Hi Folks,
I would like to pass an array of pins to a class so that I can create several instances of the same class on different IO pin. I have been programming in C for many years but C++ is still new to me.
I started out with a simple test in C to explore, but this used a global array and so is not very reusable:
Pin array test
DigitalOut ArrayOfDigitalOuts[3] = { (p9), (p10), (p11) };
void normal_c_pulse(unsigned int x)
ArrayOfDigitalOuts[x]=1; // pulse an IO pin high and then low
ArrayOfDigitalOuts[x]=0;
while(1)
normal_c_pulse(0); // pulse pin p9
normal_c_pulse(1); // pulse pin p10
normal_c_pulse(2); // pulse pin p11
Next I found out how to create a class and create an instance with a pin and rewrote the example above using a class:
Pin pulse class
class Test_One_Pin
private:
DigitalOut pin_A;
public:
Test_One_Pin(PinName A) : pin_A (A) {}
void pulse(void)
pin_A = 1;
pin_A = 0;
Test_One_Pin pulse1(p9);
Test_One_Pin pulse2(p10);
Test_One_Pin pulse3(p11);
while(1)
pulse1.pulse();
pulse2.pulse();
pulse3.pulse();
But what I actually want to do is pass several pins to the class and the number may vary for each instance. i.e these are row selects on a display and some displays have 1 row, some 2 and some 4.
Now being all new to this C++ stuff I tried this, but will not compile at the class / public code.
Test of passing an array of pins to pulse class
class Test_Array_Of_Pins
private:
DigitalOut *pin_array;
public:
Test_Array_Of_Pins(PinName *A) : pin_array(A) {}
void pulse(unsigned int x)
pin_array[x] = 1;
pin_array[x] = 0;
PinName SomePins[] = { p9, p10 , p11 };
PinName SomeOtherPins[] = { p12, p13, p14, p15 };
Test_Array_Of_Pins PulseGroupA( &SomePins[0] );
Test_Array_Of_Pins PulseGroupB( &SomeOtherPins[0] );
while(1)
PulseGroupA.pulse(0);
PulseGroupA.pulse(1);
PulseGroupA.pulse(2);
PulseGroupB.pulse(0);
PulseGroupB.pulse(1);
PulseGroupB.pulse(2);
PulseGroupB.pulse(3);
I hope these stripped down examples are clear and some one has a few moment to educate me so I know what I am doing wrong.
Thanks, Mark Leman
Hi Folks,
Pin array test
Pin pulse class
Thanks, Mark Leman
