Thanks Piotr, for the idea. I've monitored the the power output with an oscilloscope but couldn't detect any pike. I've tried other GPS modules (Locosys LS20031 and LS20126) but ended up with the same result.
Another interesting point is that if I power the GPS unit with an external battery I get the position fix within seconds, but if I connected the GPS' ground to the mbed's ground, the position fix is lost as soon as I turn the mbed ON.
Did someone experienced this? Anyone managed to connect a GPS to the mbed without loosing the position fix?
Thanks in advance.
hello, I would like to use the EM-406 GPS with an mbed. According to the GPS data sheet (http://www.sparkfun.com/datasheets/GPS/EM-406A_User_Manual.PDF), the power input ranges from 4.5V to 6.5V DC. When I power the GPS with a battery (whitout the RX/TX lines connected), the position fix indicator is set after few seconds (in outdoor). However when I try to power the GPS from the mbed's 5V output I systematically loose the position fix. Any suggestion?
Thanks in advance!
