I've stumbled upon a very weird problem with the C24LCXX_I2C library to read/write to an EEPROM.
Writing works fine but when I try to read strings, using the stripped method underneath here, it usually fails with the I2C read returning 40. Meanwhile I figured out it has something to do with the length. When I change the p_length2write variable to hardcoded number 4 (to read the string "Test"), it reads just fine. When I pass 4 as an argument in a variable, it fails.
As if this isn't weird enough, the library also has an example app which displays a menu from where you can view all the functionalities. Reading/writing strings from that app works. When I strip down that app to only read/write strings, it also fails. This while I have not touched that piece of the code.
bool C24LCXX_I2C::Read(const short p_address, std::string & p_string, const bool p_readLengthFirst, const int p_length2write) {
short address = p_address;
char i2cBuffer[2];
i2cBuffer[0] = (unsigned char)(address >> 8);
i2cBuffer[1] = (unsigned char)((unsigned char)address & 0xff);
if (write(_slaveAddress, i2cBuffer, 2, true) == 0) {
char buffer[p_length2write];
int result = read(_slaveAddress, (char *)buffer, p_length2write);
if (result == 0) {
p_string.assign(buffer, p_length2write);
return true;
return false;
Is anyone able to shed some light on this?
