I have this following code written ,I'm using the kl25z board so whats the catch about running GLCD with it an Ks0108 Driver compatible one is the library written for it prints left to right and right to left as default so I did this change then from there on it started on working all fine. but when I made the complete prototype circuitry it shows half screen and the other half is gone??
One reason this may happen is that because I have code written to display on GLCD screen on press of a designated button over a IR remote and when that button is pressed it activated some outputs which in turn take 5v to activate some TIP122 transistor NPN from the same source from where the GLCD takes power ,so then I checked for the voltage but its healthy steady @ 4.9v, so is it because of milliamps going to the GLCD then??
#include "KS0108.h"
#include "Arial12.h"
#include "SystemFont5x7.h"
#include "image.h"
#include "starting.h"
#include "brew.h"
#include "menu_stop.h"
#include "menu_alert.h"
#include "menu_status.h"
#include "menu_realview.h"
#include "menu_temp.h"
#include "ReceiverIR.h"
#include "ds1307.h"
#define TEMP_PIN PTC9
//--------------LCD connections-----------------------------//
// KS0108 (PinName _RST,PinName _DI, PinName _RW, PinName _E, PinName _CS1, PinName _CS2, PinName DB0, PinName DB1, PinName DB2, PinName DB3, PinName DB4, PinName DB5, PinName DB6, PinName DB7);
KS0108 display(PTC3,PTD6, PTE31, PTA17, PTC5, PTC4, PTA16, PTC17, PTC16, PTC13, PTC12, PTC11, PTC10, PTC6);
//--------------Timer's-------------------------------------//
Ticker flowmtr1_wait;//Timer totalflow1;
Timer LCDviewer; //Timer to timeout LCDviewing
//--------------IR configuration----------------------------//
ReceiverIR ir_rx(PTD4);
RemoteIR::Format format;
//--------------Serial OUTPUT to screen---------------------//
//--------------Interrupts----------------------------------//
InterruptIn flowmtr1(PTA5);
//--------------Variable Declaration's----------------------//
bool menu_alert = false, menu_realview = false, menu_status = false,
menu_temp = false, menu_stop = false, start = false, phase1 = false,
phase2 = false, phase3 = false, step1 = false, step2 = false, step3 = false, flowmeterON = false;
bool overflow = false, _heat_HLT = false, LCDviewing = false, MLT_diluting = false, kettleBOIL = false;
uint8_t buf[16];
volatile int NbTopsFan; //measuring the rising edges of the signal
int Calc;
int phase1RunCnt, phase2RunCnt, phaseRunCnt = 0, check_min, viewTIME, whichScreen, LCDiteration, kettleBoilingSTART;
//---------------I/O pin configurations---------------------//
DigitalOut v4(PTE29);//Valve 4 which is connected to MLT's T piping
DigitalOut v5(PTD0);//Valve 5 which is connected to Kettle piping
DigitalOut v6(PTD1);//Valve 6 which is connected to Kettle
DigitalOut v1(PTE20);//Valve 1 from which the water goes to HLT and is the valce connected to the tap
DigitalOut v3(PTE23);//Valve 3 which is connected to MLT's T piping
DigitalOut v2(PTE5); //Valve 2 which is connected to HLT
DigitalOut p1(PTD2);//1st pump
DigitalOut p2(PTE21);// 2nd pump
DigitalOut h1(PTE22);//HLT heater
DigitalOut h2(PTE30);//Kettle heater
AnalogIn overflow_HLT(PTB0); // overflow reader for the HLT tank
AnalogIn empty_MLT(PTB1); // Empty reader for the MLT tank
//----------------RTC---------------------------------------//
DS1307 my1307(PTE0,PTE1); // start DS1307 class and give it pins for connections of the DS1307 device
int sec = 0;
int min = 0;
int hours = 0;
int day = 0;
int date = 0;
int month = 0;
int year = 0;
//------------------Temp-Sensor------------------------------//
DigitalInOut temperature_pin(TEMP_PIN);
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
void rpm()
NbTopsFan++; //This function measures the rising and falling edge of the
bool HLT()
int flag = 0;
for(int i=0; i<10; i++) {
float Calc = overflow_HLT;
char HLT[10];
sprintf(HLT,"%.1f is ",Calc);
float check_[10];
check_[i] = Calc;
if (check_[i] == 0.0) {
flag++;
if(flag > 0) {
return(true);
} else {
return(false);
bool MLT()
int flag = 0;
float Calc = empty_MLT;
char HLT[10];
float check_[10];
check_[i] = Calc;
flag++;
if(flag > 0) {
return(true);
} else {
return(false);
void flowmtr1_counter()
flowmtr1.rise(NULL);
int save_it = (NbTopsFan * 60 / 7.5); //(Pulse frequency) / 7.5Q, = flow rate litre per second
Calc = Calc + save_it;
//char in[50];
//sprintf(in,"%d is ",Calc);
//pc.printf(in);
NbTopsFan = 0;
flowmtr1.rise(&rpm);
void test_rw(int test)
if (test == 0) pc.printf("Last R/W operaion passed!\n\r");
else pc.printf("Last R/W operation failed!\n\r");
void phase3_setup()
pc.printf("Phase 3 setup");
v4 = 0xff;
pc.printf("v4 off");
p2 = 0xff;
pc.printf("pump2 off");
MLT_diluting = 1;
void phase3_MLT_diluting_routine()
//If condition that turns the v4 and p2 OFF.
if (empty_MLT) {
pc.printf("Emptying MLT");
v4 = 0x00;
p2 = 0x00;
h2 = 0xff;
pc.printf("heater2 off");
test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year));
kettleBoilingSTART = min;
kettleBOIL = true;
void kettleBoilingRoutine()
if (kettleBoilingSTART + 60 == min) {
pc.printf("kettle boiling for 60 minutes done!");
h2=0x00;
p2=0x00;
v4=0x00;
void phase1_phase2_step3()
pc.printf("In phase1_phase2_step3");
v3 = 0xff;
v2 = 0x00;
p1 = 0xff;
check_min = min;
if (phase3 == false) {
step3 = true;
pc.printf("Step3 TRUE");
} else if(phase3 == true) {
phase3_setup();
pc.printf("phase3_setup()");
void flowmeter1(int qty)
if (Calc == qty) {
v2=0x00;
p1=0x00;
pc.printf("under flowmeter1 & call phase1_phase2_step3 ");
phase1_phase2_step3();
void phase1_step2()
v2 = 0xff;
p1 = 0xff;
flowmeterON = true;
pc.printf("_phase1_step2()_");
void waterValve()
pc.printf("In waterValve()");
phase1RunCnt++;
v1 = 0xff;
overflow = 1;
void phase1_phase2_step3_timecheck()
if(check_min + 30 == min) {
phaseRunCnt++;
if(phaseRunCnt == 1)phase1 = 0,phase2 = 1,phase3=0;
if(phaseRunCnt == 2)phase1 = 0,phase2 = 0,phase3=1;
//if(phaseRunCnt == 3)phase1 = 0,phase2 = 0,phase3=0;
pc.printf("_In phase1_phase2_step3_timecheck() DONE_");
waterValve();
step3 = 0;
void OneWireReset() // reset. Should improve to act as a presence pulse
temperature_pin.output();
temperature_pin = 0; // bring low for 500 us
wait_us(500);
temperature_pin.input();
wait_us(500);
void OneWireOutByte(unsigned char d) // output byte d (least sig bit first).
for(int n=8; n!=0; n--) {
if ((d & 0x01) == 1) { // test least sig bit
wait_us(5);
wait_us(60);
} else {
wait_us(60);
d=d>>1; // now the next bit is in the least sig bit position.
unsigned char OneWireInByte() // read byte, least sig byte first
unsigned char d = 0, b;
for (int n=0; n<8; n++) {
wait_us(5);
wait_us(5);
b = temperature_pin;
wait_us(50);
d = (d >> 1) | (b << 7); // shift d to right and insert b in most sig bit position
return d;
void _heat_check_HLT(int heat) //start retrieving temp from HLT tank
// sets the digital pin as input (logic 1) make sure external pullup resistor 4K7
OneWireReset();
OneWireOutByte( 0xcc); //Skip ROM command
OneWireOutByte( 0x44); // perform temperature conversion, strong pullup for one sec
OneWireReset();
OneWireOutByte( 0xbe); //Read Scratchpad
LowByte = OneWireInByte();
HighByte = OneWireInByte();
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) { // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) { // If its negative
pc.printf("-");
pc.printf("%d", Whole);
if(heat == Whole) {
h1 = 0x00;
phase1_step2();
if(phase3 == 1) {
pc.printf(".");
if (Fract < 10) {
pc.printf("0");
pc.printf("%d", Fract);
pc.printf("\r\n");
void overflow_check()
pc.printf("in overflow_check()");
if(HLT()) {
pc.printf("FILLED");
v1 = 0x00;
overflow = 0;
_heat_HLT = 1;
h1 = 0xff;
void LCDrunner()
display.FullScreenBMP(Menu_trial_startbut_Stop);
wait(2);
wait(2);
display.FullScreenBMP(Menu_trial_startbut_RealTimeView);
wait(2);
display.FullScreenBMP(Menu_trial_startbut_Alert);
wait(2);
display.FullScreenBMP(Menu_trial_startbut_Status);
wait(2);
void rtc()
pc.printf("seconds read are %.2D \n\r",sec);
pc.printf("min read are %.2D \n\r",min);
pc.printf("hour read are %.2D \n\r",hours);
pc.printf("day read are %.2D \n\r",day);
pc.printf("date read are %.2D \n\r",date);
pc.printf("month read are %.2D \n\r",month);
pc.printf("year read are %.2D \n\r",year);
pc.printf("SerPrinter");
void LCDcall()
if(whichScreen == 1) {
//temp alert
//phase alert
//overflow alert
if(LCDviewer.read() == 5) {
menu_alert = 0;
LCDviewing = 0;
LCDviewer.stop();
if(whichScreen == 2) {
LCDiteration++;
if(LCDiteration == 1) {
display.ClearScreen();
display.SelectFont(System5x7,BLACK,ReadData);
display.GotoXY(60,0);
if (overflow == 1) {
display.PrintString(" HLT filling");
display.GotoXY(1,0);
display.PrintString("up");
if(_heat_HLT == 1) {
if(phase1 == true) {
display.PrintString(" Heating HLT");
display.PrintString("to 122'F");
} else if(phase2 == true) display.PrintString(" Heating HLT to 154'F");
else if(phase3 == true) display.PrintString(" Heating HLT to 168'F");
if(step3 == true) {
display.PrintString(" In Step3 checking time");//phase1_phase2_step3_timecheck();
if(flowmeterON == true) {
if(phase1 == true)display.PrintString(" Filling water upto 20 quarts");
if(phase2 == true)display.PrintString(" Filling water upto 18 quarts");
if(phase3 == true)display.PrintString(" Filling water upto 20 quarts");
viewTIME = LCDviewer.read();
if(viewTIME == 5) {
menu_status = 0;
LCDviewing = 0;
LCDviewer.stop();
LCDviewer.reset();
LCDiteration = 0;
viewTIME = 0;
if(whichScreen == 4) {
LCDiteration++;
display.GotoXY(60,0); //(60, 0)
display.PrintString(" temp -");
display.GotoXY(1,0); //(60, 0)
display.PrintString("122");
if(viewTIME == 5) {
menu_temp = 0;
LCDviewing = 0;
LCDviewer.stop();
LCDviewer.reset();
viewTIME = 0;
LCDiteration = 0;
void IR_function(void)
if (ir_rx.getState() == ReceiverIR::Received) {
ir_rx.getData(&format, buf, sizeof(buf) * 16);
pc.printf("\n\rgot>> ");
for (int i=0; i<sizeof(buf); i++) {
pc.printf("0x%02X, ", buf[i]);
//pc.printf("%i",i);
if(menu_stop == true && buf[2] == 0x01) {
overflow = 0;
flowmeterON = 0;
step3 = 0;
_heat_HLT = 0;
pc.printf("Stopped");
display.FullScreenBMP(starts);
menu_stop = false;
buf[2] = NULL;
if(buf[2] == 0x01) {
start = 1;
waterValve();
pc.printf("Started");
menu_stop = true;
buf[2] = NULL;
if(buf[2] == 0x0A && start == 1 ) {//1 button
display.FullScreenBMP(Menu_trial_startbut_Temp);
menu_temp = 1, menu_status = 0, menu_alert = 0, menu_realview = 0;
_heat_check_HLT(122);
if(buf[2] == 0x1F && start == 1) {//3 button
menu_status = 1, menu_temp = 0, menu_alert = 0, menu_realview = 0;
if(buf[3] == 0xFF && start == 1) {//7 button
menu_alert = 1, menu_status = 0, menu_realview = 0, menu_temp = 0;
if(buf[2] == 0x19 && start == 1) {// 9 button
menu_realview = 1;
if(buf[2] == 0x04) {
for(int i=0; i<4; i++) {
if(menu_alert == 1) {
LCDviewing = 1;
whichScreen = 1;
LCDviewer.start();
if(menu_status == 1) {
LCDviewing = 1;
whichScreen = 2;
LCDviewer.start();
if(menu_realview == 1) {
LCDviewing = 1;
whichScreen = 3;
LCDviewer.start();
if(menu_temp == 1) {
LCDviewing = 1;
whichScreen = 4;
LCDviewer.start();
switch (format) {
case RemoteIR::UNKNOWN:
pc.printf("????");
break;
case RemoteIR::NEC:
pc.printf("NEC");
break;
case RemoteIR::AEHA:
pc.printf("AEHA");
break;
case RemoteIR::SONY:
pc.printf("SONY");
break;
display.FullScreenBMP(pic);
wait(2);
display.FullScreenBMP(brew1);
wait(2);
wait(2);
memset(buf, 0x00, sizeof(buf));
v5 = 0xff;
flowmtr1_wait.attach(&flowmtr1_counter, 1.0);
//LCDrunner();
IR_function();
//_heat_check_HLT(122);
if(overflow == 1) {
overflow_check();
h1 = 0xff;
} else if(phase2 == true) _heat_check_HLT(154);
else if(phase3 == true) _heat_check_HLT(168);
if(step3 == true) {
if(phase1 == true)flowmeter1(20);
if(phase2 == true)flowmeter1(18);
if(phase3 == true)flowmeter1(20);
if(LCDviewing == 1) {
LCDcall();
if(MLT_diluting == 1) {
phase3_MLT_diluting_routine();
if (kettleBOIL) {
kettleBoilingRoutine();
// Example of how to put Text on LCD
//display.DrawBitmap(mikro_test,5,5,BLACK);
#include "mbed.h" #include "KS0108.h" #include "Arial12.h" #include "SystemFont5x7.h" #include "image.h" #include "starting.h" #include "brew.h" #include "menu_stop.h" #include "menu_alert.h" #include "menu_status.h" #include "menu_realview.h" #include "menu_temp.h" #include "ReceiverIR.h" #include "ds1307.h" #define TEMP_PIN PTC9 //--------------LCD connections-----------------------------// // KS0108 (PinName _RST,PinName _DI, PinName _RW, PinName _E, PinName _CS1, PinName _CS2, PinName DB0, PinName DB1, PinName DB2, PinName DB3, PinName DB4, PinName DB5, PinName DB6, PinName DB7); KS0108 display(PTC3,PTD6, PTE31, PTA17, PTC5, PTC4, PTA16, PTC17, PTC16, PTC13, PTC12, PTC11, PTC10, PTC6); //--------------Timer's-------------------------------------// Ticker flowmtr1_wait;//Timer totalflow1; Timer LCDviewer; //Timer to timeout LCDviewing //--------------IR configuration----------------------------// ReceiverIR ir_rx(PTD4); RemoteIR::Format format; //--------------Serial OUTPUT to screen---------------------// Serial pc(USBTX, USBRX); // tx, rx //--------------Interrupts----------------------------------// InterruptIn flowmtr1(PTA5); //--------------Variable Declaration's----------------------// bool menu_alert = false, menu_realview = false, menu_status = false, menu_temp = false, menu_stop = false, start = false, phase1 = false, phase2 = false, phase3 = false, step1 = false, step2 = false, step3 = false, flowmeterON = false; bool overflow = false, _heat_HLT = false, LCDviewing = false, MLT_diluting = false, kettleBOIL = false; uint8_t buf[16]; volatile int NbTopsFan; //measuring the rising edges of the signal int Calc; int phase1RunCnt, phase2RunCnt, phaseRunCnt = 0, check_min, viewTIME, whichScreen, LCDiteration, kettleBoilingSTART; //---------------I/O pin configurations---------------------// DigitalOut v4(PTE29);//Valve 4 which is connected to MLT's T piping DigitalOut v5(PTD0);//Valve 5 which is connected to Kettle piping DigitalOut v6(PTD1);//Valve 6 which is connected to Kettle DigitalOut v1(PTE20);//Valve 1 from which the water goes to HLT and is the valce connected to the tap DigitalOut v3(PTE23);//Valve 3 which is connected to MLT's T piping DigitalOut v2(PTE5); //Valve 2 which is connected to HLT DigitalOut p1(PTD2);//1st pump DigitalOut p2(PTE21);// 2nd pump DigitalOut h1(PTE22);//HLT heater DigitalOut h2(PTE30);//Kettle heater AnalogIn overflow_HLT(PTB0); // overflow reader for the HLT tank AnalogIn empty_MLT(PTB1); // Empty reader for the MLT tank //----------------RTC---------------------------------------// DS1307 my1307(PTE0,PTE1); // start DS1307 class and give it pins for connections of the DS1307 device int sec = 0; int min = 0; int hours = 0; int day = 0; int date = 0; int month = 0; int year = 0; //------------------Temp-Sensor------------------------------// DigitalInOut temperature_pin(TEMP_PIN); int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract; //-----------------------------------------------------------// void rpm() { NbTopsFan++; //This function measures the rising and falling edge of the } bool HLT() { int flag = 0; for(int i=0; i<10; i++) { float Calc = overflow_HLT; char HLT[10]; sprintf(HLT,"%.1f is ",Calc); float check_[10]; check_[i] = Calc; if (check_[i] == 0.0) { flag++; } } if(flag > 0) { return(true); } else { return(false); } } bool MLT() { int flag = 0; for(int i=0; i<10; i++) { float Calc = empty_MLT; char HLT[10]; sprintf(HLT,"%.1f is ",Calc); float check_[10]; check_[i] = Calc; if (check_[i] == 0.0) { flag++; } } if(flag > 0) { return(true); } else { return(false); } } void flowmtr1_counter() { flowmtr1.rise(NULL); int save_it = (NbTopsFan * 60 / 7.5); //(Pulse frequency) / 7.5Q, = flow rate litre per second Calc = Calc + save_it; //char in[50]; //sprintf(in,"%d is ",Calc); //pc.printf(in); NbTopsFan = 0; flowmtr1.rise(&rpm); } void test_rw(int test) { if (test == 0) pc.printf("Last R/W operaion passed!\n\r"); else pc.printf("Last R/W operation failed!\n\r"); } void phase3_setup() { pc.printf("Phase 3 setup"); v4 = 0xff; pc.printf("v4 off"); p2 = 0xff; pc.printf("pump2 off"); MLT_diluting = 1; } void phase3_MLT_diluting_routine() { //If condition that turns the v4 and p2 OFF. if (empty_MLT) { pc.printf("Emptying MLT"); v4 = 0x00; pc.printf("v4 off"); p2 = 0x00; pc.printf("pump2 off"); h2 = 0xff; pc.printf("heater2 off"); test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year)); kettleBoilingSTART = min; kettleBOIL = true; } } void kettleBoilingRoutine() { test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year)); if (kettleBoilingSTART + 60 == min) { pc.printf("kettle boiling for 60 minutes done!"); h2=0x00; p2=0x00; v4=0x00; } } void phase1_phase2_step3() { pc.printf("In phase1_phase2_step3"); v3 = 0xff; v2 = 0x00; p1 = 0xff; test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year)); check_min = min; if (phase3 == false) { step3 = true; pc.printf("Step3 TRUE"); } else if(phase3 == true) { phase3_setup(); pc.printf("phase3_setup()"); } } void flowmeter1(int qty) { if (Calc == qty) { v2=0x00; p1=0x00; pc.printf("under flowmeter1 & call phase1_phase2_step3 "); phase1_phase2_step3(); } } void phase1_step2() { v2 = 0xff; p1 = 0xff; flowmeterON = true; pc.printf("_phase1_step2()_"); } void waterValve() { pc.printf("In waterValve()"); phase1RunCnt++; v1 = 0xff; overflow = 1; } void phase1_phase2_step3_timecheck() { test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year)); if(check_min + 30 == min) { phaseRunCnt++; if(phaseRunCnt == 1)phase1 = 0,phase2 = 1,phase3=0; if(phaseRunCnt == 2)phase1 = 0,phase2 = 0,phase3=1; //if(phaseRunCnt == 3)phase1 = 0,phase2 = 0,phase3=0; pc.printf("_In phase1_phase2_step3_timecheck() DONE_"); waterValve(); step3 = 0; } } void OneWireReset() // reset. Should improve to act as a presence pulse { temperature_pin.output(); temperature_pin = 0; // bring low for 500 us wait_us(500); temperature_pin.input(); wait_us(500); } void OneWireOutByte(unsigned char d) // output byte d (least sig bit first). { for(int n=8; n!=0; n--) { if ((d & 0x01) == 1) { // test least sig bit temperature_pin.output(); temperature_pin = 0; wait_us(5); temperature_pin.input(); wait_us(60); } else { temperature_pin.output(); temperature_pin = 0; wait_us(60); temperature_pin.input(); } d=d>>1; // now the next bit is in the least sig bit position. } } unsigned char OneWireInByte() // read byte, least sig byte first { unsigned char d = 0, b; for (int n=0; n<8; n++) { temperature_pin.output(); temperature_pin = 0; wait_us(5); temperature_pin.input(); wait_us(5); b = temperature_pin; wait_us(50); d = (d >> 1) | (b << 7); // shift d to right and insert b in most sig bit position } return d; } void _heat_check_HLT(int heat) //start retrieving temp from HLT tank { // sets the digital pin as input (logic 1) make sure external pullup resistor 4K7 OneWireReset(); OneWireOutByte( 0xcc); //Skip ROM command OneWireOutByte( 0x44); // perform temperature conversion, strong pullup for one sec OneWireReset(); OneWireOutByte( 0xcc); OneWireOutByte( 0xbe); //Read Scratchpad LowByte = OneWireInByte(); HighByte = OneWireInByte(); TReading = (HighByte << 8) + LowByte; SignBit = TReading & 0x8000; // test most sig bit if (SignBit) { // negative TReading = (TReading ^ 0xffff) + 1; // 2's comp } Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25 Whole = Tc_100 / 100; // separate off the whole and fractional portions Fract = Tc_100 % 100; if (SignBit) { // If its negative pc.printf("-"); } pc.printf("%d", Whole); if(heat == Whole) { h1 = 0x00; phase1_step2(); if(phase3 == 1) { phase1_phase2_step3(); } } pc.printf("."); if (Fract < 10) { pc.printf("0"); } pc.printf("%d", Fract); pc.printf("\r\n"); } void overflow_check() { pc.printf("in overflow_check()"); if(HLT()) { pc.printf("FILLED"); v1 = 0x00; overflow = 0; _heat_HLT = 1; h1 = 0xff; } } void LCDrunner() { display.FullScreenBMP(Menu_trial_startbut_Stop); wait(2); wait(2); display.FullScreenBMP(Menu_trial_startbut_RealTimeView); wait(2); display.FullScreenBMP(Menu_trial_startbut_Alert); wait(2); display.FullScreenBMP(Menu_trial_startbut_Status); wait(2); } void rtc() { test_rw(my1307.gettime( &sec, &min, &hours, &day, &date, &month, &year)); pc.printf("seconds read are %.2D \n\r",sec); pc.printf("min read are %.2D \n\r",min); pc.printf("hour read are %.2D \n\r",hours); pc.printf("day read are %.2D \n\r",day); pc.printf("date read are %.2D \n\r",date); pc.printf("month read are %.2D \n\r",month); pc.printf("year read are %.2D \n\r",year); pc.printf("SerPrinter"); } void LCDcall() { if(whichScreen == 1) { //temp alert //phase alert //overflow alert if(LCDviewer.read() == 5) { menu_alert = 0; LCDviewing = 0; LCDviewer.stop(); } } if(whichScreen == 2) { LCDiteration++; if(LCDiteration == 1) { display.ClearScreen(); display.SelectFont(System5x7,BLACK,ReadData); display.GotoXY(60,0); if (overflow == 1) { display.PrintString(" HLT filling"); display.GotoXY(1,0); display.PrintString("up"); } if(_heat_HLT == 1) { if(phase1 == true) { display.GotoXY(60,0); display.PrintString(" Heating HLT"); display.GotoXY(1,0); display.PrintString("to 122'F"); } else if(phase2 == true) display.PrintString(" Heating HLT to 154'F"); else if(phase3 == true) display.PrintString(" Heating HLT to 168'F"); } if(step3 == true) { display.PrintString(" In Step3 checking time");//phase1_phase2_step3_timecheck(); } if(flowmeterON == true) { if(phase1 == true)display.PrintString(" Filling water upto 20 quarts"); if(phase2 == true)display.PrintString(" Filling water upto 18 quarts"); if(phase3 == true)display.PrintString(" Filling water upto 20 quarts"); } } viewTIME = LCDviewer.read(); if(viewTIME == 5) { menu_status = 0; LCDviewing = 0; LCDviewer.stop(); LCDviewer.reset(); display.ClearScreen(); LCDiteration = 0; display.FullScreenBMP(Menu_trial_startbut_Stop); viewTIME = 0; } } if(whichScreen == 4) { LCDiteration++; if(LCDiteration == 1) { display.ClearScreen(); display.SelectFont(System5x7,BLACK,ReadData); display.GotoXY(60,0); //(60, 0) display.PrintString(" temp -"); display.GotoXY(1,0); //(60, 0) display.PrintString("122"); } viewTIME = LCDviewer.read(); if(viewTIME == 5) { menu_temp = 0; LCDviewing = 0; LCDviewer.stop(); LCDviewer.reset(); display.ClearScreen(); display.FullScreenBMP(Menu_trial_startbut_Stop); viewTIME = 0; LCDiteration = 0; } } } void IR_function(void) { if (ir_rx.getState() == ReceiverIR::Received) { ir_rx.getData(&format, buf, sizeof(buf) * 16); pc.printf("\n\rgot>> "); for (int i=0; i<sizeof(buf); i++) { pc.printf("0x%02X, ", buf[i]); //pc.printf("%i",i); } if(menu_stop == true && buf[2] == 0x01) { overflow = 0; flowmeterON = 0; step3 = 0; _heat_HLT = 0; pc.printf("Stopped"); display.FullScreenBMP(starts); menu_stop = false; buf[2] = NULL; } if(buf[2] == 0x01) { start = 1; waterValve(); pc.printf("Started"); display.FullScreenBMP(Menu_trial_startbut_Stop); menu_stop = true; buf[2] = NULL; } if(buf[2] == 0x0A && start == 1 ) {//1 button display.FullScreenBMP(Menu_trial_startbut_Temp); menu_temp = 1, menu_status = 0, menu_alert = 0, menu_realview = 0; _heat_check_HLT(122); } if(buf[2] == 0x1F && start == 1) {//3 button display.FullScreenBMP(Menu_trial_startbut_Status); menu_status = 1, menu_temp = 0, menu_alert = 0, menu_realview = 0; } if(buf[3] == 0xFF && start == 1) {//7 button display.FullScreenBMP(Menu_trial_startbut_Alert); menu_alert = 1, menu_status = 0, menu_realview = 0, menu_temp = 0; } if(buf[2] == 0x19 && start == 1) {// 9 button display.FullScreenBMP(Menu_trial_startbut_RealTimeView); menu_realview = 1; } if(buf[2] == 0x04) { for(int i=0; i<4; i++) { if(menu_alert == 1) { LCDviewing = 1; whichScreen = 1; LCDviewer.start(); } if(menu_status == 1) { LCDviewing = 1; whichScreen = 2; LCDviewer.start(); } if(menu_realview == 1) { LCDviewing = 1; whichScreen = 3; LCDviewer.start(); } if(menu_temp == 1) { LCDviewing = 1; whichScreen = 4; LCDviewer.start(); } } } switch (format) { case RemoteIR::UNKNOWN: pc.printf("????"); break; case RemoteIR::NEC: pc.printf("NEC"); break; case RemoteIR::AEHA: pc.printf("AEHA"); break; case RemoteIR::SONY: pc.printf("SONY"); break; } } } int main() { display.ClearScreen(); display.FullScreenBMP(pic); wait(2); display.FullScreenBMP(brew1); wait(2); display.FullScreenBMP(starts); wait(2); memset(buf, 0x00, sizeof(buf)); v5 = 0xff; flowmtr1_wait.attach(&flowmtr1_counter, 1.0); temperature_pin.output(); temperature_pin = 0; temperature_pin.input(); //LCDrunner(); while(1) { IR_function(); //_heat_check_HLT(122); if(overflow == 1) { overflow_check(); } if(_heat_HLT == 1) { if(phase1 == true) { h1 = 0xff; _heat_check_HLT(122); } else if(phase2 == true) _heat_check_HLT(154); else if(phase3 == true) _heat_check_HLT(168); } if(step3 == true) { phase1_phase2_step3_timecheck(); } if(flowmeterON == true) { if(phase1 == true)flowmeter1(20); if(phase2 == true)flowmeter1(18); if(phase3 == true)flowmeter1(20); } if(LCDviewing == 1) { LCDcall(); } if(MLT_diluting == 1) { phase3_MLT_diluting_routine(); } if (kettleBOIL) { kettleBoilingRoutine(); } } } // Example of how to put Text on LCD //display.DrawBitmap(mikro_test,5,5,BLACK);
