get a list of installed libraries?
R
[1] (http://mbed.org/users/p07gbar/code/AndroidAccessory/file/98fbe1660f0a/)
[2] Tronsmart MK808b with Finless ROM 1.6a, Android Jellybean 4.1.1
[3] http://developer.android.com/guide/topics/connectivity/usb/accessory.html#choosing
Dear All,
We use the AndroidAccessory Library [1] to setup a USB communication between MBED and an Android device In our case the Android device is an Android TV stick, to be precise a Tronsmart MK808b with Android Jellybean 4.1.1 installed [2]. However, setting up the USB communication with Androids ADK gives some problems. When I want to build it and run it at the Android stick I get the following error message in the Android Development Tool (ADT) using the Android Debugging Bridge (ADB):
(A) For the smartphone tested App - MBED USB communication, with use of the ADK, the App uses the 'com.android.future.usb.accessory' library. However, these USB accessories APIs are a Google APIs add-on library to backport it to models before Android 3.1, using an external library, namely the 'com.android.future.usb.accessory' library [3]. Has somebody managed to setup an Android - MBED USB communication using the built-in library (after Android 3.1), so the 'android.hardware.usb' library in combination with the MBED AndriodAccessory Library [1]? Is there a MBED library available with examples of this?
R
