enum
ILI9325_COMMANDS_DRIVERCODEREAD = 0x0000,
ILI9325_COMMANDS_DRIVEROUTPUTCONTROL1 = 0x0001,
ILI9325_COMMANDS_LCDDRIVINGCONTROL = 0x0002,
ILI9325_COMMANDS_ENTRYMODE = 0x0003,
ILI9325_COMMANDS_RESIZECONTROL = 0x0004,
ILI9325_COMMANDS_DISPLAYCONTROL1 = 0x0007,
ILI9325_COMMANDS_DISPLAYCONTROL2 = 0x0008,
ILI9325_COMMANDS_DISPLAYCONTROL3 = 0x0009,
ILI9325_COMMANDS_DISPLAYCONTROL4 = 0x000A,
ILI9325_COMMANDS_RGBDISPLAYINTERFACECONTROL1 = 0x000C,
ILI9325_COMMANDS_FRAMEMAKERPOSITION = 0x000D,
ILI9325_COMMANDS_RGBDISPLAYINTERFACECONTROL2 = 0x000F,
ILI9325_COMMANDS_POWERCONTROL1 = 0x0010,
ILI9325_COMMANDS_POWERCONTROL2 = 0x0011,
ILI9325_COMMANDS_POWERCONTROL3 = 0x0012,
ILI9325_COMMANDS_POWERCONTROL4 = 0x0013,
ILI9325_COMMANDS_HORIZONTALGRAMADDRESSSET = 0x0020,
ILI9325_COMMANDS_VERTICALGRAMADDRESSSET = 0x0021,
ILI9325_COMMANDS_WRITEDATATOGRAM = 0x0022,
ILI9325_COMMANDS_POWERCONTROL7 = 0x0029,
ILI9325_COMMANDS_FRAMERATEANDCOLORCONTROL = 0x002B,
ILI9325_COMMANDS_GAMMACONTROL1 = 0x0030,
ILI9325_COMMANDS_GAMMACONTROL2 = 0x0031,
ILI9325_COMMANDS_GAMMACONTROL3 = 0x0032,
ILI9325_COMMANDS_GAMMACONTROL4 = 0x0035,
ILI9325_COMMANDS_GAMMACONTROL5 = 0x0036,
ILI9325_COMMANDS_GAMMACONTROL6 = 0x0037,
ILI9325_COMMANDS_GAMMACONTROL7 = 0x0038,
ILI9325_COMMANDS_GAMMACONTROL8 = 0x0039,
ILI9325_COMMANDS_GAMMACONTROL9 = 0x003C,
ILI9325_COMMANDS_GAMMACONTROL10 = 0x003D,
ILI9325_COMMANDS_HORIZONTALADDRESSSTARTPOSITION = 0x0050,
ILI9325_COMMANDS_HORIZONTALADDRESSENDPOSITION = 0x0051,
ILI9325_COMMANDS_VERTICALADDRESSSTARTPOSITION = 0x0052,
ILI9325_COMMANDS_VERTICALADDRESSENDPOSITION = 0x0053,
ILI9325_COMMANDS_DRIVEROUTPUTCONTROL2 = 0x0060,
ILI9325_COMMANDS_BASEIMAGEDISPLAYCONTROL = 0x0061,
ILI9325_COMMANDS_VERTICALSCROLLCONTROL = 0x006A,
ILI9325_COMMANDS_PARTIALIMAGE1DISPLAYPOSITION = 0x0080,
ILI9325_COMMANDS_PARTIALIMAGE1AREASTARTLINE = 0x0081,
ILI9325_COMMANDS_PARTIALIMAGE1AREAENDLINE = 0x0082,
ILI9325_COMMANDS_PARTIALIMAGE2DISPLAYPOSITION = 0x0083,
ILI9325_COMMANDS_PARTIALIMAGE2AREASTARTLINE = 0x0084,
ILI9325_COMMANDS_PARTIALIMAGE2AREAENDLINE = 0x0085,
ILI9325_COMMANDS_PANELINTERFACECONTROL1 = 0x0090,
ILI9325_COMMANDS_PANELINTERFACECONTROL2 = 0x0092,
ILI9325_COMMANDS_PANELINTERFACECONTROL3 = 0x0093,
ILI9325_COMMANDS_PANELINTERFACECONTROL4 = 0x0095,
ILI9325_COMMANDS_PANELINTERFACECONTROL5 = 0x0097,
ILI9325_COMMANDS_PANELINTERFACECONTROL6 = 0x0098,
ILI9325_COMMANDS_OTPVCMPROGRAMMINGCONTROL = 0x00A1,
ILI9325_COMMANDS_OTPVCMSTATUSANDENABLE = 0x00A2,
ILI9325_COMMANDS_OTPPROGRAMMINGIDKEY = 0x00A5
#include "LCDTFT_16bitto8bit.h"
LCDTFT::LCDTFT(PinName PIN_RD,PinName PIN_WR,PinName PIN_RS,PinName PIN_CS,PinName PIN_RESET, BusInOut *BUSLCD)
: LCD_PIN_RD(PIN_RD),LCD_PIN_WR(PIN_WR),LCD_PIN_RS(PIN_RS),LCD_PIN_CS(PIN_CS),LCD_PIN_RESET(PIN_RESET){
LCD_PORT=BUSLCD;
X=0;
Y=0;
X_min=0;
X_max=LCD_X_MAX;
_Alto=1;
_Color=0x0000;
void LCDTFT::vLCDTFTSetParametersPrintf(uint16_t Xo,uint16_t Yo,uint16_t Xmin,uint16_t Xmax,unsigned char Alto, uint16_t Color){
X=Xo;
Y=Yo;
X_min=Xmin;
X_max=Xmax;
_Alto=Alto;
_Color=Color;
int LCDTFT::_putc(int value){
char Fmt[2]={value,0};
if(value=='\n'){
X=X_min;
Y+=7*_Alto + 1;
}else{
vLCDTFTText(X,Y,(const char *)&Fmt[0],&ARIAL[0],_Alto,_Color);
X+=5*_Alto+1;
if(X >= X_max){
X = X_min;
Y += 7*_Alto + 1;
return(value);
int LCDTFT::_getc(){
return(-1);
@brief Writes the supplied 16-bit command using an 8-bit interface
void LCDTFT::vLCDTFTWriteCommand(uint16_t Command){
LCD_PIN_CS=0;
LCD_PIN_RS=0;
LCD_PIN_WR=1;
LCD_PIN_RD=1;
LCD_PORT->write(Command >> 8);
LCD_PIN_WR=0;
wait_ms(100);
LCD_PIN_WR=1;
LCD_PORT->write(Command);
LCD_PIN_WR=0;
wait_ms(100);
LCD_PIN_WR=1;
LCD_PIN_CS=1;
@brief Writes the supplied 16-bit data using an 8-bit interface
void LCDTFT::vLCDTFTWriteData(uint16_t Data){
LCD_PIN_CS=0;
LCD_PIN_WR=1;
LCD_PIN_RS=1;
LCD_PIN_RD=1;
LCD_PORT->write(Data >> 8);
LCD_PIN_WR=0;
wait_ms(100);
LCD_PIN_WR=1;
LCD_PORT->write(Data);
LCD_PIN_WR=0;
wait_ms(100);
LCD_PIN_WR=1;
LCD_PIN_CS =1;
@brief Sends a 16-bit command + 16-bit data
void LCDTFT::vLCDTFTWriteCommandData(uint16_t Command,uint16_t Data){
vLCDTFTWriteCommand(Command);
vLCDTFTWriteData(Data);
@brief Sets the cursor to the specified X/Y position
void LCDTFT::vLCDTFTAddressSetPoint(uint16_t x,uint16_t y){
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALGRAMADDRESSSET,x);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALGRAMADDRESSSET,y);
vLCDTFTWriteCommand(0x0022);
@brief Sets the window confines
void LCDTFT::vLCDTFTAddressSet(uint16_t x1,uint16_t y1,uint16_t x2,uint16_t y2){
// vLCDTFTAddressSet(PosXImagen, y, PosXImagen+WidthPixel-1, y);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALADDRESSSTARTPOSITION, x1);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALADDRESSENDPOSITION, x2);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALADDRESSSTARTPOSITION, y1);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALADDRESSENDPOSITION, y2);
vLCDTFTAddressSetPoint(x1, y1);
@brief Sends the initialisation sequence to the display controller
void LCDTFT::vLCDTFTInit(void){ // Initialize the ILI9225 lcd driver. return 0 if initial succeded
LCD_PIN_RD=1;
LCD_PIN_WR=1;
LCD_PIN_CS=1;
LCD_PIN_RS=1;
LCD_PIN_RESET=1;
wait_ms(100);
LCD_PIN_RESET=0;
wait_ms(100);
LCD_PIN_RESET=1;
wait_ms(100);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DRIVERCODEREAD, 0x0001); // Star oscillator
wait_ms(50);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DRIVEROUTPUTCONTROL1, 0x0100); // Driver Output Control Register (R01h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_LCDDRIVINGCONTROL, 0x0700); // LCD Driving Waveform Control (R02h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_ENTRYMODE, 0x1030); // Entry Mode (R03h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_RESIZECONTROL, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DISPLAYCONTROL2, 0x0202);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DISPLAYCONTROL3, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DISPLAYCONTROL4, 0x0000); // Fmark On
vLCDTFTWriteCommandData(ILI9325_COMMANDS_RGBDISPLAYINTERFACECONTROL1, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_FRAMEMAKERPOSITION, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_RGBDISPLAYINTERFACECONTROL2, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL1, 0x0000); // Power Control 1 (R10h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL2, 0x0007); // Power Control 2 (R11h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL3, 0x0000); // Power Control 3 (R12h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL4, 0x0000); // Power Control 4 (R13h)
wait_ms(200);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL1, 0x1690); // Power Control 1 (R10h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL2, 0x0227); // Power Control 2 (R11h)
wait_ms(50);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL3, 0x001A); // Power Control 3 (R12h)
wait_ms(50);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL4, 0x1800); // Power Control 4 (R13h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_POWERCONTROL7, 0x002A); // NVM read data 2 (R29h)
wait_ms(50);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL1, 0x0000); // Gamma Control 1
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL2, 0x0000); // Gamma Control 2
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL3, 0x0000); // Gamma Control 3
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL4, 0x0206); // Gamma Control 4
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL5, 0x0808); // Gamma Control 5
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL6, 0x0007); // Gamma Control 6
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL7, 0x0201); // Gamma Control 7
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL8, 0x0000); // Gamma Control 8
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL9, 0x0000); // Gamma Control 9
vLCDTFTWriteCommandData(ILI9325_COMMANDS_GAMMACONTROL10, 0x0000); // Gamma Control 10
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALGRAMADDRESSSET, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALGRAMADDRESSSET, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALADDRESSSTARTPOSITION, 0x0000); // Window Horizontal RAM Address Start (R50h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_HORIZONTALADDRESSENDPOSITION, 0x00EF); // ili9325Properties.width - 1); // Window Horizontal RAM Address End (R51h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALADDRESSSTARTPOSITION, 0x0000); // Window Vertical RAM Address Start (R52h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALADDRESSENDPOSITION, 0x013F); // ili9325Properties.height - 1); // Window Vertical RAM Address End (R53h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DRIVEROUTPUTCONTROL2, 0xA700); // Driver Output Control (R60h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_BASEIMAGEDISPLAYCONTROL, 0x0003); // Driver Output Control (R61h) - enable VLE
vLCDTFTWriteCommandData(ILI9325_COMMANDS_VERTICALSCROLLCONTROL, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL1, 0x0010); // Panel Interface Control 1 (R90h)
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL2, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL3, 0x0003);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL4, 0x1100);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL5, 0x0000);
vLCDTFTWriteCommandData(ILI9325_COMMANDS_PANELINTERFACECONTROL6, 0x0000);
// Display On
vLCDTFTWriteCommandData(ILI9325_COMMANDS_DISPLAYCONTROL1, 0x0133); // Display Control (R07h)
wait_ms(100);
vLCDTFTWriteCommand(ILI9325_COMMANDS_WRITEDATATOGRAM);
@brief Assign background color
void LCDTFT::vLCDTFTFillScreen(uint16_t Color){
uint16_t i,j;
vLCDTFTAddressSet(0,0,239,319);
//LCD_PIN_CS=0;
//LCD_PIN_RS=1;
//LCD_PIN_RD=1;
//LCD_PIN_WR=1;
for(i=0;i<320;i++){
for (j=0;j<240;j++){
vLCDTFTWriteData(Color);
//LCD_PIN_CS=1;
@brief Draws a single pixel at the specified X/Y location
void LCDTFT::vLCDTFTPoint(uint16_t x,uint16_t y,uint16_t Color){
vLCDTFTAddressSetPoint(x,y);
vLCDTFTWriteCommand(ILI9325_COMMANDS_WRITEDATATOGRAM); // Write Data to GRAM (R22h)
// LCDTFT(PIN_RD , PIN_WR , PIN_RS , PIN_CS , PIN_RESET , BusOut *BUSLCD);
BusInOut MyBus(p29,p22,p23,p24,p25,p26,p27,p28);
PwmOut BL(p21);
LCDTFT MyLCD(p19,p18,p17,p16,p20,&MyBus);
int main(){
MyLCD.vLCDTFTInit();
MyLCD.vLCDTFTFillScreen(ColorRed);
MyLCD.vLCDTFTSetParametersPrintf(10,20,10,229,2,0x0000);
MyLCD.printf("Hola mbed!!!");
wait_ms(2000);
MyLCD.vLCDTFTRectangle(0,0,239,319,1,0x0000);
MyLCD.vLCDTFTCircle(120,160,110,0,0xFFFF);
Hy. I am trying to program the following LCD (http://www.ghielectronics.com/catalog/product/262) which use the ILI9325 controller. I modified the code given for HX8347 (http://mbed.org/users/Suky/programs/LCDTFT_Library/llv383) to ca work with the ILI9325, i changed all the register. i used 16bit data in 8bit parallel interface. But it's not work and i dont know were is the problem.
here the code :
thanks
